Any love for AM2?
Reply 180 of 258, by roytam1
my Athlon x2 3250e with JetWay JNC81-LF is still acting as internet gateway server for my home now.
The attachment pforte.png is no longer available
Reply 181 of 258, by AlexZ
Testbench 13:
- Gigabyte GA-MA770-UD3 v2.0
- Athlon X2 7850 BE 2.8Ghz AD785ZWCJ2BGH (Kuma, stepping B3, released in 2009)
- Asus GeForce GTX 480 (factory clocks, 701 GPU, 924 memory, 1401 shader, released in 2010). NVidia driver 197.41
- 4x 2GB DDR2 800 unganged running at 4 4 4 12
Athlon X2 7750 BE was OCed to simulate 7850 BE. I used 14x multiplier, stock CPU voltage. The results should be identical to a real 7850 BE. Later, a real 7850 BE will be used to simulate 2.9-3.0Ghz version. We couldn't run 4x 2GB sticks at 1066 similarly to Phenom X4 9950 BE 2.6Ghz. Only 2 memory sticks can run at that speed but we need 8GB RAM for Vista era.
3d mark 2006 breakdown, 1024x768:
  • Return To Proxycon - 43 fps
  • Firefly Forest - 45 fps
  • Canyon Flight - 98 fps
  • Deep Freeze - 54 fps
3d mark 2006 breakdown, 1600x900:
  • Return To Proxycon - 42 fps
  • Firefly Forest - 44 fps
  • Canyon Flight - 93 fps
  • Deep Freeze - 53 fps
3d mark 2006 breakdown, 1600x1200:
  • Return To Proxycon - 41 fps
  • Firefly Forest - 43 fps
  • Canyon Flight - 89 fps
Athlon X2 7850 BE 2.8Ghz falls in-between Athlon 64 X2 6000+ (Windsor) and Athlon 64 X2 6400+ (Windsor) as expected.
Games tested:
Windows XP
- F.E.A.R. (2005) - in 1600x1200 with max settings we get 141 fps average in built-in benchmark, 3 fps less than Athlon 64 X2 6400+ (Windsor).
- World in Conflict (2007) - in 1600x1200 we then get 31 average fps in built-in benchmark with the best visual quality settings.
- Crysis (2007) - in 1600x1200 average fps in benchmark is 45 without full screen anti aliasing. Everything else was set to max. When 4x anti aliasing is enabled, we get 43 average fps.
- Far Cry 2 (2008) - with max settings, in 1600x1200 we get 43 fps in the built-in "Demo Ranch" benchmark and 24 fps in the "Action Scene" benchmark. Not enough for enjoyable experience.
- Colin McRae: Dirt 2 (2009) - with ultra settings, in 1600x1200 we get 59 average fps in the built-in benchmark.
Windows 7
- Crysis (2007) - in dx10 mode in 1600x1200 we get 31 average fps with very high quality and 4x anti aliasing in built-in benchmark. In dx9 mode with high details and 4x anti aliasing we get 45 fps.
- Grand Theft Auto IV (2008) - in 1600x1200 we get 34 average fps in the built-in benchmark with very high quality, view distance 50, detail distance 60, vehicle density 51 (double values from defaults).
- Warhammer 40,000: Dawn of War II (2009) - with ultra settings, in 1600x1200 we get 38 average fps in the built-in benchmark.
- Batman: Arkham City (2011) - in 1600x1200 we get average 41 fps with very high quality and FXAA high anti-aliasing. Physics was off as it could not be enabled with the old driver 197.41.
Conclusion about Athlon X2 7850 BE 2.8Ghz with GeForce GTX 480 and DDR2 800:
- doesn't match Athlon 64 X2 6400+ (Windsor) performance wise in Windows XP games but beats Athlon 64 X2 6000+ (Windsor). Phenom based X2 CPUs fail to beat the best Windsor CPU.
- it is a good choice for Windows XP era games (2002-2006)
- mediocre coverage of Windows Vista era (2007-2009) due to slow CPU, noticeable in games from 2008
- noticably slower than Phenom X4 9950 BE 2.6Ghz in Windows Vista games such as GTA 4, Far Cry 2, Colin McRae: Dirt 2. We really need 4 AMD cores for later games.
- in hindsight, Phenom X4 9950 BE 2.6Ghz is a decent choice from tested CPUs to cover both Windows XP and Windows Vista era except for Crysis. It covers Vista era much better in general.
