EtherDFS - a network drive for DOS
Reply 140 of 151, by Oerg866
I once attempted to implement such a thing, but it turns out that this file naming behavior is oddly difficult to replicate 🤪
Reply 141 of 151, by ltning
Oerg866 wrote on 2025-03-25, 08:35:
Maybe steal some code from DOSBox? Or the Linux or BSD msdosfs implementations? At least the former has to actually construct correct 8.3 FAT entries with LFNs from whichever underlying filesystem you have. And the msdosfs code needs to do the same whenever you attempt to create new files:
FreeBSD sys/fs/msdosfs/msdosfs_conv.c (direct link to the unix2dosfn() function)
I have no idea if it's possible, "easy", or how to adapt this to etherdfs so .. I'm sorry I can't help more :(
The Floppy Museum - on a floppy, on a 286: http://floppy.museum
286-24/4MB/ET4kW32/GUS+SBPro2
386DX-40/20MB/CL5434 ISA/GUSExtreme
486BL-100/32MB/ET4kW32p VLB/GUSPnP/AWELegacy
~ love over gold ~
Reply 142 of 151, by Oerg866
ltning wrote on 2025-04-03, 11:20:
I had a look at this and the problem I'm facing is that the generation number is an *input* to this function; I do not know how to generate it, nor can I find a definitive spec on how to do so...
Reply 143 of 151, by ltning
Oerg866 wrote on 2025-05-13, 01:41:
I vaguely recall discussing this with someone a long time ago, and (with the danger of sounding completely clueless) I think the approach was to call that function, check if the result already exists in the virtual directory, and call it again with an incremented number if it does.
Whether that is what FreeBSD is actually doing, I don't know..
Thanks for your efforts on this!
/Eirik
~ love over gold ~
Reply 144 of 151, by superfury
Isn't it just an increasing number based on the alphabetical sorting of the list? And only added if multiple identical matches are found or the filename is too long (past 8 characters)?
UniPCemu Git repository
Reply 145 of 151, by Oerg866
superfury wrote on 2025-05-13, 09:26:
Sadly it is not that simple :\ For example, if you have two files:
Invoice Frank.docx
Invoice Peter.docx
You'd have these two:
INVOIC~1.DOC
INVOIC~2.DOC
But, if you then delete Invoice Frank.docx, to my knowledge, Invoice Peter.docx will still translate to INVOIC~2.DOC, even though there is only one file left.
I'd essentially have to implement a little FAT database that keeps track of every single file ever created, renamed, deleted, etc., which gets messy very quickly :\
Reply 146 of 151, by superfury
Oerg866 wrote on 2025-05-18, 11:32:
Sadly it is not that simple :\ For example, if you have two files: […]
Invoice Frank.docx
Invoice Peter.docx
INVOIC~1.DOC
INVOIC~2.DOC
Hmmm... Can't you simply enforce FAT32 (or VFAT?) drives being used in Linux for mounted folders and request the short filename path from the driver?
https://github.com/torvalds/linux/blob/master … at/namei_vfat.c
Reply 147 of 151, by Oerg866
Obviously, but who wants to force themselves to format their archival hard drives to FAT32? I certainly don't 😜
Reply 148 of 151, by javispedro1
In vboxsf , what I do is that long filenames are shortened to a 4 letter prefix, a ~, and a 3 letter hash of the long name, plus the extension. E.g. LONG~20B.TXT .
This way you ensure that there are no file name conflicts (because it is unlikely that multiple long file names with the same prefix resolve to the same hash, but if this is really a problem you can also increase the number of digits dedicated to the hash) , and that the short filenames do not change if you reboot or remove other unrelated files from the directory (the hash is the same as long the actual long filename does not change).
Note that both the idea and implementation actually come from https://github.com/eduardocasino/vmsmount .
Reply 149 of 151, by mkarcher
superfury wrote on 2025-05-18, 12:04:
Oerg866 wrote on 2025-05-18, 12:38:
In the case you use a modern Linux filesystem, the short names can be stored in extended attributes instead.
Reply 150 of 151, by Marco
Dear author of etherDFS,
Is there maybe now any plan to publish ethsrv for openwrt platform ? I would assume this could spread usage as lot of people might use openwrt router to connect their retro machines?
PS: posted similar question for mtcp netdrive
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 151 of 151, by digger
I have a bug report. I'm not sure if it was mentioned before, but if a directory on a Linux partition (say, ext4) contains an executable in ALL_UPPER_CASE, such as BIN.EXE, and that directory is served up with `ethersrv` lin Linux and then mounted in DOS with EtherDFS, then that file will be listed when you type DIR, but it won't be found when you actually try to run or otherwise access it ("bad command or file name"). If you rename the file to lower case (bin.exe), then suddenly the file is accessible from DOS.
Thanks enormously for this tool, though! It's being very useful for a retro software project I'm working on.
