VOGONS Driver Library
Reply 1280 of 1662, by mbarszcz
There were CRC errors in the Audigy 2 ZS Install CD in the driver library and on archive.org. I ripped my original install CD and uploaded it to archive.org here: https://archive.org/details/audigy-2-zs-install-cd
It would be good to replace the corrupt one in the driver library with a good ISO.
Reply 1281 of 1662, by Horun
mbarszcz wrote on 2022-02-14, 05:48:
You are correct in that there are some bad files in this one: http://www.vogonsdrivers.com/getfile.php?file … 510&menustate=0
The reason no one complained since it was uploaded in 2014 is that only the .chm under \warranty are bad. All the rest are good and it burned a working CD.
Only Squalstrife can swap out a file, even the uploader cannot change a file once posted....I edited the description to include the bad file info.
Reply 1282 of 1662, by Horun
Uploaded some Teac floppy manuals that I thought were included in some of the 3.5"and 5.25" floppy drive jumpers reference posted earlier but were not.
http://www.vogonsdrivers.com/getfile.php?file … &menustate=28,0
Reply 1283 of 1662, by NyLan
Hey,
might be a good idea to add this Driver.
It's the Win9x last version for CS461x but also works for CS462x
I'm using it for my IBM A20M as the driver included within the Windows98SE Recovery does not include the MS-DOS Driver.
The official windows driver from Cirrus Logic does include files and setup for MS-DOS. There's no MS-DOS Only driver and even the DOS part installs itself in C:\Windows\CWCDATA , add SET Blaster entry + launch CWCDOS.exe in autoexec.
http://nylan.info/share/PV2885.zip
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 1284 of 1662, by PC Hoarder Patrol
Horun wrote on 2022-02-21, 03:54:
Might want to add this then, from the 3.5" FD-05GF / HF / HG 'Super Slim' Series (several versions of the HF are used in the FD-505 combo drives)
The attachment TEAC FD-05HF-8830.pdf is no longer available
Reply 1285 of 1662, by Horun
PC Hoarder Patrol wrote on 2022-02-23, 09:09:
Yeah Thanks ! There a few others I found manuals for that need be uploaded to Library too. Will put them in separate part2 post since I cannot alter the contents of the other one...
Reply 1286 of 1662, by mscdex
If you're interested, here's a (DOS?) driver for a Pacific Rim parallel port-based floppy drive (5.25" IIRC) I came across on an old hard disk of mine. I didn't see it on your site so I thought you might be interested.
Reply 1287 of 1662, by NyLan
NyLan wrote on 2022-02-21, 10:41:
Hey, […]
Hey,
The driver has not been uploaded to VogonsDrivers. I also tried to contact SquallStrife to get an access but got no response yet.
+ I would like to add this driver for Accton EN1207D-TX
On Vogons there's the Packet Driver only. This package is the full driver from Dos,Windows3.11 to Windows2000.
Personal GitHub
Reply 1288 of 1662, by cyclone3d
Uploaded the IBM Branded MWAVE CD ISO:
http://www.vogonsdrivers.com/getfile.php?file … &menustate=38,0
Also uploaded the DOS, Windows 3.1x, 95 and OS/2 driver and wavetable files that were released for certain Thinkpad models. Guessing that they will work for the ISA cards as well.
Have some other files but need to test them first and that may be a while before that happens.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1289 of 1662, by MRVFONE
Hello, Here is the SB Pro (CT1600 i think) original driver disk (High Density) . I don't think this is on the site.
Thanks,
Tim.
Reply 1291 of 1662, by ruthan
It would be nice to add some ADI audio codecs drivers to Library, if someone is familiar with them.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1292 of 1662, by b_w
Here is a *HUGE* file listing dump from Microsoft WHQL drivers archive with over 16080 file(s) and 199 folder(s) certified in between October 1997 - March 2001.
ftp.microsoft.com/Services/whql/drivers/win95/
ftp.microsoft.com/Services/whql/drivers/Win98/
ftp.microsoft.com/Services/whql/drivers/WinMe/
ftp.microsoft.com/Services/whql/drivers/winnt40/ (x86/alpha/mips/ppc)
ftp.microsoft.com/Services/whql/drivers/winnt50/
Somewhere copies of ftp.microsoft.com are still maintained so feel free to find and download listed drivers and use it for good.
https://www.google.com/search?q=ftp.microsoft … es/whql/drivers
Reply 1293 of 1662, by harvald
I've found and scanned some manuals for 386 mainboards.
