Options for a bad oscillator?
Reply 20 of 22, by darry
Scouring service manuals for designs (poosibly starting with genlock capable devices or maybe timebase correctors) using a potentially compatible part might yield a list of potential donor hardware which might be available relatively cheaply.
I realize that this would be lots of work for a long shot
Reply 21 of 22, by rasz_pl
yourepicfailure wrote on 2024-05-31, 04:34:
Thank you, these are a good start. In theory, there is enough real estate to toss in a small 3.3 reg. I did measure and that the crystal's peak output is 3.3v, so I might be able to get away with that.
its the VCO IN that is more interesting and might be the main problem when substituting this part. Put a scope on that and see if its fluctuating at all, and at what range its operating.
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 22 of 22, by yourepicfailure
The VCO in pin hovers +/-.2 v around .8v
