Reply 160 of 379, by 1541
Will MBF work with Romero's SI6IL MOD/WAD?
https://www.romerogames.ie/si6il
Yes, it runs great! 😉
THE NIGHTLAND is my board + video game for Commodore 64.
Hi!
Just for the heck of it I ported some changes made to Libretro-PrBoom to MBF to properly support Sigil and it works like a charm (at least on dosbox).
Thanks! What wasn't working before that is fixed with this patch?
wrote:Thanks! What wasn't working before that is fixed with this patch?
with my release you can use the main sigil.wad and it will appear as a 5th episode, no need to use sigil_compat.wad and replace inferno.
you have to use an ultimate doom iwad for it to work though.
So looks like same-species infighting (which can be achieved in vanilla DOOM by the simple DeHackEd patch below is broken in MBF (and BOOM as well)? Somehow I only now noticed it.
Does it look like something that can be easily fixed / achieved by other means?
Patch File for DeHackEd v3.0# Note: Use the pound sign ('#') to start comment lines.Doom version = 19Patch format = 6Misc 0Monsters Infight = 221
Bah.
After verifying that the infighting DeHackEd patch support works in PrBoom+, I partially ported the following PrBoom commit to MBF, complete with the comments crediting original author "e6y" (only the changes related to monsters_infight, not the others):
https://github.com/coelckers/prboom-plus/comm … 78c9a6066711506
Same-species infighting appears to work perfectly now with the patch above.
In the attached ZIP are the 4 changed files and a .DIFF file.
@gerwin
Do you mind picking up this change?
How about bumping the version number? There have been quite a few changes since 2014, and we are still at 2.04.
I will pick up the change, seems like a fun option to tinker with the infighting. Thanks for the efforts.
Last time I changed the version number from 2.03 to 2.04 there appeared to be checks for demo and save files: They did not work properly since they expected to read 2.03. So I rather just keep that version as it is now, to prevent problems, then use the build date as an actual sub-version of 2.04.
@dr_st Thanks for the heads up, I also integrated that change into my fork.
@gerwin feel free to use my changes to support sigil. I just did it to see if I could make sigil run as a proper 5th episode under dos (as it should be) and as it worked pretty well I decided to publish it.
https://github.com/Sakitoshi/mbf_sigil
wrote:@dr_st Thanks for the heads up, I also integrated that change into my fork.
I just tried this version on real hardware, and all I get is a black screen after the initial loading. This happens on DOS 6.22 with a k6-2 and with a 486 dx4. This happens on all versions from 2.04-sigil1 through 2.04-sigil4.
Unpatched MBF 2.04 runs fine. 😒
@echo $bio
wrote:I just tried this version on real hardware, and all I get is a black screen after the initial loading. This happens on DOS 6.22 with a k6-2 and with a 486 dx4. This happens on all versions from 2.04-sigil1 through 2.04-sigil4.
I tested on dosbox and a real pentium 3 866mhz running windows me and dos 7.1.
it works flawless on all of the tested systems (although I can only make the music work under dos, the sound blaster pci 128 is weird).
the changes I made aren't severe and shouldn't interfere if you play base doom or doom 2.
EDIT: try deleting MBF.CFG to reset the settings.
wrote:I tested on dosbox and a real pentium 3 866mhz running windows me and dos 7.1. it works flawless on all of the tested systems (a […]
it works flawless on all of the tested systems (although I can only make the music work under dos, the sound blaster pci 128 is weird).the changes I made aren't severe and shouldn't interfere if you play base doom or doom 2.
Even after extracting all files into a new folder, deleting MBF.CFG and copying DOOM2.WAD I still get a black screen, this was also tested on Windows 98.
I understand that it's a small patch and that it should work, but the older version loads fine so I don't know what could be causing it.
@echo $bio
wrote:Even after extracting all files into a new folder, deleting MBF.CFG and copying DOOM2.WAD I still get a black screen, this was also tested on Windows 98.
Are you sure you are using the correct Doom WAD? (Ultimate Doom WAD which should be named "doomu.wad", according to the batch file included) You mention using "DOOM2.WAD".
@ Sakitoshi: Just tested the SIGIL MBF version and it runs fine on my real hardware (AMD K6). Thanks for the compatibility update! However, I'm just wondering why you have decided to use the old Allegro Sound System setup/config. Did you use an older version of MBF as well?
