VOGONS Driver Library
Reply 1660 of 1673, by Roman555
Hi,
I've found in my archive AMI BIOSes for Packard Bell Saturn mainboard MS-6309 v2.1 and 2.32 beta. I guess the former is listed on Theretroweb but the second is not.
I 'm not sure which hardware revision it is for but I suppose it is for rev 1.x.
The interesting fact is that v2.32 beta one has microcode for Tualatin cpuid 06b1 .
Maybe it can be useful. So I attached original file that make a bootable floppy and also the extracted ROM with its Ami flasher
binwalk Saturn.232
DECIMAL HEXADECIMAL DESCRIPTION
65705 0x100A9 Intel x86 or x64 microcode, sig 0x00000665, pf_mask 0x10, 1999-03-10, rev 0x0002, size 2048
67753 0x108A9 Intel x86 or x64 microcode, sig 0x00000665, pf_mask 0x10, 1999-05-05, rev 0x0003, size 2048
69801 0x110A9 Intel x86 or x64 microcode, sig 0x00000681, pf_mask 0x10, 1999-09-21, rev 0x0011, size 2048
71849 0x118A9 Intel x86 or x64 microcode, sig 0x00000683, pf_mask 0x10, 2000-01-10, rev 0x0010, size 2048
73897 0x120A9 Intel x86 or x64 microcode, sig 0x00000686, pf_mask 0x10, 2000-05-05, rev 0x0008, size 2048
75945 0x128A9 Intel x86 or x64 microcode, sig 0x0000068a, pf_mask 0x10, 2000-11-02, rev 0x0001, size 2048
77993 0x130A9 Intel x86 or x64 microcode, sig 0x00000683, pf_mask 0x10, 2001-02-06, rev 0x0014, size 2048
80041 0x138A9 Intel x86 or x64 microcode, sig 0x000006b1, pf_mask 0x10, 2001-02-15, rev 0x001c, size 2048
cat autoexec.bat
@ECHO OFF
:: NEC COMPUTERS INTERNATIONAL - PRODUCT SUPPORT & SERVICE PLANNING
:: 16:50 4-2-2002/TH
CLS
ECHO.
ECHO ********** NEC Computers International *********
ECHO ***************************
ECHO Packard Bell Saturn motherboard
ECHO XP Compliant BIOS version 2.32 BETA!
ECHO ********** NEC Computers International **********
ECHO.
ECHO.
ECHO.
ECHO This flash utility will automatically update your
ECHO Saturn motherboard BIOS to version 2.32.
ECHO.
ECHO IMPORTANT NOTE:
ECHO This version is not officially qualified, but tests
ECHO indicate it is fully functional and XP compliant.
ECHO This means that this BIOS version is not fully supported.
ECHO If you experience problems after using this BIOS,
ECHO Technical Support may ask you to revert your system to
ECHO the last version of the BIOS that is qualified and supported.
A:\CHOICE /N /C:YN Do you want to continue? [Y(es), N(o)]
ECHO.
IF ERRORLEVEL 2 GOTO CANCEL
CLS
ECHO Launching update program...
ECHO.
ECHO DO NOT POWER OFF YOUR SYSTEM DURING THE PROCESS!
ECHO.
a:\F826_14.EXE Saturn.232 /A
ECHO.
ECHO.
ECHO.
ECHO Finished.
ECHO.
ECHO ** Important:
ECHO ** Remove the diskette from the disk drive and restart your computer.
ECHO ** The computer MAY start with a CMOS CHECKSUM ERROR message.
ECHO ** This is just proof of a successful BIOS update and no cause for alarm.
ECHO ** Press F2 followed by F5 (ENTER) and F10 (ENTER) to save the new settings.
ECHO ** Your computer will restart again, and the new BIOS settings will take effect.
ECHO ** You may want to write down these instructions before restarting the computer.
ECHO.
GOTO END
:CANCEL
CLS
ECHO Update aborted by user.
ECHO Please remove the diskette from the disk drive and restart your computer.
ECHO.
GOTO END
:END
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 1661 of 1673, by Roman555
The latest (?) Packard Bell BIOS for MS-6159 (PB Suva)
Reply 1662 of 1673, by SquallStrife
xvertigox wrote on 2025-12-02, 19:00:
I'd be keen to mirror this site to provide a backup if there is an rsync daemon I could connect to. I am currently mirroring the idgames archive (it's the NZ mirror on the DW idgames frontend), the Quaddicted archive and a bunch more.
Lemme know if that's something you're interested in 😀
I've had this request a lot in my DMs.
Direct access like that is off the table, simply due to the cost of bandwidth. I've weighed it up many times over the years, but as much as I'd like to provide that (and other mechanisms like anonymous FTP), it's just not economically feasible.
That said, I upload a periodic snapshot to archive.org, and now's about the time I refresh it.
https://archive.org/details/vogons-drivers-snapshot-20260526
Reply 1663 of 1673, by SquallStrife
Update:
A while ago VogonsDrivers was being penalised in search engine rankings for not having an automatic SSL redirect. I set this up carefully, or so I thought, so old browsers would be happy too. Turns out I did it wrong, and vogonsdrivers.com was inaccessible from browsers with old TLS, or no SSL at all.
