What modern activity did you get up to today?
Reply 1580 of 1618, by darry
Nexxen wrote on 2026-03-28, 02:40:
darry wrote on 2026-03-28, 01:39:
Bought 16GB of DDR4 3200 for 169.99 CAN$ before taxes, for a friend's no longer delayable PC upgrade. Hint: Old CPU is Xeon e5450 on a P35 board.
Not so long ago it would have been 69,99.
Well, P35... it was really about time 😀
69.99$ ? Ipaid about that for 2x16GB DDR4 3200 a little while back.
The Xeon build is on its last legs. Only the PSU, GPU and SSDs/HDDs will get reused. It had a good run. I would have switched it to NVME for the SSDs, but with the prices these days, nope, unless it is really absolutely necessary.
Reply 1581 of 1618, by Standard Def Steve
I upscaled my iCarly DVDs to 8K resolution at 120 fps, then encoded the resulting video frames losslessly. Oh, and I remixed the audio to Dolby Atmos...after upsampling it to 32 bits and 384 KHz with a little help from X-Fi Cyrstalizer.
The file size per episode is now approximately 30 times greater than the original DVDs, the WiFi is barely fast enough to sustain the required data rate, and the 3D glasses need to be recharged every four episodes, but my word. This is the definitive way to watch iCarly. The show's sharp wit, masterful storytelling, and breathtaking cinematography have all--I feel--been amplified to a new level of glorificnessness that truly threatens to alter one's psyche and mystify the dog.
"A little sign-in here, a touch of WiFi there..."
Reply 1582 of 1618, by cyclone3d
Finishing cleaning the water loop on my main rig. Noticed a month or so ago that the water was getting nasty and that temps seemed a bit high / the fans were ramping up way more than seemed normal.
Started last night.
Also replaced 2 of the 3 fans on my video card last night as they were going out. Ordered fans probably 2.5 months ago and just hadn't had the time to mess with it till now.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1583 of 1618, by lti
I tried to fix the WiFi on one of my desktops. Since it's a desktop, the best fix is to wire the house for Ethernet, but I don't want to live in this town for much longer. This is going to turn into a long Linux rant.
The problem is that EndeavourOS has random disconnects, and dmesg is flooded with "missed beacons" warnings. However, Ubuntu 24.04 and the latest Fedora running live don't have any problems. It has been that way for a few months, but I haven't tried to fix it until the weather started warming up and the new "upgrade" Ryzen is heating the room up too much (with integrated graphics). I looked around, and it seems like the only troubleshooting step for Intel WiFi is to set an option called 11n_disable, which is extremely poorly documented. The only documentation I can find is a single-line comment in the source code and a couple of forum posts from people who figured its function out on their own. Based on the name, the implication is that it will force my nice modern WiFi card to 802.11g, which is not a legitimate solution at all. If the driver is that broken, just say that. Even if you ignore the fact that a driver for modern hardware is potentially so broken that it can't handle a 20-year-old networking standard or any newer standards, why does this only happen in one distro and not others?
Anyway, I tried setting 11n_disable to 8, and it didn't help. I don't want to try 1 (the choices are 0, 1, 2, and 8 for some reason) since that's the choice that fully disables the ability to connect using any standard newer than 802.11g. I have no idea what's in EndeavourOS that's different and triggering this, and all troubleshooting threads I've found die after setting that option.
Also, I'm trying to get a Windows 11 VM to update to 24H2 (even though 25H2 is actively being rolled out). My VM ran out of disk space, and failing to install due to insufficient disk space causes Windows Update to redownload the entire update again, fail again, and download again in an infinite loop on my DSL Internet. Then when I freed up enough space to install, it gave me error 0x8024a22a and tried to download again. Why does everyone assume that you have infinitely fast Internet? Even 1Gbps isn't good enough for them. I've mentioned how bloated AMD/Xilinx dev tools are (such as the power estimator turning from an Excel spreadsheet into a full application that's a 9GB download), but that VM has MPLAB installed, and its folder in Program Files is 10GB just to program little microcontrollers. I'm going to uninstall that since I have no desire to do any kind of programming anymore (and if I did, there are Linux tools that don't need the VM).
Reply 1584 of 1618, by 386SX
These days I tried to fix my i3-12100 config with its Intel Arc 310 ECO using a different PWM fan controller instead of the video card one. Basically the known problems of this card is that the heatsink is seriously too thin and small to dissipate a 2Ghz GPU and the ridicolous fan used has to work so much to keep it cool enough making huge noise and so variable it'd easily drive any user crazy.
