Reply 160 of 924, by Ydee
- Oldbie
shevalier wrote on 2025-10-12, 15:54:Can you run this benchmark on Sempron? 2GHz Sempron Palermo can post the results in Linpack. Same conditions: Hypertransport - a […]
Ydee wrote on 2025-10-12, 15:48:shevalier wrote on 2025-10-10, 06:13:That would be great. I wonder how smoothly it would work with Windows 98. Of course, with something like the X600/800 or PCX5700 […]
Of course, with something like the X600/800 or PCX5700.
If everything works well, it's the ultimate solution.
The Socket 754 multiplier increases the frequency from 800 to 2.4 GHz, or three times. (And this is without even changing the frequency of Hypertransport.)
256/512 MB DDR1 modules are also quite affordable.
It still amazes me that all retro gamers want the K6-3/P3S and not the S754.With GF 7600GS TOP (factory oced with clock like GT version) and X700SE (really crippled version not only on shaders and ROPs, but even memory bus too) are results on AMD 760G (aka 780) and SB710:
Same conditions: Hypertransport - as close to 800MHz as possible, RAM - 200MHz, 3-3-3-8 CR2.
Re: Battle of the platforms: socket 754!
Oh, boy - unfortunately, no, because I only have room for one more machine at the table and the choice fell to MSI K8N Neo with AGP port and Turion. AMD chipset does not allow emulation of SB16 on Audigy, while nForce3 on MSI does - so winner is clear. I already sold it.
Ozzuneoj wrote on 2025-10-12, 18:23:Ydee wrote on 2025-10-12, 15:48:shevalier wrote on 2025-10-10, 06:13:That would be great. I wonder how smoothly it would work with Windows 98. Of course, with something like the X600/800 or PCX5700 […]
Nice! Can you run the same test on the HD3000 IGP? It'd need to be run under XP, since there are no 9x drivers for it, but I'd be really interested to see the results if you have time. Also maybe running the GPUs again in XP would be good too for a more like-for-like comparison to the IGP.
Dtto, but IIRC, integrated HD3200 achieved a score of about 9,000 in 3DM2001 at stock frequency and S64 2800+.
