Reply 160 of 162, by rasz_pl
so about https://blog.theretroweb.com/2023/04/25/the-r … ing-volunteers/
readme.md appears slightly outdated. Debian 12 wouldnt work with php8.0. I had to (disclaimer, I dont know what Im doing, >10 years out of managing linux boxes):
-sudo apt install php8.0 php8.0-mbstring php8.0-dom php8.0-gd php8.0-intl php8.0-pgsql php8.0-xsl
+sudo apt install php8.2 php8.2-{mbstring,dom,gd,intl,pgsql,xsl}
+composer require symfony/stimulus-bundle
+yarn upgrade webpack@^5.0.0
\i database.pgsql generated some errors:
psql:database.pgsql:46218: ERROR:  insert or update on table "chip_image" violates foreign key constraint "fk_e3ead662df91ac92"
DETAIL: Key (creditor_id)=(6) is not present in table "creditor".
-yarn dev encore --watch
//doesnt work "Unknown command or entry 'encore'"
+yarn encore dev
//works, no idea if it does the business
-symfony serve -d --document-root=./
+symfony serve -d --document-root=./public
//only place with index.php
An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column m0_.slug does not exist
LINE 1: ...dited AS last_edited_4, m0_.max_cpu AS max_cpu_5, m0_.slug A...
debian:/var/www/ultimateretro$ grep -roaF .slug ./ |tail -n1
./migrations/Version20220506194008.php:.slug
cat ./migrations/Version20220506194008.php
        // this up() migration is auto-generated, please modify it to your needs
$this->addSql('ALTER TABLE motherboard ADD slug VARCHAR(80)');
psql:
SELECT column_name
FROM information_schema.columns
WHERE table_schema = 'public'
AND table_name = 'motherboard';
column_name | id
column_name | manufacturer_id
column_name | chipset_id
column_name | form_factor_id
column_name | video_chipset_id
column_name | max_video_ram_id
column_name | audio_chipset_id
column_name | name
column_name | dimensions
column_name | note
column_name | last_edited
column_name | max_cpu
"slug" column missing, /migrations arent being executed?
TLDR: cant bootstrap the repo as is by my own, I need some help.
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 161 of 162, by analog_programmer
evasive wrote on 2023-10-28, 20:23:
Ah yes, I checked my vogons notifications and I see I left off around July this year. […]
When I started to study for a few certificates as I had no project.
I may or may not have been more busy with trying to find something to pay the mortgage/food. My apologies.
I started again two weeks ago so now I have something to fend off the people asking for money.
Hi, evasive,
As far as I know you were the only one here to actively update theretroweb's database from info published in this and the other trw-thread. Since this thread will be locked, but "you're back", do you intend to continue this work based on posts in other (official??) trw-thread or there will be really no more vogons-forum-user-post's updates as declared in the first post here?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 162 of 162, by evasive
I am processing whatever was posted before the cutoff.
I think the post from the other admin member speaks for itself.
I really don't like the way things are going, apparently shots were fired and it came to this.
Evasive out.
