Reply 20 of 25, by PC@LIVE
berion wrote on 2024-06-22, 23:50:
Ok I'll buy a 100 MHz Coppermine as the one I tried before was a 133 Mhz 866.
We'll see what happens. Thank you for all your help and support.
So, I'm pretty sure that if you find the right combination of HW, the card will work.
I think you are using the wrong components, and even if they work, they hardly work in that MB, you can do all the tests you want, but the result will always be the same, i.e. it doesn't start and no post code.
That is a Mendocino or Katmai CPU board (or how are they spelled?), you can try all the Coppermines you want, but they are electrically incompatible with the S.370, vice versa, if it was a Coppermine board, the Mendocinos also work, mine advise?
Buy at least one Celeron Mendocino, you should find them for cheap, if you're lucky, and find someone who has several, you can get some for the price of a pair (or could you even give them away?).
Then when the card is working, you can see if it works with Coppermine, if you skip this step, you will never know if it works, and all subsequent attempts could give the same result, moreover I think that by finding the right combination of working HW, you will be able start doing something with it, I imagine you'll want to play DOOM for example or simply load Windows 98 on it, and for that a Celeron 366 or 500, it doesn't make much difference, actually a 300A you can easily make it work at 450, and it would work more or less like a PII 450.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 21 of 25, by berion
PC@LIVE wrote on 2024-06-23, 07:06:
So, I'm pretty sure that if you find the right combination of HW, the card will work. I think you are using the wrong components […]
Thank you! Per the boards manual, it supports Coppermine so I went on eBay and got a slower Coppermine and a Mendocino Cel per your advice. We'll see that happens when they get here.
Cheers!
Reply 22 of 25, by PC@LIVE
Ok maybe with a little luck, one of the CPUs might work, and I think that's likely.
Greetings
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 23 of 25, by berion
Update: Mendocino Celeron 400 did not post either. No codes. The only other thing I’m gonna try is do a hot swap do the bio chip with another motherboard I have and try to reflash it. Maybe it’s corrupted.
Reply 24 of 25, by Deunan
berion wrote on 2024-07-02, 16:35:
Do you have a scope? Or at least a somewhat decent volt meter? You can check for activity on BIOS ROM pins. If you see some weird (not close to 0V, not close to 5V either) voltages it usually means there is a signal there and you are seeing the mean DC value of that. It would tell you that CPU is trying to execute something from the ROM so it must be running, and that most likely both mobo bridges are OK (at least not completly dead).
These mobos often store some PnP config data in the Flash and if the write goes wrong it (like a power-off or reset happens right at that moment) can erase part of the BIOS code. I've seen that in the past and I've just brought back such a mobo from the dead by reflashing the BIOS in external programmer a week or so ago.
Reply 25 of 25, by berion
Hey There! In these 2 weeks' time I was able to replace the BIOS chip with a freshly flashed one. Unfortunately, I'm still not getting POST and not getting any codes on the POST card. I am starting to think there's something seriously wrong with this board.
