Reply 140 of 452, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Do they hold settings through a power cycle? Volume and whatever else you can set. If yes, then there must be a battery
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 141 of 452, by m5215tx
Well, I am wondering if these may have memory that can hold it's data even after a power cycle. That would be nice as there would be no worry about any battery issues over time.
Roland MT-32 (old), CM-32LN, SC-55, SC-88VL, MT-120, SD-35, SD-20, SD-80, SD-90
Yamaha TG100, TG300, MDF2, MU15, MU100, MU2000EX + PLG150-DR + PLG150-PF + PLG150-VL
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 142 of 452, by Cloudschatze
Per its service manual, the Yamaha MU2000(EX) has a standard, holder-mounted CR2032.
Reply 143 of 452, by m5215tx
Thanks Cloudschatze! It would be great to find a copy of the service manual as I did not locate a free download of one in my search.
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
Reply 144 of 452, by Nukkus
I just replaced the original battery in my SC-50. 😀
Reply 145 of 452, by thierry
SC-155 Battery Leaked ! , im remplace it
Reply 146 of 452, by blackmasked
What's your experience with power supplies for Roland SC and Yamaha MU modules? Have you experienced any failures? I recently purchased a genuine Yamaha PA-130 PSU for my MU80 as I no longer trust the 20 year old PSU that came with it, but it's a bit of a struggle to find a decent replacement PSU for a SC-55. Looks like Roland has not released a newer version of ACB-240 and I don't really trust all these third party compatible PSUs available on ebay.
DOS build: Gigabyte GA-586T2, P200 MMX, 64MB RAM, Tseng ET6000 4MB, Sound Blaster AWE64 Gold, Roland SC-55mkII, Yamaha MU-80
98SE build: MSI MS-6163 Pro, PIII 650MHz, 256MB RAM, Voodoo3 3000, Sound Blaster Live! 5.1 Platinum, Yamaha SW1000XG
Reply 147 of 452, by elod
blackmasked wrote:
I don't really trust all these third party compatible PSUs available on ebay. [/color]
Don't. Just get something branded that outputs the same voltage then change the connector.
Or get a decent universal PSU (should be >10 dollars/euros).
Reply 148 of 452, by derSammler
Personally, I trust a 20-year old transformer-based PSU much more than a new switching-mode PSU made in China...
Reply 149 of 452, by bjwil1991
Speaking of newer PSUs, I have 2 RCA universal PSUs that are rated for up to 2.5A and 12V (either DC or AC, can't recall) for a Yamaha TG-100 and Delco radio from 1996 that was pulled out of the 96 Safari that we had, which does work.
Reply 150 of 452, by blackmasked
I think all these C64 users who saw their beloved machines go up in flames would disagree, myself included. ;]
Reply 151 of 452, by voodoo5_6k
Oh yes, they did release a replacement unit.
The Roland PSB-230 (or PSB-1U if bundled with a Roland device) can replace, among others, any Roland ACB or ACI PSU (the PSUs bundled with e.g. MT-32, CM-32L, SC-55 and many, many other devices). I use these for all my Roland devices (UM-550, CM-32L, SC-55) for several years now. Shouldn't be too hard to find one, it is a current product.
END OF LINE.
Reply 152 of 452, by derSammler
But that's because those PSUs are simply cheap sh*t and have no protection whatsoever. Also, these supply higher voltage than needed which is then regulated down. If the regulator goes short, the much too high voltage goes directly to the device. This is not how you would normally build a PSU.
Reply 154 of 452, by badmojo
I bought a replacement PSU for my MT-32 recently - insanely cheap from China but it appeared identical to another one that I'd had an used for years. It arrived and looked the goods, but it was so light that I was moved to open it up and see if there was anything in there - there was, but I chucked it all the same.
I've since remembered that I have a spare Sega Mega Drive PSU here which people have said are workable - 10V instead of 9V tho.
Reply 155 of 452, by keropi
Yeah 10v will work just fine, the SC-55s do regulate again to 5v internally so it's no big deal. Even higher would work but I'd put a limit to 12v since the internal heatsinks/design is not made for more and the unit could overheat.
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 156 of 452, by blackmasked
Thanks for the tip voodoo5_6k, that's exactly what I was after ;]
Reply 157 of 452, by badmojo
Good to know - what about MT-32s? Do they regulate too do you know?
Thanks again.
Reply 159 of 452, by derSammler
btw, we need a thread "Have you opened your SB-55 to check the caps inside?" 😉