Also, would it be possible to have the correct demo level shown at startup? Now the demo plays on a map of SIGIL, which of course leads to nothing good 😉 If it's up to me, the SIGIL splash screen also should not show as default, since we're adding extra maps to the original version.
wrote:@ Sakitoshi: Just tested the SIGIL MBF version and it runs fine on my real hardware (AMD K6). Thanks for the compatibility update! However, I'm just wondering why you have decided to use the old Allegro Sound System setup/config. Did you use an older version of MBF as well?
I decided to use allegro setup again because I think that it works better with the version of allegro I have to compile it (for some reason I was getting adlib sound and music no matter how I changed the settings). maybe I was doing something wrong, but what's done is done.
sigil title screen and demos shows up because that's how it's supposed to work, sigil.wad contains title screen and demo lumps, so of course the ultimate doom title and demos are going to be replaced by sigil's. now, I know the demos are desyncing, but so they are in every source port I've seen (and in vanilla doom 1.9 too).
if you want to get the ultimate doom title screen and all that you'll need to open sigil.wad with slade and delete those lumps.
wrote:I decided to use allegro setup again because I think that it works better with the version of allegro I have to compile it (for some reason I was getting adlib sound and music no matter how I changed the settings). maybe I was doing something wrong, but what's done is done.
My MBF 2.04 work was about the sound drivers to a large extend. These reside in the Allegro 3 library. So Doom MBF 2.04 is supposed to be compiled with this modified Allegro. The necessary files are included in the packages. Also precompiled ones.
The MBF 2.04 setup program mirrors this work and is matched to this modified Allegro.
Besides that I had best results with a 1997 DJGPP compiler setup. Further details can be found in earlier posts in this very topic.
so I was doing something wrong.
well, I don't think I'm going to change it back, is good enough for me and I'm too lazy to do it.
The D4V gameplay mod (DOOM 4 VANILLA v2.2) exits with error while playing map06 with DIGMID wavetable music driver. Did not yet detect this issue with other midi based songs. One solution is to convert the MIDI lump to a MUS formatted lump file.
Have not yet determined the cause in the code, but the other MIDI drivers work fine so far. One possibility is the tick based timing in the midi file and its compatibility with the DIGMID driver or the ability of the DIGMID driver to send output to MBF.
wrote:so I was doing something wrong.
hi , i've downloaded your "sigil" MBF version and it runs super fine , the problems i've found so far are :
1- Plutonia Map 07 softlocks after killing the enemies on the first part of the level (after you kill the first monsters the door should automatically open and this is not happening)
2- It's cool to be able to play Eviternity on dosbox, the only problem is that maps 15, 31 and 32 wont load , idclev or -warp will crash the game giving a "segmentation violation" error
i was also able to run mutiny with your latest mbf version =) .
wrote:hi , i've downloaded your "sigil" MBF version and it runs super fine , the problems i've found so far are : […]
well, I don't think I'm going to change it back, is good enough for me and I'm too lazy to do it.hi , i've downloaded your "sigil" MBF version and it runs super fine , the problems i've found so far are :
2- It's cool to be able to play Eviternity on dosbox, the only problem is that maps 15, 31 and 32 wont load , idclev or -warp will crash the game giving a "segmentation violation" errori was also able to run mutiny with your latest mbf version =) .
thanks for the heads up. just published the fix for level 7.
I accidentally broke tag 666 and 667 while implementing the master levels behavior.
regarding eviternity, I believe that the seg faults are due to the sheer size of that wad. it's just too much for dos mbf to take. maybe there is a way to fix it, but I lack the knowledge.
wrote:thanks for the heads up. just published the fix for level 7. I accidentally broke tag 666 and 667 while implementing the master […]
I accidentally broke tag 666 and 667 while implementing the master levels behavior.regarding eviternity, I believe that the seg faults are due to the sheer size of that wad. it's just too much for dos mbf to take. maybe there is a way to fix it, I lack the knowledge.
Wow that was a fast fix, thank you , now it's working as intended =) .
according to zennode , map 15/31/32 blockmaps are too big (actual error message "Level too big to create valid blockmap") , but i think it's ok , this wad was not meat to be played on an ms-dos port.
I'll do a much intense test tomorrow
