VOGONS Driver Library
Reply 1620 of 1673, by SquallStrife
SquallStrife wrote on 2025-04-04, 22:44:
I'm going to split large files into ~32MB volumes on the BBS, since I imagine the use case for the larger files is pretty limited on systems where BBS access is your /only/ option, and large downloads in volumes are kinda period correct anyway 🤣!
I've re-built the file database, including building a file_id.diz for each download. Searching is better than before, listings are much more readable, and adding files to the download queue won't crash your session.
Winning!
Reply 1621 of 1673, by Horun
douglar wrote on 2024-12-21, 17:00:
I found an old Public Domain Info Utility from 1992:
INFOPLUS Version 1.56
https://www.vogonsdrivers.com/getfile.php?fileid=2235
While searching for some old memory test apps ran into:
INFOPLUS
Version 1.57 Released to the public domain.
By Andrew Rossmann, 6/26/1993
added here: https://www.vogonsdrivers.com/getfile.php?fil … 9&menustate=0,0
Reply 1622 of 1673, by ruthan
Im trying to make MSI Afterburner old version collection to save it for future, but i cant find 2 first versions.
Version 1.1.0 (published on 01.10.2009)
Version 1.0.0 (published on 17.09.2009) - Initial version printed on CD, it probably means bundled with some videocard on cd.
I tortured Wayback machine as far as i could, maybe some has it offline or has better google fu than me..
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1623 of 1673, by TheMLGladiator
Started imaging and scanning some of my old driver/game floppies. Not sure what the best method of uploading them is, I scanned the floppies as .tif files and they are ~11MB each. These are all original disks (hopefully) unmodified.
  1. Generic VIDE-CDD driver disk:
    Has version 2.14 of vide-cdd.sys and a UDF reader program version 1.1. Disk is similar to this one: https://archive.org/details/cd-rewriter-dos-w … n-9x-nt4-driver, but is labeled with "CD-ROM DEVICE DRIVER" instead.
  2. GFC2204 FAST PCI Adapter driver disk:
    F=ma adapter diskette, dated 07-21-1999. Not sure if this is backed up anywhere else other than maybe driverguide.
  3. Gravis Firebird V1.0-01:
    Shipped with Gravis Firebird joystick
  4. Gravis Utilities
    I have 2 of these, both are identical and both lack the INSTALL.BAT I see most versions online came with. The disks most likely came with a Gravis PC Gamepad (which I still have) and a Gravis PC Pro Joystick (which I unfortunately no longer have).
  5. Linksys Ether16 LAN Card Instant Ethernet Series Program Disk
  6. Linksys EtherPCI LAN Card II Instant EtherFast Series Program Disk
  7. Linksys EtherPCI LAN Card II Instant Ethernet Series Program Disk
  8. Logitech MouseWare 7.0:
    MOUSE.EXE can be run without installing, I generally use this driver when CuteMouse doesn't work. Acceleration can be configured from the command line.
  9. Logitech MouseWare Lite 6.411
  10. Promise EIDE2300PLUS drivers 3.10A
  11. Promise Ultra66 drivers 1.42:
    2 identical disks of this one. Probably not super useful as the latest drivers are still hosted on promise.com
  12. Western Digital Ontrack Disk Manager 6.03 w Drive Rocket 1.1
  13. Western Digital Ontrack Disk Manager 6.03C
Reply 1624 of 1673, by douglar
TheMLGladiator wrote on 2025-05-08, 21:59:
Vogondrivers has some steep limits on the image sizes (limit 1MB, 800x800 pixels, jpg,png,gif) , so anything you post is going to get reduced. You can post the stuff here, or put it on archive.org and give a link.
Reply 1625 of 1673, by SquallStrife
Yep. The "image" on an entry is only meant to be illustrative. If you want to include high-res images (pictures) with your images (binaries), then chuck them together in a ZIP before uploading.
The system that enforces image sizes is pretty simplistic. I need to revisit it in the future.
Reply 1626 of 1673, by Horun
Hmm 15 floppies for 21Mb +/- plus 165Mb +/- for .tif images ??? seems a bit overkill 🤣
Reply 1627 of 1673, by TheMLGladiator
Horun wrote on 2025-05-12, 00:51:
For sure! 🤣 I figured that since I have a scanner that can do 600 dpi that I might as well scan at the highest quality.
Anyways, here is the link: https://archive.org/details/@mlgladiator
I'm still updating some of the metadata but the driver disks and scans should be there.
Reply 1628 of 1673, by Ozzuneoj
ruthan wrote on 2025-05-01, 04:54:
Im trying to make MSI Afterburner old version collection to save it for future, but i cant find 2 first versions. Version 1.1.0 […]
Not sure how hard this would be to find, but the driver CD for an MSI GTX 285 or 295 may be from that time period.
Edit: oops, I misread your dates and thought you meant January of 2009 for 1.1. Still, these cards or a GTX 275 may have ended up with that software eventually.
Reply 1630 of 1673, by Horun
Gona wrote on 2025-06-19, 19:01:
I have tried to upload WD90C31 disk images, but I got this: […]
Driver file OK.
Image file OK.
Driver file moving failed!
Hmm I do not see it. Try to upload it again.
Reply 1631 of 1673, by SquallStrife
Driver file OK.
Image file OK.
Shoot me a PM with the filename and stuff and I'll check it out. 😀
Reply 1632 of 1673, by ruthan
Hi, im looking for glView or Gl Extension viewer on of these versions: 2.2.8; 2.3.0, 2.3.2. 2.3.3 is someone have these stashed somewhere or he its able to find them on the internet.
Update: i found 2.32, on ex soviet sites as usually:
https://soft.sibnet.ru/soft/2368-opengl-exten … -2-32/download/
Reply 1633 of 1673, by ruthan
Other one, here is Virtual Fighter 2 demo is mentioned, some Setwin95 utility to patch game for Windows NT:
https://web.archive.org/web/20030629063433/ht … detail1670.html
Update: I found it on these ISO files, its really great that people keeps to add old gaming magazines cover cds on archive.org:
https://archive.org/details/pegasuswin95 // Here is just some additional documentation
Well it turns out that is directly on Windows NT CD - im not sure if even for every Service pack - its in SUPPORT\DEBUG\I386\ it even exists for MIPS,Alpha and PowerPC architectures.
Info:
https://web.archive.org/web/20010412103251/ht … s/setwin95.html
Reply 1634 of 1673, by SquallStrife
The issue Gona was facing has been resolved.
I have a number of the default php.ini settings changed from their defaults, to facilitate direct file uploads. Apparently I missed one of them when I moved to the new VPS. Whoopsie!
Reply 1635 of 1673, by tsahi
I would like to add to your drivers page... how can I do that ?
Reply 1636 of 1673, by douglar
You can post here and I can move them to. The site or you can real out to squallstrife directly
Reply 1638 of 1673, by Horun
Hmm maybe just a burp, seems to be working now.
Reply 1639 of 1673, by douglar
Horun wrote on 2025-07-21, 12:41:
Turns out it was malware bytes deciding that it must be bad news---
