Pentium 4 Multi-OS Build Log (DOS/3.11/95/NT4/98/2k/Me/XP)
Reply 180 of 195, by Shponglefan
Did more testing with P4Tool, this time benchmarking the low end of performance with cache disabled.
First chart is using the 17x multiplier for the Pentium 4, second chart is with 12x multiplier. JEMM386 and HIMEMX was used for these benchmarks. For comparison, I included benchmarks from my 486 DX-33 and 386 DX-40 systems.
The attachment Pentium 4 651 (Cedar Mill) 17x vs 486 DX-33 vs 386 DX-40.png is no longer available
The attachment Pentium 4 651 (Cedar Mill) 12x vs 486 DX-33 vs 386 DX-40.png is no longer available
With just cache disabled, it performs like a mid-range 486. At the lowest level of performance with 12x multiplier, DS+BTS option, and cache fully disabled, the Pentium 4 is about the level of a 386 DX-40.
With cache disabled combined with the multiplier and DS/DS+BTS throttling options, the Cedar Mill P4 nicely covers a range of speeds from fast 386 to low/mid-range 486.
486 DX-33 with 5 sound cards
Reply 181 of 195, by Shponglefan
Benchmarks with 3D Bench and PC Player benchmarks testing throttling methods and combinations. These were undertaken with JEMM386 and HIMEMX enabled.
System reference scores for 3D Bench were taken from Phil's 136-in-1 Pentium MMX project. Reference scores for PC Player bench were taken from some of Phil's benchmark references and my own benchmarking.
I do find it interesting that the 3D Bench scores are comparatively lower than PC Player benchmark scores. The 3D Bench scores indicates performance going down to 386 levels, whereas PC Player bench stops at the lower-end of 486 performance. I imagine in practice it will come down to trial-and-error to hit specific performance levels in different games.
Of course the Pentium 4 can go even lower using ACPI and/or ODCM throttling.
Reply 182 of 195, by myne
The p3 era had a prochot signal (processor hot) that allowed the system monitor chip to tell the chipset to sleep the processor up to 75%.
If you're decent at coding, look up whether the p4 retained it, and the sysmon datasheets.
I built:
Reply 183 of 195, by Shponglefan
myne wrote on 2026-04-08, 02:36:
I did some research into this. From what I can gather, when prochot signal is triggered, it introduced halt states based on a frequency cycle (PWM). It sounds like it's doing the same thing that ODCM and ACPI throttling methods do.
So I suspect that functionality is already available through tools like CPUSPD which include those throttling options.
Reply 184 of 195, by myne
Probably. I doubt they left many stones unturned, but you could potentially check with something like wpcredit. I assume the sysmon will be present there.
I built:
Reply 185 of 195, by Mao
Hey, would you recommend buying this IMB200 motherboard for a multiboot retropc, say over an AIMB865 ver. xxx.2? I am very intrigued by these industrial motherboards that support ISA cards. Thanks
Reply 186 of 195, by Shponglefan
Mao wrote on 2026-05-02, 08:19:
I've only used the IMB200 motherboard. Based on my testing, it works well with ISA sound cards in DOS, if that's what you are looking for.
Since I've never owned or used an AIMB865, I can't say how the two motherboards would compare.
Reply 187 of 195, by Mao
Hey, thanks for your reply. I just ordered an IMB200 from eBay, but in the end I have decided to get both motherboards and build two systems around them. Yes, what I mean is to have many oss on them, from DOS with ISA historic and modern sound cards up to XP. I will eagerly read *all* your threads!
Reply 188 of 195, by Shponglefan
Mao wrote on 2026-05-03, 07:35:
Good luck! I'll be interested to see the results of your builds.
Reply 189 of 195, by Ascended
Like to share a little problem/solution that I had on my ITOX. It's with GUS digital not working (MK1869 Xtreme for me). I'm not sure if it's unique to my MB or all ITOX.
Disabling LAN/PXE Boot ROM (while keeping other settings active)
1. Go to Onboard Device → Set LAN (and LAN 2 if present) to [Enabled]
2. Go to Advanced BIOS Features → Set First Boot Device to [LAN]
3. In Advanced BIOS Features, set Boot Other Device to [Enabled]
4. Go to Integrated Peripherals → Set Onboard LAN Boot ROM to [Enabled]
5. Save & reboot.
6. During early boot (when basic POST info appears), press Shift + F10
to enter the Realtek LAN Boot Agent Configuration Menu.
7. In the LAN Boot GUI:
- Set Boot Order to [ROM Disable]
- Set Show Config Message to 1 Second
- Press F4 to save and exit.
8. Return to BIOS → Go back to Advanced BIOS Features → Change
First Boot Device back to [Floppy] (or your preferred boot device).
Save and reboot.
Current situation on my system:
I need to leave most of these settings active. For some reason, if I disable
[Boot Other Device] or [Onboard LAN Boot ROM], the system reverts to its
original legacy state and I lose digital sound on my Gravis UltraSound (GUS).
It's not a big deal though — the only downside is that you'll briefly see the
Realtek RTL8110SC Gigabit Boot Agent message for about 1 second during boot.
I'll happily take that small hit to keep GUS digital sound working properly.
Reason for this workaround:
When the LAN/ROM is loaded into memory, it causes all sorts of funky issues.
On my system, for example, I cannot load EMM386 + HIMEM functions when the
PXE ROM is active. This was actually the clue that led me to the fix.
The Realtek option ROM installs itself as a resident handler. It hooks
interrupts (e.g. INT 13h for the boot device chain or INT 19h) and may
probe hardware resources to prepare for network boot.
