Reply 1580 of 2491, by Falcosoft
- l33t
Roland User wrote on 2024-01-06, 13:30:This not hard ) but I think , if all other resets work without other syx files , then and MT-32 must work if speach about default mode MT-32 )
Why? This sound rather academic from your side since in practice there is no difference at all. FSMP cannot work properly without its folders anyway and with its folders it works perfectly this way. And since the whole package is portable there is no disadvantage to use FSMP the way it is designed to use.
BTW, no all other resets work without SysEx files only the ones that have special handling mode integrated into FSMP ( that is known default instruments, banks, default controllers etc.) As I said before FSMP has no special MT-32 mode currently.
