P55c at Overclocked to 300mhz?
Reply 190 of 237, by Markk
Never mind. I'm going to have a voodoo 1 instead. It's going to be fine.
btw, I've just connected it to internet by sharing the wifi connection of my laptop through the lan port, and it feels great to be posting on vogons on that old Pentium PC!
Reply 191 of 237, by Mystery
Just wanted to add some of my results I got while playing around with the 266 Tillamook I recieved recently.
Unfortunately the CPU will only work if I disable the L2 cache, which has a massive impact on the overall performance.
More Datails about that here: Re: Tillamook (in case you have a solution)
Fortunately, the CPU can be overclocked to crazy levels and the speed is so high, that the loss of the L2 cash is starting to diminish. Not by much, though.
Well, here are the specs:
The CPU runs at 440MHz. 110MHz FSB and (locked) mutliplier of 4.
Remember: All tests were run with the L2 cache DISABLED!
So if you want to compare them, run tests with your systems L2 (external) cache off to see the relative performance gain.
The board reports the CPU as a "Talimook" which is pretty hilarious.
Speedsys:
Sorry for the subpar image quality, but I just took some quick shots with my VGA grabber.
In case the values are hard to read:
Overall Score: 332.58 (between K6-2 266 and PII 300)
Memory Bandwidth: 330,42MB/s
L1 Cache Speed: 794,51MB/s
L2 Cache Speed: none 🙁
Memory throughput: 209,90MB/s
PCPBench
Final Score: 40,8FPS
Vesa Modus 100 @640x400x8 LFB
Quake 1.06 Demo1
75,0FPS
Especially Quake makes the lack of L2 cache quite obvious.
5u3 got 70,6FPS with a 300MHz P55C and L2 cache enabled.
That's just a 6% increase in performance but almost 50% more clock speed. Damn you L2 cache!
Now, imagine the results if someone figured out how to make the L2 cache available again. I'm not sure how high the performance increase would be, but I think applications like Quake would get a considerable performance boost.
FYI: The CPU cooler isn't even close to getting hot, even after a prolonged benchmark session. The system is benchmark stable even in Win98SE. So far only one application doesn't like the 440MHz and will refuse to work with anything above 420MHz.
Some applications get a significant performance boost from the increased clock speed (like the speedsys overall score), while others still suffer from the lack of L2 cache.
Shiny Benchmark is one example.
P55C Desktop at 100x2.5 will get a score of 114 in DOS.
The Tillamook (P55C Mobile) barely gets a score above 100 with the FSB set to 105 (420MHz) and the score is equal at best with 440MHz (113 Points).
Even though the results are sometimes far from spectacular, it still shows the enormous potential of the Tillamook. Unfortunately nobody has been able to run the CPU with the L2 cache enabled.
::42::
Reply 192 of 237, by sliderider
prophase_j wrote:
So from there, I contemplated strapping a Pentium Pro to a BX with one of those "slot-ket"s..
I'm guessing nobody picked up on this when it was originally posted. Was there such a thing as a slocket adapter that let you mount a Pentium Pro on it? I've never heard of one before.
Reply 195 of 237, by sliderider
I still want to see how the Tillamook compares to the Celeron 300A at 450mhz. Which should be faster?
Reply 196 of 237, by Mystery
I think even with L2 cache enabled, the Tillamook would lose, because the celeron has got the better architecture and memory throughput&bandwidth.
Against a Covington Celeron, it might have a chance, but only with L2 cache enabled and in certain applications.
If you take a look at the speedsys CPU score, the Tillamook isn't quite on par with the PII 300. As far as I know this score doesn't take any caching etc. into account. A Covington Celeron 266 will have a higher score than a PentiumII 233, even though the latter will wipe the floor with the Celeron quite easily. But the clock speed is higher and the architecture is the same, so the Celeron gets ahead.