So I used a Corsair Commander XT to drive the GPU fan and deciding a better fan curve cause it's not possible to do that on Linux drivers with video card driver itself. Of course it was not enough for the noise but more stable speed for sure. Then I downclocked the video card @ 50% and now the card should ask for 20W instead of 31W before and the fan noise seems at least a bit acceptable.
Reply 1585 of 1618, by UCyborg
Compiled Pale Moon for the second time from source on Windows...at least I hope it built, will see tomorrow. No idea what Frankenstein did actually come out, was fighting with the build system to use the old MS build tools that still produce Win7 compatible binaries and since Git submodules are alien to me along with the fact that I didn't change from the master branch...
Arthur Schopenhauer wrote:
A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
Reply 1586 of 1618, by wierd_w
I engaged in the time-old tradition of contacting a major equipment maker's support line, getting the runaround from lv1 support, then fruitlessly repeating the same troubleshooting I already did with their factory service manual, before finally being blessed with a factory service rep appointment to replace a toast component.
It sure would be nice to be able not waste a bunch of time when these things happen. I understand that the lengthy process exists to catch the most usual modes of failure, but really. Asking me to access the device's web interface when the nvram board is bad (which is what stores the configuration data of the device, including its ip address), seems a bit much.
How do I know its actually bad, actually bad?
The device does not respond to magic buttons to enter service/diagnostic mode. The device does not give a link light when connected to a switch. The USB port is physically damaged.
Need I go on?
Xerox support felt I did. 😁
Reply 1587 of 1618, by BitWrangler
Lots of "fun" yesterday. Trying to get a schoolwork machine going for a tween. First candidate, turned out to have an HM70 chipset not an HM77 so remains stuck with dog dog slow celeron... have a decent i5 on hand which should have been four times faster, but nope won't go in there and stay on for longer than 30 mins due to chipset douchebaggery.
Second candidate, went on a shelf working last year... now won't boot, won't show post screen, it was grinding it's optical drive at first though. Tried it with bootable USB and it never flicked the light on once, so IDK if it's even trying. So Asus NV56V. Turn on, screen black, some optical drive grinding, then nothing, screen stays black for 20 mins plus. Tried the old, battery out, hold down the power button trick, didn't help.
Some folks are saying that it uses it's BIOS chip for NVRAM and every time there's a settings change it has a chance of pooching the write and needing the BIOS recovered/fixed. Does that sound likely to anyone? Not something I have heard of before. I don't want to spend all day trying to screw around with that if it won't fix it. Also it seems like a bit of a pain in the ass trying to get the BIOS into it, because first off ASUS only distributes 6MB worth of BIOS code, leaving 2MB in the chip unflashed, and that bit is meant to be where the problem occurs, if it's not a bad BIOS update, but an NVRAM snafu. So apparently you have to read it, go hunting for the screwed up bits, flip them, then write the whole mess back. This is with a CH341A serial eeprom tool and 8 pin test clip.
Does this sound promising given description of symptoms and model? Sounds a bit on the legend/voodoo side where I am finding randoms discussing it. Like they heard of a guy who heard of a guy who's brother's co workers cousin definitely fixed his laptop like this brah.
Reply 1588 of 1618, by wierd_w
I just applied new, silver-bearing compound to one of the laptops at work because it was idling at 80C.
Found 500% more compound than is correct or proper under the conduction pad/bar.
Cleaned all that 'bukkake party' gunk off, and applied the actually correct 'just enough to fully spread over the die' ammount of silver bearing.
Idles at 75C. *STILL HITS 99C* under load.
There are no dust bunnies.
the grille is clean.
the fan is not noisy or stiff, turns freely.
HP clearly just put an underwhelming thermal pipe assembly on this laptop for reasons only their marketing department comprehends.
Why is this the world we live in?
Reply 1589 of 1618, by lti
Marketing demands that it's thin and silent.
At least it isn't the Dell Precision 7670, where the undersized heatsink (the size you would have seen on a C2D with integrated graphics, but now expected to cool a high-end modern CPU and GPU with a combined 200W power limit) also has one of its two fans blocked by the right hinge. You can even see through the bottom vents that only one fan ever gets dirty. That isn't a marketing mistake. I also saw a review of the larger 7770 that claimed that the CPU was being overvolted.
You can't switch suppliers either because they all suck. Lenovo is using liquid metal on their equivalent P series ThinkPads (and there's some claim that Lenovo computers all have bundled Chinese nation-state level spyware, but nobody can ever cite a source), HP computers have been unstable since they bought Compaq (but they're probably better than Dell at this point), nobody does custom-spec builds anymore, and the three standard configurations that are available are complete nonsense that nobody in their right mind would ever intentionally choose. Also, a lot of that idle heat comes from IT management software and Windows itself. I don't know what Windows is doing, but even on home machines, the CPU will be bouncing off the power limit (complete with the added noise, heat, and reduced battery life) while Task Manager shows zero CPU usage, even when you switch to the per-core chart. I've seen the simple act of having OneDrive enabled (and failing to sync as usual) increase idle power consumption by 40W on a laptop.
