How many Retro PCs do you have in your house?
Reply 140 of 202, by HanJammer
The true question is: how many of these PCs do you actually use? ;D
Reply 141 of 202, by SpectriaForce
Not counting the classic pc's that I have for sale, I own 5 classic desktop pc's (of which 4 are ready to use and always connected, the other one is a project that's almost ready) and I have ca. 5-6 classic laptops (all Toshiba except for one Fujitsu). Specifications range from a Pentium MMX 200 MHz to a Pentium III 1.0 GHz.
Reply 142 of 202, by bjwil1991
Update from my previous thread:
Retro PCs 1980's-1990's:
Commodore 64 (RF modulator went bad)
Second Commodore 64 (in an aftermarket case)
IBM WheelWriter 10 Series II <-- don't know if this counts or not
IBM QuietWriter 8 <-- don't know if this counts or not
Packard Bell Pack-Mate 28 Plus Windows 95C OSR 2.5 w/ USB Support, Plus! 95
Socket 5 build supplied by liqmat (10x 5.25" bays and that's the biggest case I've had in my life and the turbo display is programmable by pressing and holding the reset button to set the clock speed for both slow and fast).
IBM ThinkPad 380D Windows 98 upgrade installed over 95B
AMD K6-2/300 build Windows 95C OSR 2.5 w/ USB Support, Plus! 95 IE 4.0 V3 3000 PCI
HP Pavilion N3350 Windows 98SE
Slot 1 build Celeron 400 (needs repairs)
Somewhat or considered from 2000's:
Socket 370 Intel Celeron 1.4GHz build Windows 98SE
iMac G3/600 Graphite Edition
iMac G4/800 lampshade
HP Compaq NX5000 Linux
IBM ThinkPad R40 Windows XP Pro SP3
Gutted HP Pavilion 7955 (board, CPU, PSU, etc)
Gateway 400SD4 (needs work)
AMD Athlon 64 3000+ build Windows XP Pro SP3
AMD Sempron 64 build Windows 98SE
2x Dell Inspiron 600m Windows XP Pro SP3 (on 1), no OS (second one)
Dell Latitude D600 Server 2008
Dell Dimension 4550 (no OS ATM)
Dell Latitude D630 Hackintosh (needs work)
Dell Dimension E510 Linux
Compaq Presario C700 (C727US) w/ SSD Windows 7 Pro SP1 32-bit
Modern from 2010's:
ASUS X54C-RB01 notebook Windows 10 Pro x64
Raspberry Pi B+, 2 Model B, 3 Model B, and 3 Model B+
AMD FX-6300 Windows 10 Pro 64-bit (free upgrade from 8.1 Pro 64-bit) SSD for OS, HDD for games and stuff, and SSHD for games and stuff
Reply 143 of 202, by Fläskboi
OEM's:
1. IBM 5150, complete but packed down in working condition
2. Compaq LTE 5000, P75, complete in working condition
3. Compaq LTE 5300, P133, complete in working condition
4. Compaq LTE 5300, P133, complete in working condition
5. Compaq LTE 5400, P150, complete in working condition
6. Compaq Armada 1590DT, P166, complete in working condition
7. Dell Dimension XPS P200s, P233MMX @200, complete in working condition
8. Toshiba Libretto 100CT, P166 @233, in parts but working
9. Toshiba Libretto 100CT, P166 @166, in parts but working
10. Compaq Armada 100S, K6-2+ 550, complete in working condition
11. Compaq Presario 5722, PIII-500, complete in working condition
12. IBM PC300PL, PIII-750, complete in working condition
Custom builds:
13. 486DX2-66 system, complete in working condition
14. Asus P/I XP55T2P4 system, K6-II 550, being set up right now
15. Epox MVP3G-M system, K6-III 400, complete in working condition
Waiting for chassis or being sold:
16. Noname S7 AT desktop board, K6-450AFX, w/ built-in cache
17. Noname S7 AT desktop board, unknown Intel CPU and 256k RAM
18. MSI MS-5169, Pentium 166 and RAM
19. Asus P5A v1.04 w/ unknown CPU and RAM
20. Asus P5A v1.06 w/ unknown AMD CPU
And another five, yet unknown (except for a Mac classic) computers donated, waiting for pickup in early October.