The 266 Covington has a score of 305-310, which isn't that far from the 440MHz Tillamook, scoring 330 points. I might be wrong about the rating not factoring the L2 cache speed, but I think just raw processing power counts in this case, so the L2 cache won't help the Tillamook here.
Of course the Tillamook will get a huge boost in other applications with the L2 cache enabled, but I still think it's no match for a Celeron or PII at the same clock speed.
But getting an answer to your question shouldn't be that hard. Getting a P55C Desktop (with L2 cache *g*) to run at 300Mhz is absolutely doable, so that could be compared to the Celeron300A at stock speed. I think the Mendocino Celeron would win, even with the lower FSB. The P55C might give a cacheless Covington a run for its money, but with L2 enabled the P6 architecture is quite good.
::42::
Reply 197 of 237, by swaaye
In my 133mhz Challenge thread I ran a PPro, PII and PMMX. See sig. Results include Speedsys and Quake. This was a performance per clock comparison.
Reply 198 of 237, by Mystery
Alright, I'm digging this thread out again, because I did a little experiment with a bunch of CPUs I got.
I collected six 233MMX CPUs to see how big the differences in the required VCore settings were when trying to achieve 300MHz.
Well, I had seven, but one was DOA 🙁
There are a few extra CPUs here. Two 200MHz P55C, one 233MHz which seems to be defective and the 266MHz Tillamook I tested earlier.
(click for larger version)
While I expected some variation in the results, I wasn't quite ready for the huge differences in CPU quality I got.
I used this system as a base for the whole experiment:
Board: DFI P5BV3+. An excellent Super7 board, but the FSB only goes up to 100MHz and the highest multiplier is 3.5
I used quality SDRAM at the most insane performance settings
The GPUs used are a Matrox Mystique and a Voodoo1
OS was DOS with Win98SE
The cooler I used is a full copper low profile So754 cooler with arctic ceramique thermal paste.
DOS Benchmarks used:
Speedsys
Quake1 (demo1)
PCPlayer Benchmark
3DBench
Shiny Benchmark (perf_dos)
In Windows I just ran a quick round of the "four" benchmark in Quake3 Arena.
If a CPU posted, I could usually run all benchmarks in DOS except for Quake1. Quake1 usually took an .1 or .2 VCore increment. I've found the IO-Volt setting to have a very small effect on the overall stability, so I usually left it at 3.3V.
Even if the Quake1 benchmark finished, Windows was another hurdle. It often took another .1 or .2 volts to get a stable desktop and sometimes an additional .1 volt to get the Q3A benchmark to run without errors.
I tested various settings and ran benchmarks for each of them.
250MHz @3x83
250MHz @2.5x100
266MHz @3.5x75
285MHz @3x95
290MHz @3.5x83
300MHz @3x100
I quickly realized that the 83MHz FSB had some problems as the benchmark results were terrible and even the 290MHz was slower than the 266 @3.5x75.
I also couldn't boot into Windows with the 75MHz FSB, no matter what the multiplier and vcore setting was. I suspect it's a problem with the PCI raid controller I had installed since the 75MHz FSB reduces the PCI Bus speed to 30MHz. Just a theory.
Because every CPU was able to run at 250 or 266MHz without any problems and the 83Mhz FSB didn't offer reasonable performance I just tested the 285 @3x95 and 300 @3x100 settings on all CPUs for the required voltage.
Btw: The speedsys CPU score doesn't really tell you anything about the system performance in games.
Alright, first the benchmarks:
FSB is King! The P55C runs perfect @100MHz FSB and the boost from the higher FSB is much higher than a few extra MHz.
Look at the difference between 250MHz @2.5x100 and 266MHz @3.5x75.
Q3A isn't really a benchmark score you could compare, as the game runs at ultra low settings. It's just for testing the stability under Win98.
Now, let's get to the interesting part, the VCore settings.
