Reply 1880 of 2291, by SammaySarkar
- Newbie
Workaround regarding the topic of mounting ISOs:
In the Windows profile's Profile Editor,
- use your ISO mounter's mounting command as a "Command before main program" (in Helper Programs)
- and it's unmounting command as an "Extra Program File".
An example:
I have WinCDEmu. SO to mount play.iso, I would use the following as a "Command before main program":
"C:\Program Files (x86)\WinCDEmu\batchmnt.exe" "path\to\play.iso"
Then I would click "Extra Program Files" button and
put this in the "Filename" field:
and this in "Parameters":
/unmount "path\to\play.iso"
Suppose I put this in "Description":
Eject Game Disc
Usage:
- The mounter software will mount the necessary image before the windows game starts,
- and after exiting the game, just right-click the game entry and select "Additional Program File" -> "Eject Game Disc"
I've been happily using this method to run some Windows games via DFR for quite some time.
Of course this requires the same mounting software to be present in every PC D-Fend Reloaded runs in (if you are using the portable edition). I doubt there are many truly portable software of this kind available. (On a side note, mentioned WinCDEmu has a portable version but without commandline capabilities.)
