Reply 160 of 188, by DracoNihil
HunterZ wrote:
Looks like BASSMIDI has a Linux library too. Interesting that nobody uses FluidSynth on Windows or BASSMIDI on Linux.
I guess it would be best for people to pour effort into FluidSynth then.
Because BASS is proprietary and the last time I tried to get BASSMIDISynth (kode54's work) to run, it would absolutely refuse to open the sound device unless I terminated PulseAudio and gave it direct access to the DAC.
Looking into the issue this has been a huge problem with BASS for a long ass time and it's really stupid how BASS has no native PulseAudio support considering a ton of idiot-proof Linux distro's use it as the sound server... BASS refuses to even open a audio context even if you point it to the "pulse" ALSA device where as every other program under the sun that uses ALSA can run under PulseAudio via it's ALSA plugin...
You Linux guys can give PulseAudio all the BS whining you want, but it's unfortunately here to stay. Stop making up excuses and actually write code to use it natively.
― Κυνικός Δράκων
Reply 161 of 188, by HunterZ
I went through the exact same thing with Wine a few years ago. By the time they got it sorted (if they ever really did), I had ended my Linux gaming experiment and went back to Windows.
Reply 162 of 188, by gdjacobs
There were ways around that issue using the OSS proxy daemon. Still, a real pain in the ass. And Pulseaudio still sucks.
Reply 163 of 188, by HunterZ
It doesn't suck bad enough to be worth disabling, except when using digital passthrough.
Reply 164 of 188, by autoexecdotbat
Synth font does support both sf2 and dls.
to win the game you must defeat coppa!
http://chng.it/DNc2L8LvLJ
Reply 165 of 188, by deemster
Just noticed I didn't even add my Creative Wave Blaster 1 soundfont yet, although it is the soundfont I am the most proud of.
It is called Wave Blaster Archive, and it was my third attempt at sampling my Creative Wave Blaster 1 (CT1900) sound card. It turned out pretty large (more than gig), but sounds very much like the real thing.
A few samples using game midis: https://www.youtube.com/playlist?list=PLxDnrs … b9OioeVHD7VI3Vk
Download: http://1drv.ms/u/s!Ap-0SHCYq2AljA-sG1e4WBtrd989
Reply 166 of 188, by autoexecdotbat
BTW, would anyone be interested in doing a yamaha tg100 soundfont? I've become rather interested in it ever since I learned it uses the same chip as the Sega Saturn.
Reply 167 of 188, by gdjacobs
Is the TG100 GM compliant?
Reply 169 of 188, by autoexecdotbat
I knew it was gm complient since it was quite popular as a gm module in Japan.
Reply 170 of 188, by Atomic Skull
deemster wrote:
- Make the DB50XG soundfont actually XG compatible
This is not actually possible. You can't really emulate a DB50XG with just a soundfont, XG is way more than just a sound map. You'd have to emulate the ADSR envelope the resonant filter and the effects blocks as well otherwise XG MIDIs would not sound correct. The really good XG MIDI's make extensive use of these features (that's why most really good XG MIDIs have a huge block of SYSEX at the beginning). In fact most XG MIDIs composed for eg. an MU100 or MU2000 don't sound right on a DB50XG either because of the additional effects blocks that were added to the XG spec over the years. The effects blocks are why XG MIDIs have such good guitar sounds, there are effects presets for simulating a guitar amp that you can run the "dry" guitar samples though.
I've long wished that the Yamaha MU2000EX would be emulated (I mean an actual hardware emulation) like how the MT32 was. That's the only way you can get "real" XG emulation (or with a softsynth that fully supports the XG spec)
Reply 171 of 188, by Danfun64
Sorry for bump, but it appears that links are down (at least the SC-55 one is).
Also, I'm curious how these are made (I E if everything was made from scratch or actually using Roland/Yamaha/Creative's copyrighted material). Also, you never put a license on these, yet the SC-55 one has been included in the GPL GZDoom. Of course, it appears that Deemster hasn't been here in more than a year, but was permission given or something?
Reply 172 of 188, by GiSWiG
Go to this post Soundfonts that mimic old hardware (SC-55, DX50XG, AWE64 Gold) and click the 'deemster soundfonts' link
Steamer/GOG-er: ASUS Crosshair IV Formula | AMD Phenom II X6 1100T 3.7GHz all cores | Mushkin 8GB DDR3 RAM 1333 w/ 6-6-6-18 1T | Dual AMD Radeon HD 6850s in CrossFireX | X-Fi Titanium | Dual-boot Windows XP and Vista
Reply 173 of 188, by Danfun64
Sorry for the very late reply, but none of my other questions were answered.
Reply 174 of 188, by mmontag
Same here.
Hardware emulation seems pretty farfetched, but maybe you could get close just by implementing all the effects blocks in a MIDI synth.
Then again, how many MIDIs were ever composed for the MU1000/2000? How can it really be enjoyed?
When pushed to its limit, XG MIDI almost takes on the character of a tracker/DAW format. Which is cool if you ask me, since it's an open standard.
https://chiptune.app
Reply 175 of 188, by Un Information
Sorry to bump an old thread, does anyone have the files OP uploaded? The links are dead.
Reply 179 of 188, by Retroit
deemster wrote on 2015-11-13, 16:58:
My main gripe with all sorts of soundfonts was their absurd size, as well as using a lot of instruments from other synths to mim […]
My main gripe with all sorts of soundfonts was their absurd size, as well as using a lot of instruments from other synths to mimic certain instruments. What you have here is four soundfonts for the purist who wants to get the classic sound out of their Sound Blaster card or softsynth.
Roland SC-55 Presets: http://onedrive.live.com/redir?resid=25 ... file%2csf2
Yamaha DX50XG Presets: http://onedrive.live.com/redir?resid=25 ... file%2csf2
AWE64 Gold Presets: http://onedrive.live.com/redir?resid=25 ... file%2csf2
AWE64 Gold FM Presets: http://onedrive.live.com/redir?resid=25 ... e%2csfpack (Shoutout to Zandro Reveille for recording the OPL3 GM samples)
The presets in above soundfonts are carefully programmed to sound like their hardware counterparts. Therefore the soundfonts will play your music in an organic way.
The first three soundfonts are under 4 mb, so they will fit on a stock AWE64 Gold.
But there is no need to use the Gold soundfonts on your AWE64 Gold anyways 🤣 , they are meant for people without an AWE card.
Keep in mind these things:
- The DB50XG soundfont is meant for General Midi playback
- You need SFPack to unpack the AWE64 Gold FM Presets soundfont
- The AWE64 Gold actually uses an OPL clone called CQM, but it's close enough
All these soundfonts are tested on the Bassmidi driver, but should work fine on any other soundfont-compatible synthesizer, software or hardware.
Please upload this presets on vogonsdrivers as they are not available any more. Thank you