Reply 1590 of 1618, by UCyborg
Yay, trouble with the bank again. They can't keep the old shit that (barely) works, gotta make new one. All for "security" I presume. But it all ends in user frustration rather than added security.
The old phone will no longer do for the bank app. Back then, you could initiate the activation process yourself to activate new device. Now you have to write them or call them to get codes.
And it failed on two devices I tried, other being a Samsung tablet with stock everything. Can't get more mainstream than that.
Reply 1591 of 1618, by BitWrangler
Actually I avoid Samsung because they think they're Apple, can do what they like, mess too much with the stock Android platform, end up incompatible.
Reply 1592 of 1618, by dr_st
BitWrangler wrote on 2026-04-13, 21:31:
Really? Would you say Samsung diverged more than others from stock Android? How does it manifest?
I've owned Android phones from Asus (Zenfone) and Xiaomi (Poco, Redmi) and have also used some Google, LG, Samsung solutions. They have all seemed to be quite different from one another on the UI level, although most of the platform core was similar (when accounting for the different OS generations).
Reply 1593 of 1618, by BitWrangler
It's a bunch of little things that drive you nuts, below the UI, can't cite current specifics as past experiences keep me away from them, it's has the same kind of feel as IBM trying to be IBM compatible circa 1988 to 1998. Mostly shows up in interactions with other devices, I am sure casting works perfect with a Samsung TV, contact sharing works perfect between Samsung phones etc. Starts to smell of deliberate vendor lock in.
Reply 1594 of 1618, by wierd_w
The hardware is often well supported by AOSP builds, like LineageOS.
Banking aps can sometimes *complain* that the bootloader is unlocked, even though the OS that's running is lighter, cleaner, and with a lower contact footprint, and thus demonatrably safer to use.
Aside from that foible, I have had decent luck with reloaded flagship hardware.
I'm currently running an old Pixel4A with LineageOS. I still get updates this way, abd google's hentai tentacles are denied.
Reply 1595 of 1618, by UCyborg
The Samsung tablet is my brother's, he rarely uses it, it was a gratis he got with the phone. They have their annoyances, no doubt. Samsung wants you to have their account, I figured when adding myself as a user that you can bypass it by not connecting to the Wi-Fi, something we didn't think of when setting it up for my brother.
My phones tend to be rooted, though so far, there was always a way around it with my bank's app. Unihertz's ROMs appear very close to AOSP.
Not sure what's going on now, either they're busy or really want me to call them before they'll send another code.. They said so when I replied through email, though I tried contacting them again through the form you get when logged in (where I initially sent the request).
Reply 1596 of 1618, by UCyborg
I got another code from the bank and could activate the app on the tablet.
Something's screwed on my phone though, Aurora Store shows all apps I try to view in Play Store as not available for the device. And back to all crosses when it comes to Play Integrity bullshit.
I hate Google.
Reply 1597 of 1618, by UCyborg
I hate Subversion too. Gotta pay special attention when there are conflicts when merging. I think I missed Continue merging button in TortoiseSVN again so not all changes were merged and no information about how many lines were changed...bleh, this shit is easier with (Tortoise)Git, it doesn't let you just miss random changes. If only Git could be taught to update the (stupid) svn:mergeinfo property on SVN properly.
Reply 1598 of 1618, by 386SX
These days built a new home computer with spare second hand components an Intel i7-3770 with 24GB DDR3, SSD SATA3 and testing a nice new 2D only video card supported by linux based on the AST2400 PCIEX1 (internally bridged from PCI I think) video chip. When using instead the Intel integrated graphic 4000 iGPU, the system is quite powerful even nowdays and runs incredibly well, feels having less latency times than the i3-12100 when using some better video card. The 2D video card runs quite well at 1080p but modern o.s. use OpenGL also for the GUI and if not found it use the OpenGL software renderer that on modern GUIs feels really heavier than needed.
Reply 1599 of 1618, by VanillaFairy
Not sure if it entirely counts, but I did some drawing today with my Wacom tablet on my daily-driver running Fedora KDE w/ AeroThemePlasma!
...I also accidentally updated my laptop's Alpine Linux install. Turns out setting it to latest-available instead of a specific version's repos probably isn't the best idea-
Just a silly lil person in a very big world.