Wish I had a house instead of this three-room apartment.. 😉
Reply 144 of 202, by bjwil1991
I live in a house, but I need to get a high paying job in the future and install an add-on to my house that'll be my computer lab with A/C and heat for my rabbits as well. Of course, the add-on will have copper wiring and I might get the whole house rewired to copper (my basement and laundry room have copper wiring).
Reply 145 of 202, by alvaro84
Does a C64 count? I guess so 😀
So, the complete builds in cases and whatnot:
1. C64 (old or new, I have both) on Samsung 214T via s-video, 1541 and Oceanic drives, some fastloader cartridge, and X1541 for file transfer.
A system I didn't have in its time. I had a Z80-based Eastern Bloc micro instead (called a Videoton TVC). But there are great demos and great community around C64 so I longed to have one. Now I have like three. And a half. And one that's not mine.
2. Octek Fox II + Harris 80286-20; 4MB SIMM RAM; CL-GD5402 ISA VGA; GUS 2.4 + ESS 688; Quantum Trilblazer 840 HDD (504M used), 3.5+5.25" FDDs, in a neat black mini tower.
Because I needed a PC that's not even 32-bit. I don't know why but I did.
3. Abit AB-PB4 + Am5x86-133@160; 32MB FPM RAM; S3 Virge/DX VGA; Primax GUS clone + SB16/CT2290; 6.4GiB HDD; one dual 3.5/5.25" FDD, highly impractical for this particular build as I don't have the front covers for the yellowed full plastic case.
The nostalgy is strong here, I used to have an Am5x86 with an ALI PCI board. Now I have it again. Very good for not too modern DOS demos, even true color if one's, let's say, careful. Makes a good bridge machine to copy C64 stuff (via X1541) too as both the sound cards and the LPT port seems to work.
4. MSI 694T Pro + P3S-1.4@1.5 + 512MB PC133@143/cl2. Asus AGP-V3000 (Riva 128) VGA, GUS 3.74, SBLive!+LiveDrive, 20GB HDD, still two FDDs and a DVD-ROM.
Was my first permanent build. Made it strong enough for the latest DOS demos and games. Yet I wouldn't call Blood in 1600x1200 particularly playable on this one. Otherwise it's fine and serves as a backup for the older retro machines too. I also want to venture into win98 territory with this one.
5. Asus M5A78L-M/USB3 + Phenom II X2 555BE @ 4 cores + 12GiB DDR3-1333; Radeon 5870 VGA; onboard sound. 500GB HDD, may be replaced or backed by an SSD later. Or completely rebuilt around a 400GB SAS SSD I accidentally have.
I built this to have a semi modern gaming PC for the strongest VGA I've ever found. And because even the existence of a "dual core" CPU with 2 more unlockable cores fascinated me. It's quite power hungry so I don't really use it outside heating season. It runs games... fine, except that I'm always trying to run too modern ones on it, because I have no stronger VGA around.
And I have another empty AT case for something I haven't decided yet. Maybe a K6-2. Maybe a 486SLC. I'm absolutely unsure.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 146 of 202, by FFXIhealer
That's tough to answer, since they all get used from time to time. If you mean REGULARLY, then the 2008 Dell Vostro 230 and the 2015 Skylake Gaming Rig get used primarily and the Xeon Ubuntu server sits in the back of the room and is on 24/7.