Next steps:
- test Athlon X2 7850 BE OCed to 2.9-3.0Ghz. It is expected to match Athlon 64 X2 6400+ (Windsor) performance wise. We would like to see how high the clocks would have to go to match Windsor.
- although there is also Phenom II X2 with clocks high enough to beat Windsor, it will be better served in an AM3 board and testing has shown 2 cores are inadequate for some Windows Vista games
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Athlon 64 3400+,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2 ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 182 of 258, by agent_x007
Phenom I REALLY needed that 6MB of L3 (it sadly wasn't possible, due to SRAM cell size at 65nm).
Phenom II x4 940 should be a good bit faster than Phenom 9950, especially in games.
Reply 183 of 258, by AlexZ
The expectation is Athlon X2 at 3Ghz (Phenom based) may be enough to match Windsor, but it's too little as that is still only Windows XP coverage. It's interesting mainly for comparison with Phenom II X4 at the same clock. Phenom II is really needed in AM2+ with its higher clocks and larger L3 cache. Around 3Ghz could be enough. Phenom II X4 940 BE should be a good choice (is also a true AM2+ CPU), if not available a 945 / 955 BE (AM3) could be used as a replacement. Phenom II X4 975 / 980 in AM2+ would kind of look like 486 DX4 100 in an ISA only motherboard.
Phenom X4 9950 isn't that bad in later games that utilize multiple threads, but does poorly in Crysis. The regression compared to Windsor is too big to accept it.
We are kind of pushing AM2+ to the limits. When I was buying boards, most people seemed to have either a 2.2-2.3Ghz Phenom X4 or Athlon X2 in them. The top tested configurations here almost never existed.
Reply 184 of 258, by Archer57
AlexZ wrote on 2025-07-15, 07:46:
Yeah, and that's why such comparison does not necessarily represent how things were back then. Like if someone was building a system with a limited budget (which it always is) the results of LGA775 vs AM2/AM2+ comparison could be totally different.
I did find 6000+ windsor while dumpster diving digging through stuff to be discarded at work though.
And that phenom2 i've tested was the one i've used back then, though being 720BE it was not really "top" before unlocking/overclocking. This one definitely was very cost-effective back then... it is a shame AMD decided to make unlocking impossible on newer CPUs - with how bad FX was it could have given them at least some reason to exist...
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 185 of 258, by the3dfxdude
Archer57 wrote on 2025-07-15, 08:42:
The FX chip added the turbo core features (yes select Phenom II's had it too). With turbo core giving you an auto overclocking capability, why would you, as a designer, give an additional manual overclocking ability? What margin is left is there to exploit? Besides maybe on very select carefully tested dies, that exhibit excellent capabilities that you can label a "overclock" version or "black edition", and considering FX being rough around the edges, I would see them say turbo core is what people really want. And since they know best on how to get performance out of the chip, why allow the great risk now of actually damaging the chip (overclocking in current advanced nodes makes me really concerned! The models they use show they won't have much life in them then...) So better they say, let's make using whatever margin there is easy and not have to deal with silly returns because they cooked their chip or it is not a good overclocker. Yes that takes the fun away. And yes, even though there is some merit to just having auto overclock for the average person, it does kind of make the FX look bad, because it poorly performed at the time when it had it.
Reply 186 of 258, by AlexZ
the3dfxdude wrote on 2025-07-15, 13:41:
The FX chip added the turbo core features (yes select Phenom II's had it too). With turbo core giving you an auto overclocking capability, why would you, as a designer, give an additional manual overclocking ability? What margin is left is there to exploit?Besides maybe on very select carefully tested dies, that exhibit excellent capabilities that you can label a "overclock" version or "black edition", and considering FX being rough around the edges, I would see them say turbo core is what people really want. And since they know best on how to get performance out of the chip, why allow the great risk now of actually damaging the chip (overclocking in current advanced nodes makes me really concerned! The models they use show they won't have much life in them then...) So better they say, let's make using whatever margin there is easy and not have to deal with silly returns because they cooked their chip or it is not a good overclocker. Yes that takes the fun away. And yes, even though there is some merit to just having auto overclock for the average person, it does kind of make the FX look bad, because it poorly performed at the time when it had it.
Looks like there is a misunderstanding between a temporary turbo, where the CPU can exceed TDP only for a short period of time, under certain workload conditions and long term overclocking where a higher TDP is acceptable. Entirely different things. I wouldn't make any claims on behalf of other people. One of major benefits of Phenom II was core unlocking, which is totally unrelated to turbo/overclocking.
