Reply 180 of 199, by douglar
- l33t
Sphere478 wrote on 2024-12-24, 15:42:Anyone found a bracket that works with the card?
Here is a “snap on” version . Print with supports.
Anyone willing to send me one? 😀
How well does the snap in one work? Thoughts/experience? Which one linked is best? (Most durable, fits best)
What's the maximum FAT partition size usable by these industrial cards under Win95/DOS 7?
Seems like an interesting way to obtain USB on my old 386DX system.
Can FAT32 be used?
luRaichu wrote on 2025-02-22, 22:49:What's the maximum FAT partition size usable by these industrial cards under Win95/DOS 7?
Can FAT32 be used?
I think you can use large FAT32 partitions with Win95B/DOS 7.1, which requires a 386 or better to boot. Also called Win95OSR2.
I don't think it works with Win95RTM/DOS 7.0. No large volume support, even though it supports Vfat file names.
Is this card alright? https://www.ebay.com/itm/256563798374
luRaichu wrote on 2025-02-23, 17:49:Is this card alright?
Looks like mine at first glance-- Links to ebay auctions are frowned upon by the mods though. Better off doing a fair use picture.
https://www.tinkercad.com/things/jeeLpwkieu9-isa-usb-bracket
Is there a metal bracket?
I tested the Chinese CH375 card on my AM386DX-40 system using MS-DOS 6.22 and FreddyV's 286 driver. Seems to work fine at the slowest speed, 0. What's the full range for the speed parameter?
Tested with Windows 95/MS-DOS 7.1 on the same 386.
I experienced file corruption with 64GB (FAT32) and 256MB (FAT16) USB sticks and speed set to 9.
Will test with old 1GB USB stick freshly formatted as FAT32. Too bad we can't format USB disks with this card!
luRaichu wrote on 2025-03-31, 17:16:I tested the Chinese CH375 card on my AM386DX-40 system using MS-DOS 6.22 and FreddyV's 286 driver. Seems to work fine at the slowest speed, 0. What's the full range for the speed parameter?
Hi,
Speed parameter is not used 😀
Any clue about data loss? When copying files from the USB stick to the hard drive, the files on the USB stick are spoiled. That should not happen if we're simply reading from USB.
Did more testing with 1GB and 4GB USB sticks. Seems stable now with correct speed setting.
When using the CH375 driver under Windows 9x, Load it with DEVLOAD in AUTOEXEC.BAT to avoid forcing MS-DOS compatibility mode on all disks.
DEVLOAD /H CH375286.SYS @260 %0
So I just use the 286 version of the driver to run this in my 486 machine correct? Card ordered and I can't wait to have easy file transfers in DOS and Windows 3.11!
Also, do BIOS drive size limitations apply or would this be considered its own IDE drive per se? In other words should I stick to a 2GB or 4GB drive to maintain compatibility under DOS 6.22 on a 486?
Yes, you use the 286 driver on a 386 or 486.
I don't know about disk size. I use a 4GB stick formatted as FAT16 without any issues in DOS and Windows. Not much use for larger disks in my opinion
TandySensation wrote on 2015-05-11, 20:11:I move data to and from old computers through an ISA network adapter or I take the disk out and mount it in a newer PC to move the necessary installs, sneaker net also works. A USB ISA card might be neat, if you can even find one, but I wouldn't bother, it's not period correct, wont work correctly, and might use use up some of your 640K memory.
My solution for moving things to/from/betweed DOS systems easily... network/serial/parallel, nothing has to be "installed"
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
mockingbird wrote on 2024-12-25, 16:24:Can anyone share a Gerber of the Lo-Tech PCB? I would like to test the speed with 16-bit internal transfers and 0-wait state vs. my Aliexpress card. I can't get a response from Lo-Tech and I'm not skilled enough to create a PCB from their schematic.
Did someone share that GERBERs?
RayeR wrote on 2025-07-28, 22:08:Did someone share that GERBERs?
I wish. Someone built it out of the schematic they posted but that would take a serious amount of time and skill - which I lack.
I tested FreddyV's driver on my 386-DX/33. At the lowest speed, it seemed to work fine. But then I plugged my USB stick into my Windows PC and it said there was no file system... Maybe a fluke? I will have to try again at some point.
I have found GERBERs and KiCAD files on site of some other Czech guy, funny I didn't know his website and there's not much people interested in this...
http://tefatronix.g6.cz/display.php?page=isa_usb&lang=en
[DL link at the bottom]
RayeR wrote on 2025-07-29, 04:47:I have found GERBERs and KiCAD files on site of some other Czech guy, funny I didn't know his website and there's not much people interested in this...
Do you think you can modify it to add this functionality from the lo-tech card?
JP4: Port mode
Std - 8-bit transfers, registers mapped at 2C0h, 2C1h
Fast - 16-bit transfers, registers mapped at 2C0h, 2C2h (not supported by alpha BIOS)
Is it missing the pin holes for adding an internal header? That would be handy too (hint, hint).