I always started with the 3x95MHz setting at 2.8V, tried to see if it posted and if it didn't, I increased the VCore by 0.1V until it did. After the CPU posted I could usually run all benchmarks except for quake, which took another 0.1V. As mentioned before, getting Windows stable often took another 0.1 or 0.2V.
Most CPUs can easily reach 285MHz with the 95MHz FSB. If your P55C can't get to 300MHz and your board has both the 95 and 83MHz FSB available, go for the 285MHz @3x95 instead of 290MHz @3.5x83. It's 5MHz less, but it's still faster due to the higher FSB.
I often didn't have to fiddle around with the VCore too much, as I quickly reached a stable Windows.
Continuing with 300MHz, the picture changed. Getting the extra 15MHz often required a huge investment in extra VCore and even then some CPUs didn't reach a stable desktop. Since my board only offered 3.5V, I had to stop there.
Here's the chart:
For the CPU Model I just took the last digits of the number above the copyright so I was able to distinguish them from one another.
As you can see, there are really REALLY big differences, even at 285MHz. Two CPUs were able to run 285MHz with the default VCore, which really impressed me. The last CPU didn't even get an error free Windows desktop, although it was stable.
The 300MHz data is the most fascinating one. Two CPUs immediately crashed, even at the highest VCore setting. I suspect the first CPU would run with 3,7V, but the last one is just hopeless. You'd have to fry it with more than 4V to get a stable Windows desktop.
Now, two CPUs stand out. They both ran 285MHz with the default 2.8V setting and required REALLY low settings for 300MHz. One ran with 3.3V, which is pretty low compared to other CPUs in this thread.
But the other (fifth in the chart) is just insane. I couldn't believe it and had to check the jumper settings three times, but that monster ran @300MHz with the default VCore of 2.8V! I'm not joking!
I'm pretty sure I could run this bad boy at 350MHz with this board, but I honestly don't want to ruin the CPU by putting too much power through it.
The holy grail of P55C CPUs? (click for larger version)
I have made one observation which might be useful, but it might just as well be a coincidence, because I didn't have a lot of CPUs to test.
Most P55C CPUs have "MALAY" printed on the back, but both of the "high performers" had "A4" printed there instead.
So there you have it.
For high performance, get the highest FSB possible, even if the speedsys CPU score suggests lower performance due to less overall MHz.
The quality of the 233MHz P55C CPUs varies greatly. I'd say theres as much as 1V difference (or more) to get CPUs running at 300MHz.
I got 3 out of 6 CPUs to 300MHz with a stable Windows desktop and Q3A benchmark.
One was close (almost stable), one would probably just need an extra .2V and one is utterly hopeless.
And 1 or 2 of the tested CPUs have the potential to go to 333MHz or even 350MHz at "reasonable" VCore settings.
Oh and if you try to get to 300MHz you should use quality components:
The mainboard is probably the most important piece. Make sure it's got a divider to keep the AGP/PCI bus at 33MHz (or slightly above/below that). Older boards don't offer this feature.
Check for a high FSB. It'll give you higher performance at lower clock speeds and it ensures L2 cache stability.
Get a board with SDRAM support and quality SDRAM. If you have 133MHz DIMMs that are detected by the mainboard, you can usually run them at the absolute fastest settings possible. The older PS/2 EDO SIMMs and even slower SDRAM DIMMS might cause trouble when running the system with a high FSB.
Now, I'd really like to confirm my theory about the MALAY/A4 233MHz P55Cs. Maybe I'll buy some more CPUs, but it's getting somewhat expensive. 😉
Now, if you have any questions or would like other tests or benchmarks to be performed, let me know.
I'll probably try the 3rd CPU in the chart @3.5x95 and 3.5x100, but I'm not going to harm the one in the photo above, it's just too precious 😉
IIRC feipoa wanted some Quake2 benchmarks. Which settings and demo should I use to have results you can compare to yours?
