Reply 20 of 60, by butjer1010
PcBytes wrote on 2024-08-05, 13:31:Let's see. None listed in order. […]
- ABIT BE6-II HPT366 - best Slot 1 I could ever ask for. Proper 133FSB operation, lotsa IDE to work with, overclock options galore.
- Soyo 6BA +IV - sort of an indirect sibling to the BE6. It can't really overclock due to the PLL chip used, but has almost never crashed.
- Luckystar 6BX2 - small AT board that has a lot of potential with a BIOS mod. VRM is totally Coppermine compatible, but BIOS never had a chance to get the support. Patched my BIOS and it runs great.
- Gateway Tabor 3 - built upon the WS440BX, this thing is literally A TITAN. I mean it - only the ABIT and Soyo have come as close as being that rock solid.
- ECS K7VZA - neat, cheap and stable KT133A mobo, as long as you were using Shuttle's version of the BIOS (ECS' BIOS was just crap, period.). Have ran Windows ME on it with zero crashes... on an IBM Deskstar 20GB (60GXP) no less. (although I assume the 60GXP is one of the metal platter Deskstars, similar to the 34GXP I own)
- ECS K7S5A - neat small OC gremlin once recapped and flashed with the right BIOS. Mine sports Rubycons and polymer caps as of speaking.
- ABIT NF7 and NF7-S v2.0 - great boards (one is without SATA), Taipan BIOS does wonders with a mobile chip
- Soltek SL-75FRN2-RL - almost the holy grail of nForce 2. Forget the mess that is A7N8X, this is one of the kings, along with the NF7 and DFI's Lanparty NF2 Ultra B. Took me almost a decade to find a working one, it now paid off.
- ASRock P4Dual-915GL - microATX monster that can expand your GPU horizon greatly. Did I mention that thanks to the 915 chipset, it runs HD7800/7900 cards?
- ASUS CUSL2 - one of the few great ASUS boards, long before their quality took a plummet into the ground worse than Mayday. Like seriously, their later 775 boards (945 onwards) quality were worse than ECS.
- ASUS P5P800 and ASRock 775i65PE - neat 865 based 775 boards. Unfortunately both are limited to P4 and Pentium D as far as I remember, at least in ASRock's case.
- FIC P4M-RS350 - very interesting microATX mobo, with an onboard Radeon 9100. Found one OEM'd by Medion (which I fortunately managed to flash back to FIC). Depending on what CPU you have, different splash screens appear - I currently replaced the one for Celeron but might have to work something up for P4/P4HT as well.
Yessss..... My NF7 + Athlon XP Mobile 2500+ worked on 2.6GHz!!!!! Uuuuuuu, that was the best board of all time 😀