My Phenom II X4 1100T has the first turbo function but I don't see it working frequently despite it being enabled in BIOS. What is more important to me is that BIOS allows me to configure both the base and boost frequency. Since the CPU can boost up to 4.7Ghz, I could easily set the base to 4.5-4.6Ghz if I needed as long as I have adequate cooling.
I also bought an FX-8370 (that will be replacing Phenom II X4 1100T) which allows me to set the base and boost frequency in BIOS as well. Noctua NH-D15 will be used to cool it and if needed, I could set the base frequency to 4.2-4.3Ghz and deal with higher TDP.
Reply 187 of 258, by Standard Def Steve
Before I parted ways with most of my post-Pentium III, pre-AVX2 stuff a couple of years ago, I had an X6 1090T in my collection. I believe that was one of the DDR3/AM3-only Phenoms. You know, I really liked that machine! I ran mine at 4.05 GHz. At that speed, it easily outperformed a stock E8600 even in single-threaded loads, but my gosh did it run red-hot. That machine put out more heat than my current Ryzen 5950X PBO'd to 5.05/4.65 GHz!
Unfortunately, Phenom really hasn't aged well, even compared to the FX lineup. I mean, the lack of SSE 4.1 is kind of understandable for an architecture that originally launched in 2007, but no SSSE3? C'mon now!
Anyway. Just a bit of an anecdote that doesn't really add much to your thread! 😀
"A little sign-in here, a touch of WiFi there..."
Reply 188 of 258, by the3dfxdude
AlexZ wrote on 2025-07-15, 19:43:
You can certainly run an elevated base frequency and deal with higher TDP as much as you want on your chips. The designers check their chips for a reason to have an expected lifespan for their highly clocked chips. I simulated this stuff and I've seen the numbers constraining the max frequency, so this is first hand accounts here. The max frequency numbers for that generation are really low for the high frequencies they tried to push and then they added the turbo, which is why I mention it, left essentially no room at all if you stayed in spec and deploy the expected use case, and if you trust this vendor and their silicon. Overclocking is overclocking. They do have product tiers they want to meet a demand for, if you want to play the lottery on the quality of the silicon, sure try it out. Given what I've seen, I don't trust these companies didn't bend the rules going to tape out and binning them.
I do like the Phenom II, but still, it isn't like there aren't still flaws.
Reply 189 of 258, by Archer57
Honestly i do not like whole "turbo" thing at all, either modern hardware or this old stuff with first implementations. I mean we already have power saving where frequency is reduced when idle, why do we need to go both ways, why not just set the frequency to max it can handle + power limit?
It makes modern hardware weird, where it can be overclocked by downvolting (less power = more boost within power limit) etc.
On phenoms? I'd much rather disable turbo, raise multiplier (so all cores) and leave power saving on. This way it'll be more predictable and as long as cooling can handle it performance will be better.
However OC was not really what i was talking about initially - i was talking about unlocking cores. On phenoms it was possible. On FX they made extra effort to prevent it. I get it - they want to sell more expensive CPUs, but IMO with how bad the FX was at least leaving this lottery available would have made them some extra sales...
Longevity? My phenom has been working daily for 15 years +/-, unlocked and overclocked, at higher temperatures... and it is still fine. I'd say it practically outlived its useful life. I get all the talks about modern hardware with smaller transistors and longevity concerns, but i'll only be worried about it if we see actual failures in large quantities. So far - nothing but some unrelated issues like AMD killing stuff by overvolting it out of the box...
Reply 190 of 258, by AlexZ
Turbo wouldn't be bad if it had capability to enable that extra frequency in cpu heavy scenes temporarily and then switch to base thus running always just for a few seconds and reducing lows. But it isn't that intelligent and basically useless for games. It makes performance more unpredictable. Perhaps useful only for single threaded productivity apps.
Power saving features greatly reduce TDP/noise in idle mode making OC more viable. You get more noise only when playing games and low TDP otherwise. With large coolers the TDP is not a problem.
Reply 191 of 258, by AlexZ
Testbench 14:
- OCed Athlon X2 7850 BE to 3.0Ghz AD785ZWCJ2BGH (Kuma, stepping B3, released in 2009)
I used 15x multiplier, stock CPU voltage.
  • Return To Proxycon - 45 fps
  • Firefly Forest - 47 fps
  • Canyon Flight - 103 fps
  • Deep Freeze - 57 fps
  • Return To Proxycon - 44 fps
  • Firefly Forest - 46 fps
  • Canyon Flight - 97 fps
OCed Athlon X2 7850 BE at 3.0Ghz slightly outperforms Athlon 64 X2 6400+ (Windsor).
