Reply 140 of 894, by ynari
Damnit, didn't realise there was a final batch. Currently waiting on my amibay account being authorised..
It's authorized, and you got a PM there 😀
Hurrah! One bought! 😀
Two left for anyone else looking..
I finally got around to reviewing this card 😊
I tested all the "tricky" games requiring intelligent mode and IRQ 2 and they all worked of course.
Here is my video review of the MPU 401 MIDI card: https://youtu.be/WdfXdsN3fcU
Apparently, Amibay.com hates me right now. I couldn't remember my password and when I typed in the temporary password, it says that I have to retry in 15 minutes... Ugh!
I'm interested in the card itself, but in US currency, 110 Euros is $123.52 USD, and PayPal isn't an option, unless it's temporary.
I see that the amibay thread is closed. Don't hesitate to let us know whenever another batch is coming, I'm interested!
There will be a final batch of 10 cards available very soon, after that it will be a while before more are made.
Ok cheers, will it be advertised here or on Amibay?
^ they are already on AmiBay since last week, 1 card left for now!
wrote:^ they are already on AmiBay since last week, 1 card left for now!
Such a shame I was ready to buy you one 🙁
Don't worry , you will get one 😉
Hello,
I got one of that card, it's perfect work in my Pentium 1 200MMX system with default settings (330, IRQ2)
Now I build new DX4-120 system, check vga, i/o, Awe32 for free irq2, but when start system and run mqdiag catch message "interface found but unable determine irq level"
On the IRQ line bottom i find that IRQ2 - free and enable. Anyone know whats is problem ?
Thanks
My hardware:
enough for my wife to hate
This error is related to resource conflict, since IRQ2 is free like you say then it's port 330 - did you check that the AWE32 isn't configured to use it? Run it's setup to verify that AWE32 is using port 300
I have CT2760 no pnp card. I setup it to 220, IRQ7 DMA1,5 and midi 300. Also i check multi i/o card and disable LPT port. MT-32 software works, but sysex not worked.
Today i set up pin on mpu to IRQ3 and all work perfectly, but as i know that not dafault IRQ for MPU 🙁
PS System is M912 ver:1.4 mobo with DX4-120 CPU
My hardware:
Then something is hogging IRQ2 , I can see your motherboard is so called "Deep Green / "True" Green" - is there an ACPI option or something? If there is then turn it OFF since ACPI is hard-wired to IRQ2.
Else just fiddle with your BIOS settings, see if anything uses IRQ2 and change that or reserve it for "Legacy ISA" usage. You just need to find out what uses IRQ2 and either disable it or make it use another IRQ.
Any of these cards left? I'd be interested in getting one if there is. Nifty work Keropi.
^ sorry none left atm... just wait for the next fresh batch 😉
wrote:Then something is hogging IRQ2 , I can see your motherboard is so called "Deep Green / "True" Green" - is there an ACPI option or something? If there is then turn it OFF since ACPI is hard-wired to IRQ2.
Deep Green means present of "green mode" button on mobo. I don't know what he did and newer use it. Also in bios on this mobo not acpi support and any type of IRQ and DMA allocation. I think about change this mobo.
My hardware:
Most likely that "green mode" is hardwired to IRQ2 - that's why it is occupied and the MPU does not work ... I don't see a jumper option to completely disable it so maybe the solution is indeed another mobo - or use another IRQ for mpu but there is a chance some old game is expecting to find IRQ2 and thus it won't work...
Hello,
Apparently I'm late again for your cards, are there any plans for another batch?
