Reply 160 of 470, by carlostex
- l33t
Well the fuse map addresses match the code inside the JED file. If you edit the file you'll see "L0000","L0256" and so on with these having sets of binary. So i just manually wrote the fuse map according to the file. Programmed the GAL put it in the card and system now booted with no crashes or visual artifacts.
Loaded the driver and it detected it. Loaded up inertia player and MOD files were playing nicely. Tried some games and absolutely no sound, no CMS no AdLib no Soundblaster.
