Dos 6 conventional memory tricks
Reply 160 of 302, by dr_st
tayyare wrote:
Don't we need to add first, one of the "NOEMS" or "RAM" keys into EMM386.EXE command line, in order to load anything to upper memory area?
Yes, we do. In this case, it is obvious that it was forgotten and that is the reason no upper memory blocks were created.
Reply 161 of 302, by jmdlcar
Here what happen. NOEMS I got error #06 and RAM the Computer just rebooted. My Dell Laptop was built in 2008 and it has 4GB of Ram.
Reply 163 of 302, by jmdlcar
dr_st wrote:
Try removing the HIGHSCAN. Just leave DEVICE=EMM386.EXE RAM
That is what I did,
Reply 164 of 302, by elianda
No, that is expected if you have e.g. a rather modern graphics card with a higher BIOS ROM footprint.
NOEMS disables EMS emulation and makes a 64 kB area available, typically at E000 that is used as page frame for the EMS emulation.
So you get 64 kB more UMA that can be converted to UMBs. However you don't have EMS functionality available anymore for programs that use it.
Classic VGA cards have a BIOS ROM footprint of 24 kB to 32 kB.
Youtube Channel
Reply 165 of 302, by jmdlcar
I can tell you I am lost here @70 my mind is slow today at that age but I need still need help.
Reply 166 of 302, by jmdlcar
Well I guest I will have to live what I have.
Reply 167 of 302, by jmdlcar
Will my problem is my Computer I change to an Acer aspire one and now it shows this. Sorry the way it look
Modules using memory below 1 MB: […]
Name Total = Conventional + Upper Memory
MSDOS 16,125 (16K) 16,125 (16K) 0 (0K)
HIMEM 1,120 (1K) 1,120 (1K) 0 (0K)
EMM386 4,144 (4K) 4,144 (4K) 0 (0K)
COMMAND 2,928 (3K) 2,928 (3K) 0 (0K)
MOUSE 17,296 (17K) 17,296 (17K) 0 (0K)
SETVER 512 (1K) 0 (0K) 512 (1K)
SMARTDRV 29,024 (28K) 0 (0K) 29,024 (28K)
Free 648,448 (633K) 613,616 (599K) 34,832 (34K)
Memory Summary:
Type of Memory Total = Used + Free
Conventional 655,360 41,744 613,616
Upper 64,368 29,536 34,832
Reserved 393,216 393,216 0
Extended (XMS) 65,995,920 2,409,616 63,586,304
Total memory 67,108,864 2,874,112 64,234,752
Total under 1 MB 719,728 71,280 648,448
Largest executable program size 613,520 (599K)
Largest free upper memory block 34,736 (34K)
MS-DOS is resident in the high memory area.
I know the mouse didn't load high but I am not sure what else should.
There no CD in this Laptop.
CONFIG.SYS
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF DEVICE=C:\DOS\EMM386.EXE NOEMS DOS=HIGH,UMB FILES=30 BUFFERS=20 LASTDRIVE=Z DEVICEHIGH=C:\D […]
DOS=HIGH,UMB
FILES=30
BUFFERS=20
LASTDRIVE=Z
DEVICEHIGH=C:\DOS\SETVER.EXE
rem DEVICEHIGH=C:\DOS\DISPLAY.SYS CON=(EGA,,2)
rem DEVICEHIGH=C:\DRIVER\OAKCDROM.SYS /D:MSCD001
AUTOEXEC.BAT
@ECHO OFF LH C:\DOS\SMARTDRV.EXE 2048 128 rem LH C:\DOS\MSCDEX.EXE /D:MSCD001 /L:D LH C:\MOUSE\MOUSE.COM /Y PATH C:\;C:\DOS;C:\ […]
@ECHO OFF
PATH C:\;C:\DOS;C:\NC;C:\PKWARE;C:\WORKS;C:\QB;C:\WORD
PROMPT $p$g
SET TEMP=C:\TEMP\
rem SET SOUND=C:\SB16
rem SET BLASTER=A220 I5 D1 H5 P330 T6
rem SET MIDI=SYNTH:1 MAP:G
rem LH C:\SB16\DIAGNOSE /S
rem LH C:\SB16\SB16SET /P
Reply 168 of 302, by oeuvre
Try this
CONFIG.SYS
SWITCHES /F
DOS=HIGH,UMB
DEVICE=C:\DOS\HIMEM.SYS /Q /TESTMEM:OFF /NUMHANDLES=128
DEVICE=C:\DOS\EMM386.EXE RAM I=B000-B7FF AUTO NOTR
BUFFERS=11,0
FILES=50
LASTDRIVE=F
I like using VIDE-CDD.SYS instead of OAKCDROM.SYS and substitute MSCDEX with SHSUCDX
Leave AUTOEXEC.BAT the way it is. Which mouse driver are you using? I would use ctmouse http://cutemouse.sourceforge.net/
Reply 169 of 302, by OldCat
Oooh, I like this thread. Marked for future reference.
