The Changeling 3dfx Voodoo 5 5500
Reply 160 of 168, by Marmes
Where can I get this card? I have a couple of never used 320 VSA waiting for being populated.
Reply 161 of 168, by Dolenc
At the bottom of the first post is a link to Antonys fb page and you can ask him.
Reply 162 of 168, by Dolenc
Mdk done!
This game with its wild artstyle really is something, on a huge monitor even with low-res assets it just looks amazing.
The attachment glide_20260906_211813.png is no longer available
All the games in this batch are patched, also resolved an issue with Turok where reflections were black, and Ignitions flickering of 2d elements.
Now for Diablo II, I can only test the early section, since I havent progressed further in the game, tried to cover everything and lets hope there are no more merchants that are handled differently further on 😀.
Added 800x600-equivalent resolutions in 16:9, 16:10 and 21:9 , 1064x600 for 16:9, 960x600 for 16:10, 1400x600 for 21:9. This allows the same pixel size as the game expects it. While it will also work with other, higher resolutions, the world will get smaller and there will be artifacts on the borders and other things breaking in the game, so best to stick to the x600 height. I saw that other patches use 1068x600 for its 16:9, but that resolution wont work with the Voodoo.
The attachment glide_20260829_233242.png is no longer available
Some games wont have their main menu scaled, some do.
All the patches, that are built in the driver, will be located in GameFixes class. If someone wants to do it, they can be made to patch the .exe directly and it will work with a wrapper like nGlide.
A bit of testing and that I upload/write everything and it goes into the wild!
Reply 163 of 168, by Dolenc
3dfx Wide driver v1.5
The attachment IMG_20260819_091312.jpg is no longer available
Voodoo4/5 Wide Driver
Version 1.5
Voodoo Series Driver Kit: 1.0
Voodoo Series Win9x 2D/3D Display Drivers: 4.13.01.0028
Glide 2.X Driver: 1.00.01.0107 (glide2->glide3 wrapper)
Glide 3.X Driver: 3.10.00.40408 (Glide sourceForge project)
OpenGL Driver Version: MesaFx 7.4.4.0 (v0.76) (OpenGL ICD)
Release Notes
Version 1.5
- Game Ignition fix, that caused flickering of UI elements and eventually locked-up.
- Game Turok fix, reflections on the water were black.
- Added 640x480 and 800x600 equivalent resolutions for other aspect ratios
- 768x480, 1144x480, 960x600, 1064x600, 1400x600
- Widescreen patches for games
- Gta 2 (v10.3)
- Turok (Retail, not 3dfx rush version)
- Ignition (3dfx patch ver2 and ver3)
- MDK (retail + 3dfx patch + nocd)
- Driver (Retail + 2.1 patch + 2.1 fix)
- Diablo II retail + LOD expansion + patch v1.13d
- Additional HOR+ patched .exe for Aliens vs Predator Gold
Whats new?
2 bugfixes, additional x480 and x600 resolutions.
The main thing being additional widescreen patches for the games listed above!
You must match the version of the game to the patch or it wont work!!!
In the driver there is now a folder "WidescreenPatches", where you can get per-game information and additional files if needed.
Most games will work just from setting the Override resolution in the driver control panel. But some need additional setup.
For example Gta2 will require setting the resolution to 800x600, editing the resolution for the game in the registry and adding the .ini file next to the exe.
For some games there is an additional "wideDriver.ini", where you can tweak additional settings, like HUD scale and similar.
For Diablo II, I havent progressed that far into the game to see if it works everywhere, so fingers crossed!
You can get the driver here
Github Links
3dfx_Wide_driver_98
MesaFx-7.4.4
Glide sourceforge
GlideXp glide2->glide3 wrapper
Reply 164 of 168, by Dolenc
Made a small update, removed the 120hz refresh cap in the driver, always thought that was a windows98 thing, but it was a limit in the 3dfx16vs.drv (also your monitor .inf must support it).
And since Im playing Diablo II a bit, updated the patch, mostly fixes for higher than x600 height resolutions, also videos are now upscaled fullscreen +bilinear, attacks/abilities are now moved further to the center, not anchored to the sides.
I wont make a new release, but you can always get the latest version if you download from the 3dfx_Wide_driver_98 repo.
The attachment glide_20260915_082819_2.png is no longer available
Reply 165 of 168, by Radeux
Dolenc wrote on 2026-09-15, 21:24:
Made a small update, removed the 120hz refresh cap in the driver, always thought that was a windows98 thing, but it was a limit […]
Where's your guitar Dolenc? Because you absolutely rock sir!
I think my Pentium 4 and Voodoo 4 rig needs a go at this! Gotta get a ram patched Win98/ME going again.
I made an x3dfx Discord finally, if you or anyone else wants to join I'm sure the discussions, gaming, and networking opportunities will be plentiful. Linked your github there as well.
https://discord.gg/JEPu3ubzF
Reply 166 of 168, by Dolenc
Im not really a community guy, but Ill make a patch here or there 😜
Think I caught everything Diablo II has, when going over x600 height resolutions, updated the files. Im at act 5, so I guess no more surprises.
Have to say, while Im not a fan of farming-loot-slot games, some parts of it is good enough that I kept returning to it. And act5 is reallly nice.
The attachment glide_20260922_223806.jpg is no longer available
I also checked Diablo 1, which atmosphere is really nice and since I played the demo "back in the day" it instantly clicked with me.
I used Devilution (without the X) which is a reverse-engineering of the original game (and since its matching the file size of the original, guess they did a good job). Just added widescreen and compiled it so it runs on win98.
The attachment screen04.png is no longer available
As far as a read, DevilutionX, so original with improvements, has plans to add 9x support and that would be a better option, but if anyone wants it I can upload the build somewhere.
I think Ill use 1400x600 for the playthrough, just a bit more in view, but still feels a bit clastrophobic.
The attachment screen00.png is no longer available
Reply 167 of 168, by Radeux
I gotta say I'm stoked about what you've done for Diablo and D2 here. Thankyou Dolenc, your work is a constant in conversation around the community! Did you upload your widescreen Diablo somewhere?
Reply 168 of 168, by Dolenc
Here, now its uploaded somewhere 😀
Diablo 1.09, build from Devilution (non-x), edit .ini with a custom resolution
Battllezone v1.4, .exe has the following resolutions 640x480, 1600x900, 1920x1080, 1680x720, 1920x800