Games tested:
Windows XP
- F.E.A.R. (2005) - in 1600x1200 with max settings we get 145 fps average in built-in benchmark, 1 fps more than Athlon 64 X2 6400+ (Windsor).
- World in Conflict (2007) - in 1600x1200 we then get 32 average fps in built-in benchmark with the best visual quality settings, which is 1 fps less than Athlon 64 X2 6400+ (Windsor).
- Crysis (2007) - in 1600x1200 average fps in benchmark is 46 without full screen anti aliasing. Everything else was set to max. When 4x anti aliasing is enabled, we get 45 average fps. 4 fps less than Athlon 64 X2 6400+ (Windsor).
- Far Cry 2 (2008) - with max settings, in 1600x1200 we get 44 fps in the built-in "Demo Ranch" benchmark and 25 fps in the "Action Scene" benchmark. Not enough for enjoyable experience.
- Colin McRae: Dirt 2 (2009) - with ultra settings, in 1600x1200 we get 61 average fps in the built-in benchmark.
- Tom Clancy's H.A.W.X. 2 (2010) - with max settings, anti aliasing set to 4x, in 1600x1200 we get 82 average fps in the built-in benchmark
Windows 7
- Crysis (2007) - in dx10 mode in 1600x1200 we get 31 average fps with very high quality and 4x anti aliasing in built-in benchmark. In dx9 mode with high details and 4x anti aliasing we get 47 fps.
- Grand Theft Auto IV (2008) - in 1600x1200 we get 35 average fps in the built-in benchmark with very high quality, view distance 50, detail distance 60, vehicle density 51 (double values from defaults).
- Warhammer 40,000: Dawn of War II (2009) - with ultra settings, in 1600x1200 we get 40 average fps in the built-in benchmark.
- Batman: Arkham City (2011) - in 1600x1200 we get average 43 fps with very high quality and FXAA high anti-aliasing. Physics was off as it could not be enabled with the old driver 197.41.
Conclusion about OCed Athlon X2 7850 BE at 3.0Ghz with GeForce GTX 480 and DDR2 800:
- about equal to Athlon 64 X2 6400+ (Windsor) performance wise except for Crysis
- noticably slower than Phenom X4 9950 BE 2.6Ghz in Windows Vista/7 games such as GTA 4, Far Cry 2, Colin McRae: Dirt 2, Tom Clancy's H.A.W.X. 2, Batman: Arkham City. We really need 4 AMD cores for later games.
Next steps:
- test Phenom II X4 940 BE 3.0Ghz
Reply 192 of 258, by the3dfxdude
Archer57 wrote on 2025-07-16, 01:08:
Yes, I agree, that turbo, in a technical sense is lame. But when you are speak about wanting to unlock cores in FX like in the previous gen, even that, turbo added into the design affected the handling and access into each core. They started locking that down because they had to place limits on how many cores you can actually use when engaging turbo. The thing is, when they tried to get turbo implemented fully in FX, they also redesigned the core architecture to add more features they were missing, and add threading to use more of the "idle" parts of the chip. It was still too hot. That is why they went with the 2 core x 2 thread scheme, 4x4 etc, and only engaging turbo when using only half, and running slower with both. And even ended up loosing actual cores compared to the previous gen. The speeds weren't even that great. They just couldn't get the higher frequencies in FX without cooking the chip, and therefore why there were complaints and Phenom II being a more performant chip. I'm not sure if financially FX helped to have keep the company afloat or simply hurt them. It was a long time for them to get Ryzen out. I would guess it helped keep them afloat.
Generally, I think the auto overclocking feature shows the weakness of the industry in being able to get more speed out of silicon anymore. So they are pushing the limits of what anyone can do and calling it faster now.
I like the phenoms. It is a more traditional design, and easier and more predictable like you say. But they want to make the next gen "faster" and so now the chip design is to be your parent and do overclocking for you.
Reply 193 of 258, by AlexZ
Testbench 15:
- Phenom II X4 940 BE 3.0Ghz HDZ940XCJ4DGI (Deneb, stepping C2, released in 2009)
Phenom II X4 940 BE is an AM2+ specific CPU that doesn't work in AM3. Alternatively, a Phenom II X4 945 could be used (AM3, slightly higher HT speed).
We didn't test stability of DDR2 1066 with 4 memory modules.