Reply 170 of 302, by 0kool
Hey guys, I've been using QEMM on my main DOS/3.11 machine (P133, 16RAM, VIRGE DX and non-PnP SB16) with various success for some time now, but decided to go the classy way. I understand that a single config can't run 'em all, but so far I'm mostly happy with it. Two issues - unable to start NFS SE DOS installer (works in DOSBox) and Adlib Tracker freezes ("page fault") the PC on track load every other boot.
Did I messed something up memory-wise? Is there anything I could have done better? I'm particularly attached to msmouse, mscdex, oakcdrom and NC, so those are untouchables.
AUTOEXEC.BAT
@ECHO OFF SET SOUND=C:\DRIVERS\SB16 SET BLASTER=A220 I7 D1 H5 P330 T6 SET MIDI=SYNTH:1 MAP:E C:\DRIVERS\SB16\DIAGNOSE /S C:\DRIV […]
@ECHO OFF
C:\DRIVERS\SB16\MIXERSET /P /Q
C:\DOS\EMM386.EXE AUTO
LH C:\DOS\MSCDEX.EXE /S /D:MSCD000 /l:D
SET MOUSE=C:\DRIVERS\MOUSE
LH C:\DRIVERS\MOUSE\MOUSE.COM /Y
PATH C:\WINDOWS;C:\DOS;C:\NC;
PROMPT $p$g
SET TEMP=C:\TEMP
SET TMP=C:\TEMP
LH C:\DRIVERS\VGA\XMODE.EXE MONITOR
LH C:\NC\NC.EXE
CONFIG.SYS
SWITCHES /F DOS=HIGH,UMB BUFFERS=11,0 FILES=60 LASTDRIVE=D FCBS=4,0 STACKS=9,256 DEVICE=C:\DOS\HIMEM.SYS /Q /TESTMEM:OFF /NUMHAN […]
SWITCHES /F
DOS=HIGH,UMB
BUFFERS=11,0
FILES=60
LASTDRIVE=D
FCBS=4,0
STACKS=9,256
DEVICE=C:\DOS\EMM386.EXE I=B000-B7FF RAM AUTO NOTR
DEVICEHIGH=C:\DRIVERS\SB16\DRV\CSP.SYS /UNIT=0 /BLASTER=A:220
DEVICEHIGH=C:\DRIVERS\CDROM\OAKCDROM.SYS /D:MSCD000
DEVICEHIGH=C:\WINDOWS\IFSHLP.SYS
SHELL=C:\COMMAND.COM C:\ /P
MEMORY
conventional - used 60,528 - free 594,832
upper - used 96,288 - free 29,520
Reply 171 of 302, by dr_st
Quick suggestions:
Remove the BUFFERS= and FCBS= lines (no reason to mess with the defaults typically).
Use CTMOUSE instead of MOUSE and VIDE-CDD instead of OAKCDROM (shouldn't affect stability but use substantially less RAM).
No need to run EMM386 from AUTOEXEC.
What does XMODE.EXE do and why do you need it?
Remove /S switch for MSCDEX unless you really need to share your CDROM drive via WfWg servers, and add /E (to use EMS, and less normal RAM)
Reply 172 of 302, by 0kool
Thanks dr_st! I readjusted the files according to your advice and will consider swapping my oakcdrom driver for the acer one later.
