Reply 20 of 28, by Falcosoft
laios67 wrote on 2024-05-10, 11:32:
Hmm yes indeed same issue although in this case is windows xp . I'll see what is running in the background […]
Curiously I found a similar question about Max Payne 2 in an archived post at 3DRealms forum:
after a while...
I closed almost everything of background but the same
Separate background applications cannot cause such a problem since the x87 FPU precision settings are per-thread settings (the control word is saved/restored at context switches).
This error must be caused by a library that is loaded into the address space of the game's process either directly or indirectly and the library changes the x87 FPU precision settings.
Typically Direct3D changes the FPU precision to 24-bit all the time to speed up fsqrt/fdiv but games that use Direct3D expect this behavior.
So you should investigate about audio/video codecs and multimedia drivers that are loaded by the game's process instead of separate apps to find the problematic component.
According to this webpage Process Explorer 10/11 does work under Win9x so you can use it to determine what components are loaded by the game.
https://eternallybored.org/misc/procexp/
http://www.oldversion.com/windows/process-explorer-11-11
When you get the error message and the messagebox is not closed yet the game's process must be active so you can open Process Exolorer, look for the game's executable and select it.
Then check that View menu -> Show Lower Pane and View menu -> Lower Pane View -> DLLs are selected. Then at the lower pane look for libraries that are not from Microsoft and can be changed/uninstalled.
Website, Youtube
VST Midi Driver Midi Mapper
x86 microarchitecture benchmark (MandelX)
Reply 21 of 28, by laios67
oh thank you very much I'll check it and post results
Pentium III 1ghz Coppermine 750mb SBLive! Voodoo 3 3000 AGP
Compaq Deskpro Pentium III 933 EN 500mb Geforce4MX 440 AGP
Pentium 4 1.8ghz Northwood 500mb Voodoo 3 3500 AGP
Pentium 4 1.7 ghz Northwood 1gb Voodoo3 3000 AGP
Reply 22 of 28, by laios67
I used the proccess explorer and the only non-Microsoft library was from something called Power menu which I removed but the result was the same
Reply 23 of 28, by jmarsh
FFDSHOW.AX isn't from Microsoft...
Reply 26 of 28, by laios67
I unistalled ffdshow but neither this was the cause
Reply 27 of 28, by Duffman
Maybe Max Payne 1 needs an instruction set that your CPU doesn't support?
What CPU do you have?
edit: oh I see you have a pentium3
maybe try a different voodoo3 driver?
MB: ASRock B550 Steel Legend
CPU: Ryzen 9 5950X
RAM: Corsair 64GB Kit (4x16GB) DDR4 Veng LPX C18 4000MHz
SSDs: 2x Crucial MX500 1TB SATA + 1x Samsung 980 (non-pro) 1TB NVMe SSD
OSs: Win 11 Pro (NVMe) + WinXP Pro SP3 (SATA)
GPU: RTX2070 (11) GT730 (XP)
Reply 28 of 28, by laios67
I think this is indeed the only remaining cause , at the moment everything else worlks fine perhaps I'll try it in future