So I fixed it.
http://nossl.vogonsdrivers.com
As usual, let me know if there are any problems.
Reply 1664 of 1673, by TheMLGladiator
SquallStrife wrote on 2026-06-23, 11:57:
Update: […]
Update:
So I fixed it.
On an old browser, will the www.* redirect to nossl.* ? I know Macintosh Repository figured out a way to automatically disable SSL when browsed from an old browser without negatively affecting search engine rankings.
Reply 1665 of 1673, by tomasgal
Hello there, I'm Tomáš Gál from Slovakia. I have a QDI V4P895P3/SMT V5.0 Socket 3 / VLB motherboard and recently, i have saved its BIOS revision.
I have a verified physical dump of the original TMS27C512 EPROM, identified as OPTi895P3 GREEN PC IVN5.0, 7 Dec 1994.
It is different from the later IVN5.2 BIOS already present in the VOGONS Driver Library.
The BIOS ZIP and documentation are here:
https://github.com/tomasgal/qdi-v4p895p3-smt-v5
As a new forum member I can't use PM yet, so I'm posting it here in case it is suitable for inclusion in the Driver Library.
Thanks,
Tomáš
Reply 1667 of 1673, by giantenemycat
This is a long shot, but does anyone have the Virge DX/GX driver 4.10.01.2140-3.43.01? It seems to be lost to time on video-drivers/driverguide, which once upon a time required registration (so prevents archived download), but now redirects to some crapware driver downloader. Everywhere else has 4.10.01.2122-3.42.02 as the latest release.
https://web.archive.org/web/20090104102018/ht … rs/66/66846.htm
https://web.archive.org/web/20080412134218/ht … ?driverid=66846
Reply 1668 of 1673, by vetz
giantenemycat wrote on 2026-10-17, 23:34:
See attached:
S3 Virge/GX2/GX2+ Windows 98 FASTD3D Driver
Version * 4.10.01.2140-3.43.01 *
S3D Tool Kit version (s3dtkw.dll) * 5.00.01 *
- 06/23/98 -
Reply 1669 of 1673, by giantenemycat
vetz wrote on 2026-10-18, 06:48:
See attached: […]
See attached:
- 06/23/98 -
You're a legend! Thanks a lot man.
Reply 1670 of 1673, by douglar
I added the driver and I tried to clean up the naming a bit
Does this look OK?
S3 ViRGE Win3.1 v1.05.05 (DX, GX, VX)
S3 ViRGE Win3.1 v1.05.09 (DX)
S3 ViRGE Win95 v3.12.01 (DX, GX, VX)
S3 ViRGE Win9x v3.12.01 (VX, DX & GX)
S3 ViRGE Win9x v3.42.02 (DX, GX & GX2)
S3 ViRGE Win9x v3.43.10 (DX, GX & GX2)
S3 ViRGE WinNT 3.51 v1.22.04 (DX, GX)
S3 ViRGE WinNT 3.51 v1.23.01 ( ViRGE & VX )
S3 Win95 Driver v2.02.04 (ISA, VLB, Early PCI )
Reply 1671 of 1673, by douglar
I cleaned up the names on all of the S3 drivers. There were some version number discontinuities that complicate things, and there's the driver packs that complicate things, but hopefully the folder is a little more clear. I didn't touch any of the OEM drivers, because in those days the OEM drivers were often OEM specific and should stay seperate.
I guess I could go clear up the ViRGE vs Trio names, but that might take a lot of testing, because they all overlap
Chip Model     Part      Released
S3 Trio64 86C764 Mar-94
S3 Trio64V+ 86C765 Apr-95
S3 ViRGE 86C325 May-96
S3 ViRGE/VX 86C988 May-96
S3 Trio64V2/DX 86C775 Oct-96
S3 Trio64V2/GX 86C785 Oct-96
S3 ViRGE/DX 86C375 Nov-96
S3 ViRGE/GX 86C385 Nov-96
S3 ViRGE/MX 86C260 Mar-97
S3 Trio3D 86C365 Nov-97
S3 ViRGE/GX2 86C357 Jan-98
S3 Trio3D/2X 86C368 Dec-98
Reply 1672 of 1673, by ohnoitsalobo
Hi! I just came across this forum and I wanted to submit a driver (well, a set) for archival. The M-Audio Fast Track Ultra was an excellent compact 8-in, 8-out audio interface (6 analog, 2 S/PDIF). I have two of them and I hope to use them again, but I almost couldn't find the drivers.
Fortunately, the drivers (Win/Mac) are currently still accessible via Archive.org (PAGE LINK), and even more fortituously, appears to work perfectly on Windows 11.
It's been discontinued and the drivers WERE hosted on AVID's website ... but the page for "Fast Track Ultra" no longer exists.
They still have the drivers for Fast Track Solo, Duo, Pro, USB, and Ultra 8R, however.
I hope this fits as an addition to the driver archive.
Reply 1673 of 1673, by NeoG_
ohnoitsalobo wrote on Today, 10:18:
Hi! I just came across this forum and I wanted to submit a driver (well, a set) for archival. The M-Audio Fast Track Ultra was a […]
You can also upload them to Internet Archive, that's where most of them end up
