Reply 1540 of 1540, by SquallStrife
- l33t
FWIW... The current Linux drivers 7.35.0 work on kernel 7.0.0. Officially on -14, but I'm using them on -43 perfectly fine. The sample app, which is basically "Vision Window for Linux" has been updated for Qt6, and builds+runs perfectly fine in TYOOL 2026. No more ancient kernels and libraries needed.
My E2S has died though. I found an inexpensive one of those "199A" cards, waiting for it to arrive. When it does, I will finish off and publish my native OBS source plugin that "speaks EasyRGB" and lets you perform all your tweaks right there in OBS, with capture profiles and everything. So far, handles resolution changes like a boss, super snappy, super low latency. Few bugs still, but will work through them once I have a working datapath card again.