  • Return To Proxycon - 51 fps
  • Firefly Forest - 52 fps
  • Canyon Flight - 112 fps
  • Deep Freeze - 66 fps
  • Return To Proxycon - 49 fps
  • Firefly Forest - 51 fps
  • Canyon Flight - 105 fps
  • Canyon Flight - 99 fps
  • Deep Freeze - 65 fps
Games tested:
Windows XP
- F.E.A.R. (2005) - in 1600x1200 with max settings we get 161 average fps in built-in benchmark.
- Test Drive Unlimited (2006) - in 1600x1200 and max details 55-90 fps after buying car and driving around on highways
- Call of Duty 4 Modern Warfare (2007) - in 1600x1200 we get 210-380 fps (200 when aiming at tower with scope) in the initial mission outside of shooting room.
- World in Conflict (2007) - in 1600x1200 we then get 42 average fps in built-in benchmark with the best visual quality settings.
- Crysis (2007) - in 1600x1200 average fps in benchmark is 54 without full screen anti aliasing. Everything else was set to max. When 4x anti aliasing is enabled, we get 52 average fps.
- STALKER (2007) - in 1600x1200, first mission outside we get about 65-130 fps.
- Far Cry 2 (2008) - with max settings, in 1600x1200 we get 48 fps in the built-in "Demo Ranch" benchmark and 36 fps in the "Action Scene" benchmark.
- Need for Speed: Undercover (2008) - in 1600x1200 we get 37-60 fps in the city at the main menu. Not enough for enjoyable experience due to lows.
- Colin McRae: Dirt 2 (2009) - with ultra settings, in 1600x1200 we get 93 average fps in the built-in benchmark.
- Tom Clancy's H.A.W.X. 2 (2010) - with max settings, anti aliasing set to 4x, in 1600x1200 we get 117 average fps in the built-in benchmark
Windows 7
- Crysis (2007) - in dx10 mode in 1600x1200 we get 34 average fps with very high quality and 4x anti aliasing in built-in benchmark. In dx9 mode with high details and 4x anti aliasing we get 52 fps. The 41 fps in dx10 mode recorded in Phenom X4 2.6Ghz was most likely an error.
- Grand Theft Auto IV (2008) - in 1600x1200 we get 60 average fps in the built-in benchmark with very high quality, view distance 50, detail distance 60, vehicle density 51 (double values from defaults). 33-60fps while driving home in the first mission.
- Warhammer 40,000: Dawn of War II (2009) - with ultra settings, in 1600x1200 we get 48 average fps in the built-in benchmark.
- Metro 2033 (2010) - in 1600x1200 we get average 22 fps with very high quality except for SSAA and Physics (caused crashes). No graphical glitches unlike on Phenom X4 2.6Ghz.
- Mafia II (2010) - in 1600x1200 we get average 28 fps with max settings including antialiasing and 16x anisotropic filtering. Apex Physics level may have to be reduced to make the game enjoyable. Game asked to update Physics which could explain the much improved score over Phenom X4 2.6Ghz.
- Batman: Arkham City (2011) - in 1600x1200 we get average 65 fps with very high quality and FXAA high anti-aliasing. Physics was off as it could not be enabled with the old driver 197.41.
Conclusion about Phenom II X4 940 BE 3.0Ghz with GeForce GTX 480 and DDR2 800:
- decent coverage of Windows Vista era (2007-2009), better than Phenom X4 2.6Ghz
- some Windows 7 era (2010-2012) titles may have to be played with reduced settings
- I can recommend this 4 core CPU for AM2+ systems. It supersedes Phenom X4 9950 BE 2.6Ghz.
Next steps:
- test Phenom II X4 955 BE 3.2Ghz which represents Phenom II X4 940 BE OCed to 3.2Ghz. It is a real world scenario as exemplified by Archer57. The motivation is to improve dx10 performance in Crysis and Need for Speed: Undercover and mitigate possible regressions when moving to 2xx geforce drivers. The 197.41 driver was not chosen randomly. This is the last CPU that will be tested as faster CPUs would typically be used in AM3 systems.
- we hope that dx10 Crysis perfromance can be improved further with a better GPU
- we should be able to beat the 3.2Ghz Phenom II X4 (OCed and unlocked X3) from Archer57 paired with GeForce GTX 750. GeForce GTX 750 is about same as GeForce GTX 260 which we tested. GeForce GTX 480 is slightly faster. We also have better memory timings and better GPUs in reserve.
edit1: fixed DDR2 1066 findings
Reply 194 of 258, by AlexZ
Testbench 16:
- Phenom II X4 955 BE 3.2Ghz HDZ955FBK4DGM (Deneb, stepping C3, released in 2009)
Phenom II X4 955 BE represents an OCed Phenom II X4 940 BE to 3.2Ghz which is a realistic scenario. 940 BE is an early stepping C2 and has less overclocking potential than C3. Un-core is running at 2Ghz vs 1.8Ghz on 940 BE. This can be adjusted in BIOS as Northbridge multiplier. Raising un-core frequency improves memory controller and L3 cache bandwidth. Un-core at 2Ghz is a realistic target for 940 BE.