::42::
Reply 200 of 237, by nforce4max
Who knows it may have existed at one time. I do remember reading several times that a DDR chipset was designed for super 7 but it ever went into production. Did it have agp 4x maybe but I would have to go back and hunt it down again.
Reply 201 of 237, by kool kitty89
DDR on SS7 would bit pretty pointless except maybe for multiprocessing . . . and the P55C was the last S7 CPU line to even support SMP.
OTOH extending SS7 chipsets to 133 MHz and maybe AGP4x would have made more sense alongside late-gen S370 boards, but as it is no SS7 chipsets or CPUs were ever rated for anything above 100 MHz, let alone 133. (though a handful of boards allowed overclocking to 133 with a 1/4 PCI divider)
It might have made sense for VIA to do that had they targeted S7 for the Cyrix III. (with the lower prices of S7 boards making more sense for such a low-end CPU, and the board-level L2 cache to compliment the 128k L1)
Reply 202 of 237, by nforce4max
kool kitty89 wrote:
DDR on SS7 would bit pretty pointless except maybe for multiprocessing . . . and the P55C was the last S7 CPU line to even suppo […]
Even SDR was a bit pointless considering just how slow the memory controllers were in all the chipsets produced for S5 and S7 when considering the bandwidth potential of the ram used. EDO has a bandwidth potential at 66mhz of 266mb/s but rarely achieved over 100-125mb/s. As for SDR it could have hosted two P55C with plenty to spare and could have gone quad if the memory controller was on par with 815E. In the end I am glad that AMD and Intel when for IMC over past designs.
Reply 203 of 237, by kool kitty89
Peak bandwidth also isn't going to get reached in real-world tests (even optimized benchmarks) unless the system caters to the specific operating parameters specific to the RAM in question. You'd need continuous burst/page-mode access to reach that (ie only accessing consecutive memory locations within the same page/row in the DRAM chips), and anything beyond that will incur significant performance penalties with latency from page-changes (change in row address). The greater the number of row changes, the greater the reduction in bandwidth. (granted, modern tricks like interleaved access to multi-bank DRAMs or multi-bank modules helps too)
So you've got limitations based on how software utilizes memory as well as the chipset and the CPUs themselves. (I think Cyrix's linear burst caching had more potential to approach peak DRAM bandwidth, though real-world examples would still be chipset and software dependent)
And you've still got timing parameters to consider on top of that. (moreso with EDO or -especially- FPM)
The performance gains in intel's Slot 1 and S370 chipsets obviously shed more light on how big a factor chipset performance is, comparing the various SDRAM based platforms of the time. (though, the same is true for comparing faster and slower systems using EDO DRAM)
On a related note, with the relatively weak SDR performance of SS7 boards, 50 ns EDO DRAM may have been a very good match for those 100 MHz chipsets. 100 MHz DRAM controllers would tend to mesh very well with the ideal timing (pulses) for typical 50 ns EDO chips. (maybe getting relatively close to the 400 MB/s peak potential of that RAM)
That would be something interesting to try out on an MVP3 board with SIMM sockets (like a VA503+) and compare that to performance of SDR on the same platform (as well as either types of RAM on slower buses), assuming the MVP3 chipset allows running EDO with a 100 MHz clock.
Interestingly, wikipedia specifically gives a 50 ns EDO DRAM timing example using a 100 MHz bus/controller.
Reply 204 of 237, by feipoa
I spent about 2 weeks reading this whole tread when the time permitted. It did not seem as if there was a clear answer on setting a 4x multiplier on P233 MMX chips. It was noted that the BF0 and BF1 pins should be shorted to set 4x. Another comment was to short BF0 and NC for 4x. RG100 tried both of these but did not check the actual CPU speed, for example, with Chkcpu or in Windows. He relied soley on the BIOS table look-up information at boot, which may not display the correct CPU speed if that speed is not in the table.
