Project: Full Can Clock Oscillator Replacement
Reply 140 of 141, by feipoa
Ya, 120 MHz is bootable, but when pressed, usually falis. You might be able to get 117 Mhz stable on a BL3, but probably at 3x39 MHz, and with a peltier.
In heinsight, we probably should have made 120 Mhz the upper limit on the clock gen module, rather than 110 MHz. But alas, I doubt few people are going to try running a BL3 at 2x57 or 2x60 MHz.
I've had a few case buttons go bad - power, reset, or turbo bottons. It resuts in sporatic behaviour, resets, etc.
Reply 141 of 141, by wiretap
Yeah.. I'm not sure why people are adverse to using level shifting for a proper design. But then again I'm sure the people/AI doing the design don't have any engineering background so they don't know it is important for stability or to prevent IC damage.
My Github
Circuit Board Repair Manuals