  • Return To Proxycon - 53 fps
  • Firefly Forest - 55 fps
  • Canyon Flight - 118 fps
  • Deep Freeze - 70 fps
  • Canyon Flight - 111 fps
  • Firefly Forest - 54 fps
Games tested:
Windows XP
- F.E.A.R. (2005) - in 1600x1200 with max settings we get 164 average fps in built-in benchmark.
- Call of Duty 4 Modern Warfare (2007) - in 1600x1200 we get 225-380 fps (200 when aiming at tower with scope) in the initial mission outside of shooting room.
- World in Conflict (2007) - in 1600x1200 we then get 45 average fps in built-in benchmark with the best visual quality settings.
- Crysis (2007) - in 1600x1200 average fps in benchmark is 60 without full screen anti aliasing. Everything else was set to max. When 4x anti aliasing is enabled, we get 56 average fps.
- Far Cry 2 (2008) - with max settings, in 1600x1200 we get 49 fps in the built-in "Demo Ranch" benchmark and 38 fps in the "Action Scene" benchmark.
- Need for Speed: Undercover (2008) - in 1600x1200 we get 40-65 fps in the city at the main menu. Not enough for enjoyable experience due to lows.
- Colin McRae: Dirt 2 (2009) - with ultra settings, in 1600x1200 we get 99 average fps in the built-in benchmark.
- Tom Clancy's H.A.W.X. 2 (2010) - with max settings, anti aliasing set to 4x, in 1600x1200 we get 122 average fps in the built-in benchmark
Windows 7
- Crysis (2007) - in dx10 mode in 1600x1200 we get 35 average fps with very high quality and 4x anti aliasing in built-in benchmark. In dx9 mode with high details and 4x anti aliasing we get 54 fps.
- Grand Theft Auto IV (2008) - in 1600x1200 we get 62 average fps in the built-in benchmark with very high quality, view distance 50, detail distance 60, vehicle density 51 (double values from defaults).
- Warhammer 40,000: Dawn of War II (2009) - with ultra settings, in 1600x1200 we get 51 average fps in the built-in benchmark.
- Mafia II (2010) - in 1600x1200 we get average 30 fps with max settings including antialiasing and 16x anisotropic filtering. Apex Physics level may have to be reduced to make the game enjoyable.
- Batman: Arkham City (2011) - in 1600x1200 we get average 67 fps with very high quality and FXAA high anti-aliasing. Physics was off as it could not be enabled with the old driver 197.41.
SiSoft Sandra 2013:
- memory bandwidth 9.75GB/s, 77% bandwidth efficiency
- cache bandwidth L1: 248GB/s, L2: 122GB/s, L3: 42GB/s
Conclusion about Phenom II X4 955 BE 3.2Ghz with GeForce GTX 480 and DDR2 800:
- decent coverage of Windows Vista era (2007-2009), better than Phenom X4 2.6Ghz which suffers from low clock and low single thread performance
- I can recommend this AM3 4 core CPU for AM2+ systems even though it is a bit of a stretch as the top AM2+ only CPU is Phenom II X4 940 BE, which can be recommended as well.
- note: Phenom II X4 945/955/965 is not compatible with all AM2+ boards, it requires a dual power-plane. If not available, the CPU will run at 800Mhz. It is not resolvable via BIOS update. If your board doesn't have this feature, use Phenom II X4 940 BE.
- users considering Phenom II X4 965 or later will be better off in an AM3 board which introduced DDR3, SATA 3.0, USB 3.0.
Next steps:
- test GeForce GTX 580
edit2: fixed DDR2 1066 findings
Reply 195 of 258, by AlexZ
Testbench 17:
- EVGA GeForce GTX 580 (factory clocks, 772 GPU, 1002 memory, 1544 shader, released in 2010). NVidia driver 285.58
  • Firefly Forest - 56 fps
  • Canyon Flight - 122 fps
  • Deep Freeze - 71 fps
  • Canyon Flight - 116 fps
  • Return To Proxycon - 52 fps
  • Firefly Forest - 53 fps
  • Canyon Flight - 113 fps
Games tested:
Windows XP
- F.E.A.R. (2005) - in 1600x1200 with max settings we get 181 average fps in built-in benchmark.