Reply 1294 of 1662, by jheronimus
Here are two floppy images from my latest purchases.
One is a driver disk from Terratec EWS64XL, version 23/07/1997
The other is Genius MouseMate & MediaMate — a driver disk from a Genius EasyTrak trackball. MediaMate is some Win 3.11 presentation software as far as I can tell.
https://www.dropbox.com/s/uz1dwgs4hktpu1w/terratec.IMG?dl=0
https://www.dropbox.com/s/kel46a7dvnt8q5g/mousemate.IMG?dl=0
MR BIOS catalog
Unicore catalog
Reply 1295 of 1662, by Horun
harvald wrote on 2022-04-12, 11:44:
386 mainboard manual - september 1993.pdf
386 mainboard manual - june 1993.pdf
Excellent !! The Sept 1993 manual matches Soyo 386 SY-019R1 : https://www.ultimateretro.net/en/motherboards/6747#downloads
and the June 1993 matches Soyo 386 SY-019L1: https://www.ultimateretro.net/en/motherboards/6798#downloads
Reply 1296 of 1662, by appiah4
jheronimus wrote on 2022-04-12, 22:02:
Envy....
Reply 1297 of 1662, by mrwho
Rescued this from a couple of failing floppies while adding network to my DOS machine. A quick search on Vogondrivers doesn't return any results, so here it is.
Already placed it on my ftp as well.
“Hey, you sass that hoopy MrWho? There's a frood who really knows where his towel is."
My home retro drivers repository: ftp://retro:drivers@mrwho.duckdns.org
Reply 1298 of 1662, by Pierre32
Uploaded Audigy series driver 2.18.0017 for 7/Vista/XP: https://archive.org/details/audigy-series-for-7-vista-xp
There are XP Audigy drivers on Vogons Drivers already, but in the form of a full ISO. I didn't feel like wrangling that so I just grabbed this more convenient 40MB pack from support.creative.com. It's their final XP pack, released in 2010. I think it'd be a nice option to have on Vogons Drivers, and I have upload access, but this size requires FTP and I haven't jumped through that additional hoop yet. Backed up to archive.org for now, and if someone with FTP access wants to add it here, cool. Otherwise I'll sort out my access later.
Body text:
Small Audigy driver package for those not wanting the full ISO. […]
Device support:
Sound Blaster Audigy including Platinum and Platinum eX series
Sound Blaster Audigy 2 including Platinum, Platinum eX, and Value series
Sound Blaster Audigy 2 ZS including Platinum and Platinum Pro series
Sound Blaster Audigy 4 Pro and Sound Blaster Audigy 4
Sound Blaster Audigy 2 ZS Notebook PCMCIA
OS Support:
Microsoft Windows 7 64-bit, Windows 7 32-bit, Windows Vista 64-bit with Service Pack 1 (SP1), Windows Vista 32-bit with SP1, Windows XP Professional x64 Edition, Windows XP Service Pack 2 (SP2), Windows XP Media Center Edition (MCE) 2005 or Windows XP MCE 2004
Do not install this driver for Sound Blaster Audigy LS, Sound Blaster Audigy SE, or Sound Blaster Audigy Value.
[edit] So many cool and interesting contributions posted here. Nice work everyone.
Reply 1299 of 1662, by Joseph_Joestar
I just noticed that someone uploaded the Sound Blaster Live 5.1 Platinum driver CD and application disk on archive.org.
Sound Blaster Live! 5.1 Platinum Driver CD
Sound Blaster Live! 5.1 Platinum Applications CD
Leaving the links here in case we want to mirror this, or if someone is looking for that specific driver disc.
My retro builds
