Reply 1300 of 3184, by 640K!enough
wrote:And guys. The possibility for a 4Mb ROM will make the whole project 500% more interesting. Please keep up the good work!
Frankly, I have never heard MIDI playback from a device with a 1 MiB instrument bank that I liked. The only one that was anywhere close was the Soundscape S2000 and DB. From what I've heard so far, the standard AMD/Eye & I ROM isn't terrible, but it's still quite a compromise. I find the percussion to be particularly lacking. They had to cut corners to get that many instruments to fit in 1 MiB.
Starting from the PPLT set, there is just about no way that I can think of to fit a complete sound bank in 1 MiB, much less with any semblance of quality. That is why place for the headers was so important.
In the current 44-pin SOP package, we can only source 1 MiB parts, with some possibility of a 2 MiB part if Digi-Key or Mouser get the 29F160 in stock. Even then, they are relatively expensive. I think it makes more sense to use a modern part, and add level translation and other hardware to a ROM daughterboard. That way, we can have any size ROM that is supported by the InterWave, and a quality sound set to match.
EDIT: Corrected spelling errors.