- Call of Duty 4 Modern Warfare (2007) - in 1600x1200 we get 240-450 fps (250 when aiming at tower with scope) in the initial mission outside of shooting room.
- World in Conflict (2007) - in 1600x1200 we then get 47 average fps in built-in benchmark with the best visual quality settings.
- Crysis (2007) - in 1600x1200 average fps in benchmark is 60 without full screen anti aliasing. Everything else was set to max. When 4x anti aliasing is enabled, we get 58 average fps.
- S.T.A.L.K.E.R. (2007) - in 1600x1200 with max details we get 70-150 fps outside in the first mission
- Far Cry 2 (2008) - with max settings, in 1600x1200 we get 70 fps in the built-in "Demo Ranch" benchmark and 39 fps in the "Action Scene" benchmark. "Demo Ranch" result is a major improvement over GeForce GTX 480.
- Tom Clancy's H.A.W.X. 2 (2010) - with max settings, anti aliasing set to 4x, in 1600x1200 we get 143 average fps in the built-in benchmark
Windows 7
- Crysis (2007) - in dx10 mode in 1600x1200 we get 41 average fps with very high quality and 4x anti aliasing in built-in benchmark. In dx9 mode with high details and 4x anti aliasing we get 54 fps.
- Grand Theft Auto IV (2008) - in 1600x1200 we get 60 average fps in the built-in benchmark with very high quality, view distance 50, detail distance 60, vehicle density 51 (double values from defaults). Slight regression over GeForce GTX 480.
- Warhammer 40,000: Dawn of War II (2009) - with ultra settings, in 1600x1200 we get 53 average fps in the built-in benchmark.
- Metro 2033 (2010) - in 1600x1200 we get average 29 fps with very high quality except for SSAA (GPU not powerful enough) and PhysX (caused crashes).
- Mafia II (2010) - in 1600x1200 we get average 32 fps with max settings including antialiasing, 16x anisotropic filtering and Apex PhysX. Apex PhysX level may have to be reduced to make the game enjoyable.
- Batman: Arkham City (2011) - in 1600x1200 we get average 78 fps with very high quality and FXAA high anti-aliasing without PhysX. With PhysX set to normal we got average 45 fps.
SiSoft Sandra 2013:
Conclusion about Phenom II X4 955 BE 3.2Ghz with GeForce GTX 580 and DDR2 800:
- decent coverage of Windows Vista era (2007-2009).
- some Windows 7 era (2010-2012) titles may have to be played with reduced settings, especially PhysX which needs to be off
- we saw a major improvement over GTX 480 in Far Cry 2, noticeable improvement in Crysis dx10, Tom Clancy's H.A.W.X. 2, Metro 2033, Batman: Arkham City
Next steps:
- test GeForce GTX 770 as a proxy for GeForce GTX 680
Reply 196 of 258, by agent_x007
To be honest, I don't think GTX 770 should be that much faster than GTX 580.
I would love to see what HD 7970 or R9 280X can do in WinXP vs. Win7 though.
Reply 197 of 258, by AlexZ
There is actually a big performance jump between GTX 580 and GTX 680. GTX 260, 275, 480, 580 feel like minor revisions compared to that jump. GTX 770 will be used as a proxy for GTX 680 as its specs are almost the same. However, a 3.2Ghz Phenom II is too weak for that GPU.
I wonder whether we can keep the performance boost in Far Cry 2 and what happens to Metro 2033, Mafia II and Batman: Arkham City with PhysX.
Phenom II X4 at 3.2Ghz in AM3, DDR3-1600, GeForce 980Ti OC gets just 43 fps in Crysis dx10 in 1920x1080 so we have pretty much reached the ceiling there. It would take the top 3.7Ghz Phenom II X4 980 BE to make significant progress there.
I don't have any AMD Radeon GPUs, only NVidia.
Reply 198 of 258, by AlexZ
Testbench 18:
- Gigabyte GeForce GTX 770 WindForce 3X OC 2GB (1137/1189 GPU, 1753 memory, released in 2013). NVidia driver 340.52
  • Return To Proxycon - 54 fps
  • Canyon Flight - 123 fps
  • Canyon Flight - 119 fps
Negligible improvement over GTX 580, results are within margin of error. We are CPU bottlenecked.
Games tested:
Windows XP
- F.E.A.R. (2005) - in 1600x1200 with max settings we get 207 average fps in built-in benchmark.