As for XMODE.EXE - 3.11 Virge DX driver I've got from vogonsdrivers only gives me 60 hertz in Windows (with any resolution/color depth). So I'm using a tool from Diamond Stealth 3D 2000 package to make it 85. Strange, with Virge GX, 3.11 and the exact same monitor on the other machine everything was fine with just an appropriate driver.
Reply 173 of 302, by dr_st
I assume you are using a CRT monitor? For most LCDs anything over 60Hz is useless and only makes things worse.
Also, LASTDRIVE=D? I assume it means you have a single hard drive partition and a single CD-ROM drive and don't plan on expanding it? I am not sure if any programs may have issues with this (like, trying to create a temporary 'virtual drive'). Maybe you can at least make it LASTDRIVE=E so you have more room (this will not use so much extra memory).
Reply 174 of 302, by 0kool
I do 😀
dr_st wrote:
LASTDRIVE=D
Single CD-ROM and partition. I just like for everything to be tight. Ok, let's make it E, with them theoretical virtual drives and all.
Reply 175 of 302, by Baoran
Bit newer Athlon64 pc and I am trying to see if I can get dos to work with reasonable amount of conventional memory. Basically something is using 64Kb at E000. When trying to get ems working by default settings emm386 ram auto, it can't find any place in upper memory for page frame segment base. Checkit marks those 64Kb at E000 as hi ram and UMBINFO just says it is RAM and refuses to view it. I=E000-EFFF makes floppy drive stop working in dos which I assume is the dma thing. Frame=E000 works, but gives a warning about detecting RAM or ROM there, but floppy drive works and I have EMS. No idea what kind of issues this might cause while actually running games.
I left the like as:
DEVICE=C:\DOS\EMM386.EXE RAM AUTO FRAME=E000 I=B000-B7FF
I left is as that because that was the only way to get reasonably good amount of conventional memory with ems, cd driver and mouse driver. I think I have about 584Kb of conventional memory with that setting.
Anyone has any idea of better way because I have no idea what kind of problems that Frame address at E000 can cause?
Reply 176 of 302, by oeuvre
Post the rest of your CONFIG.SYS and AUTOEXEC.BAT
Reply 177 of 302, by Baoran
Sure, but I didn't think they mattered because, there was nothing special about them. Just trying to get sound, mouse and optical drive working while having enough conventional memory. Main problem is where I should put the frame with emm386.exe.
I just don't think I could do anythin in bios either that would free some memory in UMA.
config.sys:
DEVICE=C:\DOS\HIMEMX.EXE /MAX=65536
DEVICE=C:\DOS\EMM386.EXE RAM auto highscan FRAME=E000 I=B000-B7FF
BUFFERS=15,0
FILES=40
DOS=HIGH,UMB
LASTDRIVE=I
FCBS=4,0
DEVICEHIGH=C:\DOS\CD1.SYS /D:OPTDRV
Autoexec.bat:
@echo off
path c:\;C:\dos
c:\dos\ctmouse.exe
MODE CON CODEPAGE SELECT=850
LH /L:1,20448 keyb su,,C:\dos\keyboard.sys
C:\YAMAHA\SETUPDS.EXE /S
SET BLASTER=A220 I5 D1 T4
LH /L:2,28032 MSCDEX /D:OPTDRV /L:G
Reply 178 of 302, by Baoran
I just tested a bit and having Frame=E000 causes crashes when running dos games. It looks like having ems in dos is bit impossible with this motherboard unless there is something else I can do.
Reply 179 of 302, by elianda
You already wrote this. Since you noticed that Floppy does not support DMA any more when E000 is included then DMA when attributed as page frame won't work as well.
Usually DMA stops working if the UMB is generated by Shadow RAM when the mainboard does not support DMA from Shadow RAM or if UMB is generated from XMS regions where no DMA is possible. For ISA DMA generally there is a 16 MB limit. I don't know how HIMEMX provides XMS to EMM386 to generate UMBs, but the /MAX=65536 indicated that you enable more than 16 MB. Now if the XMS that is provided by HIMEMX to be mapped at E000 for virtual EMS is from an area beyond 16 MB physical it could be the source of non working DMA.
Youtube Channel
