Reply 20 of 22, by vanfanel
Cyberdyne wrote on 2024-07-22, 15:31:
UMBPCI + HIRAM + HIMEM + if needed EMSMAGIC. This confoguration works for me for most DOS games. Only Windows 1.x/2.x somehow do not like the EMS that emsmagic provides.
Sounds good, but here on the Vortex86, I get when UMBPCI is loading:
"The chipset is unknown!"
And "mem" reports:
Largest free upper memory block 0k
So UMBPCI is not working (it should give way more UMBs, right?)
Then, if I install HIRAM, with the results that can be seen on the attached screenshot, "mem" reports:
Largest free upper memory block 8k
Finally, if I load, let's say, "EMM386 /NOEMS" instead, I get:
Largest free upper memory block 135k
Then, with 135k UMB, I can load emsmagic and it will load in UMB as intended, BUT it hangs while detecting audio, which is what motivated this thread in the first place.
Reply 21 of 22, by vanfanel
In the end, it was fixed by loading SMARTDRV in CONFIG.SYS like this:
DEVICE=C:\DOS\SETVER.EXE
DEVICE=C:\DOS\HIMEM.SYS /TESTMEM:OFF
DEVICE=C:\DOS\SMARTDRV.EXE /DOUBLE_BUFFER
DEVICE=C:\DOS\EMM386.EXE RAM I=B000-B7FF
DOS=HIGH,UMB
FILES=30
Yep, SMARTDRV was the key to bring the compatibility up to pair with the Vertex86 DX!
Lemmings 2 works, Elder Scrolls: Arena works, etc.
Reply 22 of 22, by wbahnassi
Right, that to me confirms its a memory layout quirk in the Vortex86, and SMARTDRV -being the fatso driver it is- is changing the layout in favor of the game.. it's a lucky find I'd say.. so yeah, maybe you should buy a number or two from the lottery 😅
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