- Call of Duty 4 Modern Warfare (2007) - in 1600x1200 we get 250-500 fps (320 when aiming at tower with scope) in the initial mission outside of shooting room.
- World in Conflict (2007) - in 1600x1200 we then get 48 average fps in built-in benchmark with the best visual quality settings.
- Crysis (2007) - in 1600x1200 average fps in benchmark is 61 without full screen anti aliasing. Everything else was set to max. When 4x anti aliasing is enabled, we get 57 average fps.
- S.T.A.L.K.E.R. (2007) - in 1600x1200 with max details we get 70-220 fps outside in the first mission
- Far Cry 2 (2008) - with max settings, in 1600x1200 we get 81 fps in the built-in "Demo Ranch" benchmark and 41 fps in the "Action Scene" benchmark.
- Colin McRae: Dirt 2 (2009) - with ultra settings, in 1600x1200 we get 97 average fps in the built-in benchmark.
- Tom Clancy's H.A.W.X. 2 (2010) - with max settings, anti aliasing set to 4x, in 1600x1200 we get 148 average fps in the built-in benchmark
Windows 7
- Crysis (2007) - in dx10 mode in 1600x1200 we get 46 average fps with very high quality and 4x anti aliasing in built-in benchmark. In dx9 mode with high details and 4x anti aliasing we get 57 fps.
- Grand Theft Auto IV (2008) - in 1600x1200 we get 49 average fps in the built-in benchmark with very high quality, view distance 50, detail distance 60, vehicle density 51 (double values from defaults). 11 FPS less than GTX 580.
- Warhammer 40,000: Dawn of War II (2009) - with ultra settings, in 1600x1200 we get 56 average fps in the built-in benchmark.
- Metro 2033 (2010) - in 1600x1200 we get average 44 fps with very high quality except for SSAA and PhysX. With SSAA enabled we get average 30 fps. With PhysX enabled we get average 23 fps. With both SSAA and PhysX we get average 18 fps.
- Batman: Arkham City (2011) - in 1600x1200 we get average 118 fps with very high quality and FXAA high anti-aliasing without PhysX. With PhysX set to normal we get average 56 fps. With PhysX set to high we get average 48 fps.
SiSoft Sandra 2013:
Conclusion about Phenom II X4 955 BE 3.2Ghz with GeForce GTX 770 and DDR2 800:
- we saw improvement over GTX 580 in Far Cry 2, and Tom Clancy's H.A.W.X. 2, Crysis (dx10), Metro 2033, Batman: Arkham City. The upgrade does pay off in late titles even though the CPU is underpowered and cannot fully utilize the GPU.
- we saw a noticable regression in Grand Theft Auto IV. It may be worth it to try a different driver.
Next steps:
- try different drivers to see if the performance regression in Grand Theft Auto IV can be resolved
- test DDR2 1066 with 4x 2GB modules as it seems possible with Phenom II
Reply 199 of 258, by AlexZ
Drivers 332.21 and 368.81 didn't resolve the performance regression in Grand Theft Auto IV. 332.21 got 47 fps, 368.81 got 52 fps which is still too low. It is probably related to GPU architecture or changes in driver. As I do not have a GeForce 680, I cannot verify when the regression was introduced. We can only hope that it will get resolved by brute force with GTX 780 or GTX 980.
With driver 368.81 in Windows 7, we got the following results:
  • Return To Proxycon - 57 fps
  • Firefly Forest - 60 fps
  • Canyon Flight - 129 fps
  • Deep Freeze - 73 fps
The results are slightly better than in Windows XP and NVidia driver 340.52. We got very close to results from Archer57 with C2D E8600+GTX660 (driver 368.69). See Re: Any love for AM2? .
With driver 368.81 in Windows XP, we got the following results:
Driver 368.81 doesn't seem to be better than the tested 340.52 in Windows XP.
I re-tested Need for Speed Hot Pursuit 2 and the major performance regression observed with GTX 480 is gone with 368.81 and GTX 770. The game is perfectly playable.
All 3d mark 2006 scores in previous testbenches are from Windows XP.
Conclusion:
- We could not resolve the performance regression in Grand Theft Auto IV. 11 fps drop is quite significant and during real game we can easily hit 30 fps.
- For some DirectX 9 games, there is potential for them to run better in Windows 7 than Windows XP. The reason is unknown, it could be better thread schedulling. C2D E8600 may be more resilient.
Next steps:
- re-test Need for Speed Hot Pursuit 2 with GTX 480 and GTX 580 with driver 368.81 in Windows XP