The Pentium 3 rig is my primary retro gaming system for Win9x and DOS games because it covers both DirectX 7 and GLIDE via the Voodoo2 SLI and the TNT2 cards in the same system. The P54c system was just me using spare parts lying around and having fun tweaking DOS 7 configurations. It has a Voodoo1 so it can game and Tomb Raider 1 runs GREAT on it, but otherwise, there's no REAL reason to have it other than to mess around on it from time to time for nostalgia. The Athlon XP system sits on the side and does nothing unless I can get my hands on a working Radeon 9800 Pro/XT, which are stupid expensive on the used market. I've hooked up my 2010 i7-860 gaming rig a few times when a friend comes over to do LAN gaming, but it usually sits in the corner too. It's my custom water cooling system - so it's sort of a work in progress. It's also the last time I messed with SLI as it has two Fermi GTX 480s and the Big Bang Trinergy cost me $350 back in 2010 in order to get me dual-16x PCIe 2.0 slots simultaneously (in order to prevent bottlenecking the Fermi cards from 8x limits). I have never paid even half that for any motherboard since.
My Dell XPS laptop gets brought out from time to time to play era-correct games, such as Final Fantasy 11 (see my handle) and F.E.A.R. 1 (which refuses to run on either of my two Windows 10 gaming rigs).
Reply 147 of 202, by kixs
Yes, that is the real question 🤣
At the moment I don't use any. This moment is going on for a few years now. I just test them and get to play with the hardware, do some benchmarks and that's it 😊 Nowadays I don't even have the time to test and sell the parts I don't need or have duplicates... 😢
Visit my AmiBay items for sale (updated: 2025-08-01). I also take requests 😉
Reply 148 of 202, by fjk61011
I have an IBM PS/1 TYPE 2121.
It came with a 386SX chip, 2 Mb of Ram and a 42 Mb hard drive.
Over the years I've upgraded it to a 486SX with a Cyrix chip, 6 Mb of memory and various hard drives. I also bought an adapter unit with 3 ISA slots and the 5.25" floppy drive unit.
I also managed to find the elusive Audio card.
It came with IBM PC DOS 4 and Windows 3.0
Reply 149 of 202, by tanasen
I currently own four retro pc's and I'm about to receive another one from a friend (which I've previously upgraded for him).
1. Pentium III-S 1.4GHz, Gigabyte GA-6VTXE, 2x256MB SDRAM-133, Chaintech GeForce 2Ti 32MB or Albatron FX 5900XTV 128MB, Creative Audio PCI CT4810, C-Media CMI8738, OS: Win98SE
2. Pentium III 800MHz, MSI MS-6178, 256MB SDRAM, 3DFX Voodoo 3 2000 PCI, Soundblaster Live! 5.1 (need to replace this as it stopped working 🙁 ), OS: WinME
3. Pentium MMX 200MHz, Soyo SY-5EAS5 (AT), 128MB SDRAM , Diamond Viper V330, Diamond Monster 3D, ESS Audiodrive 1868F LP, OS: Win95 OSR 2.1
4. Pentium 4 3.0GHz Northwood, Fujitsu D1675, 2x1GB DDR-400, XFX Radeon HD4650 512MB AGP, Soundblaster X-Fi Platinum, OS: WinXP SP2
and the upcoming one is probably the most interesting for me: Celeron Mendocino 433MHz (about to upgrade to a 533MHz Celeron), Asus P2L97-S (440LX), 2x128MB SDRAM, Diamond Stealth 3D 4000 AGP, Gainward Dragon 3000 (about to add a Creative Labs 3D Blaster Voodoo2 for SLI), Soundblaster Vibra16S, OS: Win98SE.
PC1😜 III-S 1.4GHz, GA-6VTXE, 512MB SDRAM, Albatron FX5900XTV 128MB, SB Live! 5.1
PC2😜 III 800MHz, MS-6178, 256MB SDRAM, 3DFX Voodoo3 2000 PCI, Creative CT4810
PC3😜 MMX 200MHz, SY-5EAS5, 128MB SDRAM, Diamond Monster 3D, Diamond Viper V330, ESS 1868F
Reply 150 of 202, by appiah4
I have the seven systems in my signature, and 5 other OEMs of various brands and eras, but they are all packed away in storage. In addition, I am currently in the process of building a DOS/Windows/OS2 daily driver that I can actually keep inside the house, though I can't really decide on what to build (DX4-100 PCI/VLB vs 233MMX vs PII-350).
