DOSBox-X branch
Reply 1420 of 2428, by AnnaWu
yksoft1 wrote:
I've found another one. Photo Genic by Sunsoft […]
TheGreatCodeholio wrote:
The PC-98 port of "Marble madness" appears to be one (and so far only that I've found) game on the PC-98 platform that uses INT 33h
Nice find, yksoft1!
Anna's Playground for QMC2
Official MESS Forum
Reply 1421 of 2428, by hail-to-the-ryzen
Interesting work on the adaptation for the extender. Would it be simpler to turn off opengl in configure instead of the batch script? If this is true, then these lines would be moved to below where C_OPENGL is detected in configure.ac.
+dnl HX DOS build.
+case "$host" in
+ *-*-cygwin* | *-*-mingw32*)
+ if test x$enable_hx == xyes; then
+ CXXFLAGS="$CXXFLAGS -DHX_DOS"
+ AC_DEFINE(C_HX_DOS,1)
+ AC_DEFINE(C_OPENGL,0)
+ fi
+esac
Reply 1422 of 2428, by TheGreatCodeholio
Nah, I did it at the build script level instead, which works for me.
DOSBox-X project: more emulation better accuracy.
DOSLIB and DOSLIB2: Learn how to tinker and hack hardware and software from DOS.
Reply 1423 of 2428, by hail-to-the-ryzen
My suggestion doesn't work anyways. 🙁 The opengl library is linked to and the related code is still parsed.
I tried your hxdos build and it works great. Is it necessary in your testing to shorten the dosbox-x configuration filename to 8.3 format?
Reply 1424 of 2428, by TheGreatCodeholio
I will need to shorten the configuration filename, yes. Haven't done that yet.
"YKsoft" on twitter recommends dosbox.ini because the configuration file is very INI like.
Reply 1425 of 2428, by hail-to-the-ryzen
Something like this?
diff -rupN dosbox-1//src/gui/sdl_gui.cpp dosbox-//src/gui/sdl_gui.cpp
@@ -494,7 +494,11 @@ public:
ToplevelWindow(parent, x, y, 400, 150, title) {
new GUI::Label(this, 5, 10, "Enter filename for configuration file:");
name = new GUI::Input(this, 5, 30, 350);
+#ifndef HX_DOS
name->setText("dosbox.conf");
+#else
+ name->setText("dosbox.cnf");
+#endif
(new GUI::Button(this, 120, 70, "Cancel", 70))->addActionHandler(this);
(new GUI::Button(this, 210, 70, "OK", 70))->addActionHandler(this);
diff -rupN dosbox-1//src/gui/sdlmain.cpp dosbox-2//src/gui/sdlmain.cpp
@@ -139,7 +139,11 @@ extern char** environ;
#define STDOUT_FILE TEXT("stdout.txt")
#define STDERR_FILE TEXT("stderr.txt")
-#define DEFAULT_CONFIG_FILE "/dosbox.conf"
+#ifndef HX_DOS
+# define DEFAULT_CONFIG_FILE "/dosbox.conf"
+#else
+# define DEFAULT_CONFIG_FILE "/dosbox.cnf"
+#endif
#elif defined(MACOSX)
#define DEFAULT_CONFIG_FILE "/Library/Preferences/DOSBox Preferences"
#else /*linux freebsd*/
@@ -2032,7 +2036,11 @@ static void printconfiglocation() {
static void eraseconfigfile() {
+#ifndef HX_DOS
FILE* f = fopen("dosbox.conf","r");
+#else
+ FILE* f = fopen("dosbox.cnf","r");
+#endif
if(f) {
fclose(f);
show_warning("Warning: dosbox.conf exists in current working directory.\nThis will override the configuration file at runtime.\n");
@@ -2049,7 +2057,11 @@ static void eraseconfigfile() {
static void erasemapperfile() {
+#ifndef HX_DOS
FILE* g = fopen("dosbox.conf","r");
+#else
+ FILE* g = fopen("dosbox.cnf","r");
+#endif
if(g) {
fclose(g);
show_warning("Warning: dosbox.conf exists in current working directory.\nKeymapping might not be properly reset.\n"
@@ -2233,8 +2245,11 @@ int main(int argc, char* argv[]) {
// if none found => parse localdir conf
+#ifndef HX_DOS
if(!control->configfiles.size()) control->ParseConfigFile("dosbox.conf");
+#else
+ if(!control->configfiles.size()) control->ParseConfigFile("dosbox.cnf");
Show last 17 lines
+#endif
// if none found => parse userlevel conf
if(!control->configfiles.size()) {
config_file.clear();
diff -rupN dosbox-1//src/misc/programs.cpp dosbox-2//src/misc/programs.cpp
@@ -379,7 +379,11 @@ void CONFIG::Run(void) {
writeconf(pvars[0], false);
} else {
// -wcp without parameter: write dosbox.conf to startup directory
+#ifndef HX_DOS
if (control->configfiles.size()) writeconf(std::string("dosbox.conf"), false);
+#else
+ if (control->configfiles.size()) writeconf(std::string("dosbox.cnf"), false);
+#endif
else WriteOut(MSG_Get("PROGRAM_CONFIG_NOCONFIGFILE"));
break;
Reply 1426 of 2428, by hail-to-the-ryzen
If the sdl_net static library is missing a getadaptersinfo function, then it may help to add a library to Makefile.am in /dosbox-x/src/: LIBS += -liphlpapi.