On the vintage-computer.com thread, there was much talk of running this 4x experiment, but nobody posted any photo evidence of 4x working on a non-Tillamook chip. Tetrium mentioned he was going to try this, but did not follow through in the vintage-computer thread.
I don't have any P233 MMX chips or S7 motherboards to kill for this test so I will not be trying this myself. Has anyone successfully run a P233 MMX at 4x and have photo evidence of it, for example, a CPU photo, chkcpu, and a benchmark? The best bet for this test is to try something modest, like 66x4 (266 MHz) at the rated voltage. It seems a lot of people who tried this 4x test were gunning for 300 MHz and above. Even 66x4 would might be of moderate benefit since you don't need to overclock the PCI bus for running the chip at 75x3.5.
Reply 205 of 237, by retro games 100
Good post, feipoa. One of my many regrets, and funnily enough one that popped in to my head only the other day, was to check the actual CPU speed, rather than to solely rely upon the BIOS POST look-up info table. At that time, my naivety on this subject got the better of me, and I didn't appreciate that that look-up table could state an inaccurate CPU speed.
Reply 206 of 237, by Tetrium
I know this is old, but I think this thread is very informative. I somehow ended up reading the entire thing and the A4-bit prompted me to have a look at my own MMX chips to see what the deal could be with these markings and their supposedly better overclock.
I don't have a testbench available at this time, but I did write down the markings of all the MMX chips I had stored in a couple trays and noticed a few things that might be of interest.
What I wanted to know, is if there was anything peculiar about the "MALAY" marking or the "A4", and apparently all the ones with the MALAY marking were made in a fab in Malay (big surprise there). The line below the MALAY line starts with an "L", which is the fab's code, and the ones with "A4" start with a "C" (indicating these chips were manufactured in the USA).
I found a webpage with information about the Pentiums here, it lists the fabs where any particular chip is produced.
Now I know the sample rate of only 3 A4 chips isn't much, but at first I thought perhaps these chips were better overclockers because of a later production date?
But it seems the A4 MMX's might simple be of better manufacture, which might make these better overclockers. Otoh, my oldest A4 chip (I only checked all my 200's and 233's and skipped the CPGA and 166MHz models) had a production date of 721 (1997, week 21, Pentium MMX 200) and the newest 838 (1998 week 38, Pentium MMX 233), while the oldest MALAY chip I had was from 726 (1997 week 26) and the most recent one was apparently produced in 037 (2000 week 37!). My 3 most recent chips also had a different font compared to all the other chips from either factory, dunno what the story is with that.
These 3 chips (date codes of the other 2 are 907 and 913) were all 3 made in the MALAY plant and have the same font used on all my Tillamooks (which apparently also were made in the Malay plant).
The superchip from Mystery has a date code of 818 (C818, the C is the plant code btw. Malay uses L), which may have been a more recent production date.
In theory, newer chips should be better overclockers.
Here's the list of all the MMX chips I checked (200MHz and 233MHz only)
Apparently all MALAY chips were made in the L plant and all A4 chips were made in C plant (perhaps I missed a single chip, but all of the chips I had my eyes on, followed this simple rule)
233 L907 (Tillamook font)
233 L037 (Tillamook font)
233 L913 (Tillamook font)
233 L808
233 L746
233 L726
233 L823
233 L726
233 L805
233 L805
233 L814
233 L805
233 C829
233 C815
233 C801
233 C838
233 C829
233 C836
233 C749
233 C733
233 C829
200 L804
200 L739
200 C731
200 C807
200 C722
200 C745
200 C721
My retro rigs (old topic)
Report spammers here!
Reply 208 of 237, by Tetrium
Jade Falcon wrote:
It doesn't tell us anything specific about that particular chip though.
Is this you btw?
Reply 209 of 237, by Rhuwyn
Interesting thread. Makes me want to checkout my PentiumMMXs I have sitting around. Don't have nearly as many as Tetrium but I believe I have a couple.