Reply 151 of 202, by Deksor
I have 14 mounted towers and 10 ""working"" laptops. But I could probably increase that number by mounting other computers with all the parts I have, and also fix some dead laptops I have. There are also two pentium 2 towers I didn't count for some reason (one I plan to sell)
Reply 152 of 202, by hwh
Probably 20-25 systems, mostly in "storage." And parts.
As for use, this computer is "modern" from 2010. The laptop, well, that was modern but now it's so old, well, it's from 2002. Compaq Presario 905. Recently I went to an estate sale and collected a P100, got it going and that's the only one connected because believe you me I don't have a place to set up 20 computers. That makes 3.
Or 2 1/2 since I really don't have time for this stuff and haven't turned the old one on in like two weeks.
I used to use the laptop for everything, including YouTube, but now they've degraded their website so badly it's no longer practical. Plus the higher resolution video is no-go. So it's mostly a web browsing-file downloading thing.
Other recent turn ons include my 2003 build Athlon 64, but that's not really "vintage" and TBH I could probably technically use it as a primary computer if I wanted to; it's fast enough and just about does it. Was happy to recently see its Epson 5.25" working again; those things are so touchy I can't believe.
Oldest I think is a 5150 from 86. Few Apples (I was enjoying that for a while). Got an XT, a 286, a 386, a few 486s and a bunch of Pentiums.
Reply 153 of 202, by PTherapist
PTherapist wrote:
Not sure how much of this people would consider "retro" but nonetheless, my collection is as follows - […]
The Old/Retro PC Build specs:
PC 1: Intel Celeron 1.2GHz (Tualatin), 512MB RAM, GeForce FX5500 256MB PCI, Opti 82C931 ISA Sound, Sound Blaster Live! PCI Sound. OS: Windows 98SE & Windows XP
PC 2: AMD Sempron 3500+, 2GB RAM, GeForce 7300LE 128MB PCIe. OS: Mac OS X 10.6 Snow Leopard
PC 3: Intel Pentium III 650MHz, 512MB RAM, TNT2 32MB AGP, Sound Blaster Live! 5.1 PCI Sound. OS: Zeta 1.21, Windows XP, Windows 98SE
PC 4: AMD K6-2 500 @ 300MHz, 128MB RAM, Voodoo3 16MB PCI, Sound Blaster AWE64 ISA Sound. OS: Windows 98SE
PC 5: IDT Winchip C6 200MHz, 72MB RAM, Virge 2MB PCI Graphics, ESS 1868 ISA Sound. OS: Windows 95
PC 6: AMD Am486 DX-40 @ 33MHz, 28MB RAM, Tseng Labs ET 4000 1MB ISA, ISA Sound (need to check). OS: Windows 95
PC 7: Intel 80386SX 16MHz, 10MB RAM, Western Digital Onboard Graphics. OS: MS-DOS 6.22 with Windows for Workgroups 3.11
PC 8: AMD Athlon XP 3200+, 1GB RAM, AGP Graphics (need to check), Onboard Sound. OS: Windows 7
PC 9: Intel Celeron 400MHz (PII era, Mendocino), 64MB RAM, 3D Rage Pro 8MB AGP, Onboard Sound. OS: Solaris 10
PC 10: Intel Pentium 4 3.0GHz (Prescott, Socket 478), 1GB RAM, GeForce FX 5700VE 256MB AGP, Onboard Sound. OS: Windows 7