Reply 1427 of 2428, by yksoft1
My nickname is always in all lowercase letters.
In fact, according to my test even with the menu code and SDL subwindow code intact, Dosbox-X is still working in HX DOS extender only that the SDL window is not in the middle of screen.
Reply 1428 of 2428, by yksoft1
Nice find, yksoft1!
By the way this game requires 5MHz GDC clock.
Reply 1430 of 2428, by hail-to-the-ryzen
RE: Move DIB window parent shutdown to SQL_Quit.
I can't decide whether the above commit to fix window focus outweighs the loss of opengl context. 😀
Reply 1431 of 2428, by TheGreatCodeholio
When I made that commit, there was code in DOSBox-X still that liked to shutdown and restart SDL's video subsystem (for reasons that may have something to do with historical SDL 1.x bugs, I guess). Waiting until SDL_Quit to shut down the parent window prevents the parent window from flickering on the screen for each time that is done.
On Windows, doing that would sometimes cause Windows to restore the window behind another application, whenever output=opengl, which is annoying.
I had a similar problem on Linux where if output=opengl, any change including bringing up the mapper would cause the X11 window manager to move the window to the upper left hand corner, no matter how many times I moved it back, which was also annoying.
Reply 1432 of 2428, by hail-to-the-ryzen
In my case, the sdl12 async code is leading to the lost window focus, too, but it occurs with other output modes (sdl_driver is windib). I confirmed that your no-async code patch fixes it.
I think the SDL_Quit commit also affects the opengl context, although I haven't tested it again.
Reply 1433 of 2428, by hail-to-the-ryzen
Misspelled word in bios_disk.h:
 	imageDiskMemory(diskGeo floppyGeometry);
- imageDiskMemory(imageDisk* underylingImage);
+ imageDiskMemory(imageDisk* underlyingImage);
virtual ~imageDiskMemory();
Reply 1434 of 2428, by hail-to-the-ryzen
I think that you once had a question about centering the window (example in Windows):
set SDL_VIDEO_WINDOW_POS=center
set SDL_VIDEO_CENTERED=1
start /B dosbox-x
Reply 1435 of 2428, by hail-to-the-ryzen
For get_key() in bios_keyboard, the PC98 key counter function is written as available in regular PCs?
unsigned char b = real_readw(0,0x528);
if (b != 0) real_writew(0,0x528,b-1);
Reply 1436 of 2428, by TheGreatCodeholio
Not that I'm aware of...
If there is, it's not widely used on the IBM PC platform.
On PC-98 however, implementing the counter is vital because some games and even MS-DOS itself depends on the counter to sense keyboard input.
Reply 1437 of 2428, by hail-to-the-ryzen
The reintroduction of the dynamic core may have led to some of the reported errors in dos 32-bit games. The page handler is different, for example. At least they could reproduce any issue with core=normal.
Also, I've been testing your new debugging code and data views in the console. Is there a general guide for which a data view should be selected?
Reply 1438 of 2428, by TheGreatCodeholio
You generally want the default "segmented" view provided by the "D" command.
However "DV" (virtual view) and "DP" (physical view) permit alternate ways to view memory in the system.
To summarize:
D seg:off segmented view
DV offset virtual view (linear memory address subject to paging)
DP offset physical view (physical memory address on the bus, not subject to paging)
Reply 1439 of 2428, by hail-to-the-ryzen
Thanks for the help. I tried to set a breakpoint to the problematic segment:offset location, but the process of debugging with a breakpoint led the page fault error to another location. The original page fault type in kernel32 seems to be from running out of stack memory, possibly from an infinite looping in the game code.
I can't decide if it is simpler to reconstruct the program flow or instead to just invent a time machine and ask the developers to redo their sound code. 😀
