Reply 160 of 479, by Chkcpu
- Oldbie
chacha wrote on 2025-03-06, 22:45:Some good news ! […]
Some good news !
So, lets start:
- BIOS flash ran perfectly, using uniFlash, and it boots without issues then (and faster + bios has more options)
( I haven't tried bigger HDD yet)
- I finalized my undervolt motdto have exactly 2.2V, and while I was away I received my K6-IIE 400 (AFR).
- Installed, and with BF0/1 out => it boots at 233MHz ! Nice start !
- Then I tried to set multiplier to 2x because I am expecting this CPU to actually run at 6x if 2x set... no POST 😒
- I tried to pull-up in case it was the same problem as with the MMX CPU, no change.
- other configuration does work (underclock even more)
- Then I did the BF2 mod => short to ground
- TADA ! --==> CPU now runs at 5.5x 66 | 366MHz <===--I can see a very significant improvment in general performances, thats nice !
But as you probably can guess I'd like it to run at 400MHz 😀 .But I cannot figure out why it wont run at normal speed.
I tried other jumper configuration ,with BF2 shorted, and they all does work, so there is no pull up/ down issue.I thought it can be a VRM issue ... but 366MHz seems verry stable, I would expect 400MHz to at least POST.
And as its a linear voltage regulator, lowering the voltage might actually increase power dissipation (not sure how K6 regulate tho..). I added a bigger capacitor at the transistor output and it did not change anything.
I ordered a more recent replacement Transistor, in theory it should accept 4 more amps than this one.
I am tempted to try to feed this transistor with the PSU 3.3V instead of MB 5V to lower the voltage difference...Or maybe it has nothing to do with the hardware and this CPU just does not has the 2x => 6x feature ?
I will receive the K6-III+ 400ATZ, I hope that one will work.
I expect it to be stronger, in particular because it should be able to cache the whole RAM, but also it should require less current.If anyone has idea on how to achieve 400MHz... I am ready for trials 😀
I dont think it can be BIOS related at that stage isn't it ?
Hello chacha,
Great to hear that the Unicore BIOS for the 8500TVX works. 😀
From your CPU-Z picture I see that the K6-2/400 is definitely one with the improved CXT core and supports the x2 -> x6 multiplier remap. You can test this by setting the K6-2 to 360MHz (60 x 6).
The 03/16/2000 BIOS does support the K6-2CXT at x6, so I it is very likely that the 400MHz non-POST issue is due to the VRM limitation.
If so, then a K6-2+ or K6-III+ should work at 400MHz because of its lower power consumption.
I will keep my fingers crossed. 😉
Cheers, Jan