PC 11: AMD Athlon 64 3200+, 2GB RAM, Radeon HD 3450 512MB AGP, Onboard Sound. OS: Windows 7
PC 12: AMD K6-2 450MHz, 128MB RAM, TNT Vanta 16MB AGP, Aureal Vortex 2 PCI Sound. OS: Windows XP & Windows 98SE
PC 13: Intel Pentium III 1.0GHz (Coppermine), 768MB RAM, GeForce 4 MX440 64MB AGP, Onboard Sound. OS: eComStation 2.1
PC 14: Intel Celeron D 320 2.4GHz, 512MB RAM, Intel 82845G Onboard Graphics, Onboard Sound. OS: Windows 7
PC 15: AMD Duron 892MHz, 512MB RAM, Radeon 9200SE 128MB AGP, Onboard Sound. OS: Windows XP
PC 16: AMD K6-2 400MHz, 160MB RAM, Voodoo3 16MB PCI, ESS Solo-1 Onboard Sound. OS: Windows 98SE
PC 17: Intel Pentium III 500MHz, 128MB RAM, Rage 3D Pro 4MB Onboard Graphics, Onboard Sound. OS: Windows 98SE
PC 18: AMD Sempron 3000+, 1GB RAM, Radeon HD 3450 512MB AGP, Onboard Sound. OS: Windows 7
PC 19: Intel Pentium II 266MHz, 160MB RAM, Riva 128 4MB AGP. OS: Windows XP (will remove soon)
PC 20: AMD Athlon XP 1900+, 1.2GB RAM, GeForce4 MX 4000 128MB AGP, Onboard Sound. OS: Windows XP
PC 21: Intel Celeron 700MHz (Coppermine), 192MB RAM, Onboard Graphics (need to check), Onboard Sound. OS: Windows 2000
PC 22: Intel 80286 12MHz, 1MB RAM, Trident TVGA 8900C 1MB ISA, Hercules Monochrome ISA Graphics. OS: IBM PC DOS 7.0, with GEM/3 Desktop 3.13 & Windows 3.1
The unbuilt specs:
PC 1: Intel Pentium MMX 233MHz, 128MB RAM.
PC 2: AMD Duron 800MHz.
PC 3: Intel Celeron D 335 2.8GHz, 512MB RAM, Intel 865G Onboard Graphics, Onboard Sound.
PC 4: Intel Celeron 1.2GHz (Tualatin), 128MB RAM, Trident Blade 3D Onboard Graphics, Onboard Sound.
PC 5: AMD Athlon XP 2600+, 256MB RAM, SIS Mirage 64MB Onboard Graphics, Onboard Sound.
PC 6: AMD Athlon XP 3200+, 512MB RAM, Radeon HD 2600XT 256MB AGP, Onboard Sound.
PC 7: Intel Pentium III 450MHz, 128MB RAM.
PC 8: AMD Duron 800MHz, 64MB RAM, Rage XL AGP Graphics, Sound Blaster 128 CT4810 PCI Sound. (this system presently has a case, but will soon be reused for another build)
PC 9: Intel 8088 4.77MHz, 256KB RAM.
The Active/More Modern Built PCs:
PC 1: AMD Athlon 64 X2 5200+, 4GB RAM, GeForce Quadro FX1700 512MB PCIe, Onboard Sound. OS: Windows 10
PC 2: Intel Core 2 Quad Q6600, 4GB RAM, GeForce GT 430 1GB PCIe, Onboard Sound. OS: Windows 10
PC 3: AMD Athlon 64 X2 6400+, 4GB RAM, Radeon HD 3450 256MB PCIe, Onboard Sound. OS: Ubuntu 16.04 LTS
PC 4: AMD Athlon II X2 4450E 2.8GHz (unlocked Sepmron 145), 8GB RAM, Radeon HD 5450 512MB PCIe, Onboard Sound. OS: Windows 8.1
PC 5: Intel Core 2 Duo E8400, 2GB RAM, Radeon HD 5450 512MB PCIe, Onboard Sound. OS: Windows 7 (getting Windows 10 soon)
PC 6: Intel Pentium D 830 Dual Core 3.0GHz, 2GB RAM, Radeon HD 5450 PCIe, Sound Blaster (need to check model) 5.1 PCI Sound. OS: Windows 8.1
PC 7: AMD Athlon 64 X2 5600+, 2GB RAM, Radeon HD 5450 512MB PCIe, Onboard Sound. OS: Windows 8.1
Laptops & Tablets:
Laptop 1: Intel Core 2 Duo T5300, 2GB RAM, Intel 945 Graphics. OS: Windows 10 (7 to be reinstalled soon).
