16 bit ISA extender
Reply 20 of 29, by tony359
Very good points all around! I can't wait to do more tests! Thanks for now!
If a long IDE cable will work with a hard drive, it will work with your extender. IDE hard drives literally run the ISA bus down the ribbon cable. Electrically there is no difference between what you are doing and what a hard drive is doing.
But at a certain speed IDE requires 80 conductor cables. I guess that's not happening on an ISA IDE controller though?
My Youtube channel: https://www.youtube.com/@tony359
Reply 21 of 29, by kingcake
tony359 wrote on 2024-05-25, 21:23:
Correct. Here's the cycle times for UDMA modes:
The attachment Screenshot 2024-05-25 163335.png is no longer available
Frequency is the reciprocal of cycle time. ISA bus is going to be about 120ns.
Also, here's the spec on the absolute max an ISA card can pull on each rail. If you want to incorporate fuses of some kind.
The attachment Screenshot 2024-05-25 163120.png is no longer available
Reply 22 of 29, by tony359
Thanks for the power table, that's going to be useful for sure! Fuses sound like a very good idea.
Gotcha about speeds. So ISA is limited to ATA33 - as we all know - and more than that it's going to be PCI based, which also needs better shielding. Very interesting. Cheers!
Reply 23 of 29, by maxtherabbit
tony359 wrote on 2024-05-25, 21:06:
maxtherabbit wrote on 2024-05-25, 20:58:
This. I would not use the 80C IDE cables, I don't think ISA is fast enough that interspersing ground wires will be required.
Well I guess it wouldn't hurt?
It might hurt for the reasons mkarcher posted above
Reply 24 of 29, by tony359
Well, obviously I will design the connectors so that the pins are in the right place. I'm not thinking of just plugging 80 conductor wires ribbons in the existing sockets - which are 50 ways anyways. It needs a re-design of course.
Reply 25 of 29, by maxtherabbit
tony359 wrote on 2024-05-26, 17:41:
Yes of course as long as you mind the ground pin and presence detect pin concerns it would be perfectly fine
Reply 26 of 29, by Bjlled
I’m looking at doing this… did you get anywhere with success??
Reply 27 of 29, by tony359
yes and no.
The extender worked once I wired the POWER lines using proper cables. Then I decided NOT to improve on that design and I just made a simple 16bit 90 degrees adaptor.
https://www.pcbway.com/project/shareproject/1 … r_175d8c84.html
(the project is free to download. If you order through PCBWay I get 10% I think - just to be clear).
If you're interested in the original project, I could upload it on github - Honestly I think that if you used a decent ribbon cable, it would work. Mine was VERY flexible, indicating very small conductors.
Ideally you'd want to wire the power using a power connector, problem solved. But also soldering some wires works.
Reply 28 of 29, by ia2115
@tony359 if your "simple" isa angle jig coult be "extended" like 2cm for measuring points for A and B side of the actual ISA bus this would be insane valuable 😀 like the empty 8 bit necroware card with loads of "easy testpoints" for every finger of the isa slot.
regards
jan
Reply 29 of 29, by tony359
Sorry, I missed your message 😀
You mean a longer PCB? If that's what you mean, the issue is that the board you're testing would then "fly high" - fair enough, you can add a wedge under it but as it is right now, you need something pretty thin to rest the board. If I extended the PCB 2cm, then you'd need a bigger "wedge".
Or maybe you just mean to extend the PCB OVER the connector so it can host test points? In that case I'd be concerned about reflections and signal integrity. I think as it is, the adaptor is "ISA compliant" (I believe the white paper allows 2.5cm of extension) but if I add traces which end up nowhere, that might have RF interferences consequences?
Am I understanding your point? 😁
Thank you!
