Reply 160 of 412, by betamax80
I've been in discussions with nop about this over DM - his 1.0.3 BIOS allows booting from a floppy image on the CH375 bus - and once booted as I understand it you can swap USB stick and access a different image on A:.
In theory, it may be possible to add a B: drive for a second image (would suit MS-DOS 5.0a) but I would also like to find a way to manage multiple images.
The upcoming PicoMEM board seems to be evaluating floppy disk management - there is a system that works with a daomon on a linux host (which could be a raspberry pi zero) out there online already which I think does work (on client side) under 8088.
