EGA Graphics card beeps
Reply 160 of 165, by mkarcher
butjer1010 wrote on 2025-07-23, 19:32:
So i did my fist try, hope it is ok. pin 1/244 to pin 1/pal pin 5/244 to pin 11/pal pin 10/244 to pin 10/pal pin 18/244 t […]
pin 18/244 to pin 11/pal
pin 20/244 to pin 20/pal
Will not connect until You gave me Your "blessing" 😀
Hope You can see on picture every wire i have solder.
OK, this will not work as is, but it wont damage anything as well. First, you have a typo in your description. Pin 18 of the 244 is connected to pin 13 of the PAL, not pin 11.
The supply voltage connections are fine: Pin 10 and Pin 20 copied from the PAL to the 74LS244 is perfect. Also, applying the enable signal to pin 1 is fine. But this enables these four buffers: Pin 2 to 18, pin 4 to 16, pin 6 to 14 and pin 8 to 12. You connected pin 18 to PAL pin 13. This is fine: pin 18 is a buffer output pin of a buffer that is controlled by pin 1. But that buffer takes it input on pin 2, not on pin 5! Actually, pin 5 is an output pin of a different buffer. You thus need to move the wire that connects pin 11/pal to pin 5/244 to pin2/244. Everything else looks fine.
Reply 161 of 165, by butjer1010
mkarcher wrote on 2025-07-23, 21:35:
Yes, i did a typo, it is connected to pin 13/pal, not 11. I did make a change from 5 to 2, and now is ready to try it 😀
Will let You know of the results
Reply 162 of 165, by butjer1010
Yesss! it works perfectly!!!!
Now just to see if this GAL is ok, i will order it, and sometimes when i will have enough time, i will try to program it with this file deunan sent me, and see if that works either. If not, i can always revert to this state!
Need to find brightness potentiometer for this monitor, and IO bracket for this graphics card, and my 2nd EGA PC is done 😀
Thanks to all geniuses here, i don't know how much i can thank You enough!!!!
Reply 163 of 165, by butjer1010
butjer1010 wrote on 2025-07-23, 17:39:
As You said, it is in list of my T48 (ATF16V8B) https://www.ebay.com/itm/226559768634?_skw=AT … ABk9SR-iO54WHZg https://www.ebay […]
Deunan wrote on 2025-07-23, 17:02:
Before you buy make sure it's a type supported by your programmer. That's why I suggested ATF16V8B - I know this one works because I've used them myself.
As for F and LS series, both will work but F is meant for much higher switching speeds. It will draw more power, run hotter - this might matter if you place this new chip close to existing ones. It can also inject more noise into power rails if you don't put a capacitor nearby. I would prefer LS, ALS, or maybe a more modern HCT or ACT would be good enough for this as well.
https://www.ebay.com/itm/204789149078?_skw=AT … ABk9SR96wh4aHZg
Hope those ones are ok?
Ok, than F is out 😀
I have found GAL16V8D-25QP-LATTICE in one local shop, so it could arrive next day if this one is ok. I have it in T48 database, but is it ok for this job?
Thanks
I still didn't get answer if those 2 are ok. Should i order one of them to program it?
Reply 164 of 165, by Deunan
Yes, those will work, provided the chips are not fake or damaged somehow.
Reply 165 of 165, by butjer1010
Deunan wrote on Yesterday, 19:28:
Thanks man, that's way i search in Europe, not China (hope for the best).
Will order one right....
