Reply 180 of 186, by red-ray
- Oldbie
PARKE wrote on Yesterday, 09:14:Do mobile chips with the same CPUID come with the same nomenclature ?
Often, but it would be wise to check what CPU World and/or Wikipedia says.
I added all the P4 Celerons and noted:
In my opinion some are accidentally entered two times by the people who typed the data or one of the two identical S-Specs is incorrect and some may actually have been produced with identical S-Specs - like for example the PII SECC you are discussing. The jury is still out for that one imo.
PARKE wrote on Yesterday, 13:34:The jury is still out for that one imo.
OK, I have been adding P4 Mobile.
Thanks for all the additional names. The Mobile P4 90-nm from pdf 302441 is later and supports hyper-threading.
PARKE wrote on Yesterday, 15:26:The Mobile P4 90-nm from pdf 302441 is later and supports hyper-threading.
OK, however I was really asking, why do the two Northwoods have very different names? Looking further one is Mobile P4 533MHz fsb
Also I noted below, given the 400MHz FSB then 2.33 GHz is impossible and https://www.cpu-world.com/sspec/SL/SL789.html says 2.30 GHz.
SL789 checked D1 0F29h 2.33GHz/400MHz Mobile Pentium 4-M 512KB sep 2002 35 1.3 400 2333.00 23 RK80532GC052512SL789 Malay
I have added more and noted:
