Reply 140 of 353, by darry
darry wrote on 2020-06-19, 04:10:Did some more tests with the OSSC (in pass-through mode) together with the CP-254 . I could not get 1152x864 @60Hz or 70Hz, whatever I tried (I started with proper VESA timings in Powerstrip and matched the in the OSSC), but always get no picture .
1024x768@60Hz and at 70Hz do work, but I lose about 2 pixels on the left size if I follow VESA timings to a T . This also happens in DOS (720x400), but is on the left side instead . In either case, playing with sync, porch and active pixels lets me move the image sideways and switch the cutoff from side to side but not increase the horizontal image size . (maybe I'm doing it wrong, though). My guess is that the CP-254 masks some lines .
I added an HDMI switch to the output of the OSSC . One side goes to CP-254 for when I need proper aspect in DOS at 70Hz . The other side goes directly to my main HDMI switch, so I can get all 4:3 modes in Windows without going to through the CP-254 . I now have an even bigger mess of HDMI cables and increased need for manipulation when switching modes, but I am as close to perfection as I can get with available equipment .
The masking effect I mentioned causes me to lose about 5 pixels out of 640 on the X axis, so 2.5 actually 2.5 out of 320 , which I can live with for now .
Of course, I do have a powered Startech 2-way VGA splitter(rated at 350MHz bandwidth), so I could always add my Extron DVI300 to the mix and get DOS modes with proper sampling, proper scaling and no masking but at 60Hz . Or I can wait for OSSC Pro.
So many options and cables, so few power outlets and no perfect solution, yet.
EDIT : Ordered a new monitor Philips 252B9), which might make the OSSC alone enough to get "perfect" results. See Re: Widescreen monitors and 4:3 aspect ratio compatibility thread
