Reply 180 of 866, by Roland User
wrote:Fellows, I urgently need the help of someone who ones the SC-88 or SC-88Pro, before I make a fool of myself in front of Roland C […]
Fellows, I urgently need the help of someone who ones the SC-88 or SC-88Pro, before I make a fool of myself in front of Roland Corporation. 😀
Please test the following:
1. When playing a game or midi file, when you press the SC-55 map mode, DOES THE SOUND CHANGE IMMEDIATELY?
2. When playing Doom or (GM mode), can you change the Map mode? does it change immediately? Or does the map is locked on what was selected before entering Doom?
Answer :
1) No , if select other mode during play map last also as not play sounds selected map
2) No , if select GM mode , map always set as SC8820 or any other selected mode... aslo , this only if select other mode earlier in GS mode.