Laptop 2: Intel Core i3-6100U, 8GB RAM, Intel HD 520 Graphics. OS: Windows 10
Laptop 3: AMD Turion 64 MK-36 2.0GHz, 2GB RAM, Radeon Xpress 1100 Graphics. OS: Windows 10
Laptop 4: Intel Pentium III 897MHz, 512MB RAM, Intel 82815 Graphics. OS: Windows XP & Windows 98SE
Tablet 1: Intel Atom Z3735G Quad Core 1.83GHz, 1GB RAM. OS: Windows 8.1
Plus I have 3 ARM-based Android tablets & a Blackberry Playbook.
Macs:
Mac 1: Mac mini, PowerPC G4 1.25GHz, 512MB RAM, Radeon 9200 32MB Onboard Graphics. OS: Mac OS X 10.3 Panther
Mac 2: Power Macintosh G3 Beige Desktop, PowerPC G3 300MHz, 448MB RAM, Rage 128 16MB PCI, 3D Rage Pro 2MB Onboard Graphics (disabled). OS: Mac OS X 10.4 Tiger & Mac OS 9.2.2
Mac 3: PowerMac G5, PowerPC G5 Dual 2.0GHz, 3GB RAM, GeForce 6200 256MB AGP. OS: Mac OS X 10.4 Tiger & Lubuntu 16.04 LTS
Mac 4: iMac DV Summer 2000, PowerPC G3 400MHz, 512MB RAM, Rage 128 Pro 8MB Onboard Graphics. OS: Mac OS X 10.4 Tiger & Mac OS 9.1
Mac 5: iMac DV Summer 2000, PowerPC G3 400MHz, 128MB RAM, Rage 128 Pro 8MB Onboard Graphics. OS: Mac OS X 10.4 Tiger & Mac OS 9.1
Mac 6: iMac Rev. D, PowerPC G3 333MHz, 320MB RAM, Rage Pro 6MB Onboard Graphics. OS: Mac OS X 10.3 Panther & Mac OS 9.1.
Mac 7: Power Macintosh G3 Blue & White, PowerPC G3 350MHz, 512MB RAM, Radeon 7000 64MB PCI Graphics. OS: Mac OS 9.2.2
Other Vintage Computers:
System 1: Commodore 64C
System 2: Sinclair (Amstrad) ZX Spectrum +2A
So in addition to this post of mine from over a year ago, I took a look at my inventory and I've since acquired further systems. That's mad, as I wasn't planning to expand so much.
So my current tally stands at 64 systems, of which 55 are built & operational. New additions/alterations since last year (including non-retro additions):
The unbuilt PC 9 from above has since been built as below.
PC 23: Intel 8088 4.77MHz, 256KB RAM, UMC UM6845R CGA Graphics, 20MB MFM HDD. OS: IBM PC DOS 3.30
PC 24: AMD Sempron 3500+, 2GB RAM, Radeon HD 3450 256MB PCIe Graphics, Onboard Sound. OS: Windows 10
A couple of Thin Clients added to my collection:
TC1: VIA Nano U3400 800MHz, 1GB RAM, VIA Chrome9 HCM 256MB Onboard Graphics, VIA Onboard Sound. OS: Windows XP Professional
TC2: VIA C7 1.0GHz, 512MB RAM, Via/S3G UniChrome Pro 64MB Onboard Graphics, VIA Onboard Sound. OS: Windows ME
Some more Laptops & Tablets added to my collection:
Laptop 5: Intel Celeron Dual-Core T3300 2.0GHz, 6GB RAM, Intel GMA 4500M Onboard Graphics, Onboard Sound. OS: Windows 7
Laptop 6: Intel Pentium Dual-Core T4400 2.20GHz, 3GB RAM, Intel GMA 4500MHD Onboard Graphics, Onboard Sound. OS: Windows 7
Laptop 7: Intel Core i5-2520M 2.50GHz, 6GB RAM, Intel HD 3000 Onboard Graphics, Onboard Sound. OS: macOS 10.14 Mojave (this is not a Mac laptop, total Hackintosh)
Tablet 6: Intel Atom Z3735G Quad Core 1.83GHz, 1GB RAM. OS: Windows 8.1
Also added another ARM-based/Android tablet - Amazon Fire 7 (2017). Purchased in an emergency while on holiday in the US, as my travel tablet got broken.