If LAN boot/PXE is enabled in BIOS (or the NIC has its boot ROM/PXE option
ROM active), the card’s option ROM loads early in POST. It can temporarily
“probe” or reserve DMA resources — which causes the GUS initialization
(IWINIT or UNISOUND) to misconfigure or fail silently on DMA.
Many NIC option ROMs perform legacy resource probes during init. They
temporarily test or claim DMA channels (e.g. DMA 1–3 or 5–7), IRQs
(often 9–12), or I/O ports (e.g. 300h–380h range).
Even if they don’t fully claim the resources permanently, the probe can:
- Leave the DMA controller in a weird state
- Temporarily mask or alter IRQ lines
- Shadow/occupy memory regions that DOS programs expect to be free
Reply 190 of 195, by Mao
just to keep you guys updated, neither motherboard was available. Especially AIMB-865 is completely gone, out of stock everywhere. So, in the end I made a money effort and bought a very expensive RUBY-9719AR2VG motherboard, which actually arrived, luckily with no import tax nor VAT. I am still gathering everything I need to assemble a whole pc around it. Its strong point are 1 16x pci-e slot, 5 or 6 pci slots and 1 ISA slot, which can do DMA if properly activated via software in DOS and also in Win9x, with a getaround (I believe). It will take months to have a working system because I have so little time, but there are useful guides and nice people ready to help here and elsewhere.
Reply 191 of 195, by Pino
Pino wrote on 2024-03-22, 15:49:
Beautiful build, I might try one like this some day.
How are you slowing the CPU? Just disabling L1 and L2 cache? How slow can you go and how flexible it is?
Thanks for all the detailed info on the post.
It might have taken me more than 2 years, but I have finally started to build a similar system.
I could never convince myself into spending close to $200 on a motherboard, so when a socket 478 with 2 ISA slots showed up on ebay for $50 I took my chance.
The board is a Corvalent P4EAX, AKA APC Gator, AKA Corvalent/APC Phoenix
Not great as the models discussed on this thread, as it was sold as not tested, it uses an Intel 854GE chipset, and more concerning it uses the PCI-ISA bridge PC87200VUL from National Semiconductor, which I had no confirmation that could handle DMA correctly.
Quickly tested last night and glad to report that it booted first try, no repair needed. I'm even happier to report that the PCI-ISA bridge works like a charm, the BIOS have very detailed options to control IRQ and DMA allocation. Tested with a ESS sound card (SB PRO clone that required only low DMA) and a Soundblaster 16 (uses 2 DMAs).
I will test tonight with my GUS PNP Clone (a Compaq card) let's see if it works better than with the ITE bridge.
Anything else you guys are curious to compare with this bridge?
Reply 192 of 195, by Shponglefan
Pino wrote on 2026-09-29, 16:55:
That looks like a solid option and a great deal for a Pentium 4 board with working ISA slots and DMA support!
I would be very curious to see how the GUS PnP fairs with that PCI-ISA bridge chip. It's the one main point of incompatibility in my current setup, although I do believe it's ultimately a driver issue, since some things do work (i.e. Win 3.1 drivers and some games), while other things don't work.
Reply 193 of 195, by Pino
Shponglefan wrote on 2026-09-29, 21:51:
That looks like a solid option and a great deal for a Pentium 4 board with working ISA slots and DMA support! […]
Had some time to test the GUS PNP clone on it last night and it didn't go too well. Not sure if it's the same problem you are facing with yours.
Card gets initialized fine by Unisound or GUS on init program, but when I try to open descent setup it fails to load the .PAT files, I get several lines of errors.
If I wait and ignore the errors I can select the card on setup, digital sound test works, but obviously fails the music test because it didn't load the .PAT files.
Doom gets stuck at "calling DMX_init".
Thought it could be an issue with the IDE/SD adapter on a too fast system, but I installed Win98/DOS 7.1 on SATA SSD and got the same error.
Tried to remove the extra memory on the GUS PNP, but using only the onboard 512KB memory had the same issue.
Too me it looks like an issue caused by using a too fast CPU (2.8Ghz in my case), I'm not sure it's related to the PCI-ISA bridge
Reply 194 of 195, by Shponglefan
Pino wrote on 2026-10-02, 13:48:
Had some time to test the GUS PNP clone on it last night and it didn't go too well. Not sure if it's the same problem you are fa […]
Those are the same symptoms I've had when trying to use a GUS PnP on my system. Looks like it has the same incompatibility.
You could test some things that should work. This includes Epic Megagames' games like Epic Pinball, Jazz Jackrabbit and One Must Fall 2097. Tracker software like Scream Tracker 3 and Impluse Tracker should also work. And Windows 3.1 drivers may work if you have a Windows 3.1 install to test.
I'm not sure if it's a CPU speed issue, because even when throttling the CPU, the incompatibilities are still there. Plus there is some software along with Windows 3.1 drivers that has worked for me, as listed above.
Though I suppose the exact issue hasn't been diagnosed that I'm aware of, so it could still be anything at this point.
Reply 195 of 195, by Pino
Shponglefan wrote on 2026-10-05, 23:45:
Those are the same symptoms I've had when trying to use a GUS PnP on my system. Looks like it has the same incompatibility. […]
Well, I tested the GUS PNP on the fastest native ISA system I have, a KT133A motherboard with a Athlon XP running at 1.9Ghz and it was not happy at all, this time it doesn't fail at loading .PATs, and music works, but then digital sound crashes, both at Descent and Doom I / II. So there is definitively something about fast systems and I don't think it's exclusive a bridge issue.
Never tried Win 3.11, but on Win98 the GUS PNP uses the onboard ROM to play MIDI, different than DOS where it needs to load .PAT files, isn't that the case on 3.11?
