Reply 20 of 25, by Horun
I agree that using older versions of anything may not be a good idea. Two people with same issue with DHCP.exe made me think about:
newer BIOS versions with dropped micro code, newer video drivers that give worse performance/crashes, etc so was just a thought. As I said "(doubt that will help but can't hurt...)"
Reply 21 of 25, by chinny22
kepak wrote on 2024-05-04, 12:33:
All utility software detects this card and i can change settings
This is a good sign and would seem to suggest more of a driver issue then hardware.
I'd probably stick with Win95 for troubleshooting, nice easy modorn-ish GUI
Which drivers are you using? I don't have any of the cards listed so can't give any known to work driver, but this here is a list for the complex card.
https://www.network-drivers.com/companies/237 … thx=9&bng=7&o=2
Also what are you using for a DHCP server. There have been some reports of newer devices not working with 10Mb cards.
Reply 22 of 25, by Grzyb
At this point, I suspect some weird incompatibility between that machine and NE2000-style cards.
It seems logical to try something completely different: 3Com, Intel, SMC...
Nie rzucim ziemi, skąd nasz root!
Reply 23 of 25, by kepak
Grzyb wrote on 2024-05-06, 05:37:
I think the same at the begining of this thread. I decided not to buy another card, i just pass networking this PC.
Reply 25 of 25, by Grzyb
Rwolf wrote on 2024-05-06, 12:30:
Do you have all voltages needed for that card on your ISA bus? Not sure what version you have of that card, TP or Coax?
Ethernet cards only need +5 V.
Yes, Coax transceivers need 9 V, but even this is provided from the +5 line, using a DC-DC converter.
Overall, if an SB-compatible sound card works, an Ethernet card should work as well.