My newest Active/More Modern Built PC & current main system:
PC 8: Intel Core i7-4770K (overclocked to 4.5GHz), 16GB RAM, GeForce GTX 980 Ti 6GB PCIe Graphics, Onboard Sound. OS: Windows 10.
Another Vintage Computer:
System 3: Amstrad CPC 464, Zilog Z80A 4.0MHz, 576KB RAM (64KB Onboard + 512KB Expansion), DDI-5 USB HxC Floppy Emulator. A variety of OS: ParaDOS, AmsDOS, SymbOS, CP/M Plus 1.0.
Just for fun and not mentioned in my previous post, but my Games Consoles collection, in the order I originally acquired them:
Console 1: Hanimex Model 8881 Colour TV Game (Pong-based system)
Console 2: Sega Master System 1
Console 3: Systema TV Boy II (Atari 2600 clone)
Console 4: Sega Mega Drive 1
Console 5: Nintendo Entertainment System
Console 6: Sega Dreamcast
Console 7: Microsoft Xbox 360 (Falcon)
Console 8: Nintendo Wii
Console 9: Microsoft Xbox 360 (Zephyr)
Console 10: Microsoft Xbox One
Console 11: thumbsUp! OR-MINITVGAME, Model 8039 (NES Clone)
Console 12: E-Mods Gaming RS-1 (Handheld NES clone, with TV output)
Console 13: Sony PlayStation
Console 14: Sony PlayStation 2
Console 15: Microsoft Xbox
Now to answer how many PCs I actively use day-to-day, that answer still sits at around 10 active systems.
Of my retro builds, only my 8088 PC & Thin Client 1 are actively connected up at present, all the rest of my old/retro systems are pulled out of storage as and when I wish to mess around with them.
Reply 154 of 202, by retropol
PTherapist, you are sick 😀 you need ... (P)THERAPY.
Reply 155 of 202, by PTherapist
Damn, no time for the therapy, gotta play with all these systems first. 🤣
Reply 156 of 202, by DaveJustDave
holy cow, i've lost track.
Apple IIc
Apple IIe
Apple IIGS
Apple Macintosh IIci
Commodore 128
Commodore 128D
Commodore Amiga 500
Commodore Amiga 1000
Commodore Amiga 3000
Commodore Amiga 1200
Atari 1040STFm
Atari 1040STe
Atari Falcon 030
Atari 800XL
IBM 5150
IBM 5160
IBM 5170
IBM PS/1 286
IBM PS/1 386sx
IBM PS/2 model 30 8086
IBM PCJr
Tandy 1000SL
Tandy 1000TL
and then I have a pile of 486/pentium/mmx/pentium 2/pentium 3/pentium 4 systems in various states, some complete, some not complete. Probably a dozen complete systems. Also have three Dell XPS Dimensions (old beige ones) varying from p2 to p3 that i need to consolidate).
I'm running out of space
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 157 of 202, by retropol
1 x 486DX2 - 1994
1 x 200MMX - 1997
1 x DURON - 2000
1 x ATHLON - 2002
2 x amiga 500 rev 6
2 x amiga 500 rev 8.1
1 x amiga 500 rev 3
1 x amiga 500plus
1 x amiga 600 rev 1
1 x amiga 600 rev 2
looking for amiga 1200, want to sell some of the amigas 500
Reply 158 of 202, by oeuvre
Just one, a Dell Optiplex GXM 5133
Reply 159 of 202, by SaxxonPike
I've got many systems worth of parts but only have three "built" PCs.
- 1x Commodore 64, using the Reloaded MK2 motherboard (and I've got all sorts of chips from different systems: pal nmos/hmos, ntsc nmos/hmos, 6581, 8580, etc etc to drop in there)
- 2x Athlon XP machines (for some local multiplayer stuff and running games "on real hardware" as opposed to Dosbox)
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
