MSI 694D PRO bios request
Reply 20 of 28, by Mamba
So we have two things:
A) knocked out capacitor spotted by you
B) the IC is super hot, not sure it is related.
Both things are near cpu1, unexpected.
Reply 21 of 28, by nhattu1986
Mamba wrote on 2024-09-24, 14:55:
So we have two things: […]
Also i notice the choke near the cpu1 slot is discolor which mean it kind of get very hot
Also which cap did you replace? I can't see the label so i'm not sure if they are original or not.
The attachment Screenshot_2024-09-24_22-03-03.png is no longer available
Reply 22 of 28, by Mamba
nhattu1986 wrote on 2024-09-24, 15:03:
Also i notice the choke near the cpu1 slot is discolor which mean it kind of get very hot Also which cap did you replace? I can' […]
Yes it was getting super hot before the partial recap.
Those are recapped and now the choke is ok.
Reply 23 of 28, by Mamba
For clarity, here the motherboard before recapping, marked are the four caps replaced.
Same specs as original
Reply 24 of 28, by nhattu1986
Mamba wrote on 2024-09-24, 15:14:
I think you should also replace those black cap since they are most likely bad inside even if they don't budge yet.
I bet their internal resistance is increase which is the reason why the Diod D10 get hot
Reply 25 of 28, by soggi
As @nhattu1986 said, I would also replace all ECs, at least all of the same type, especially in the VRM region.
Mamba wrote on 2024-09-24, 14:24:
There is an IC in D12 position (under cpu1) that gets incredibly hot.
I do not know if it is an indication of something.
@nhattu1986 already said that Dxx is a diode, an IC (integrated circuit) would be Uxx, Cxx is capacitor, ECxx is electrolyte capacitor, Rxx is resistor...did I forget something!?
...since you recognized that no dual configuration works I also thought "bad caps" which can serve one but not two CPUs.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 26 of 28, by Mamba
soggi wrote on 2024-09-24, 16:37:
As @nhattu1986 said, I would also replace all ECs, at least all of the same type, especially in the VRM region. […]
...since you recognized that no dual configuration works I also thought "bad caps" which can server one but not two CPUs.
kind regards
soggi
Thank you.
Seems like this motherboard will have some iron again.
Not sure it will ever handle two Tualatin, but will hopefully overclock two Coppermine-T.
Reply 27 of 28, by PC@LIVE
If the problem is that the motherboard does not support Tualatin, I can tell you that some motherboards, although in theory they support them, in reality do not work, I have an ACorp 815 which with modified Tualatin (Korean) does not work, from what I understand , has something different in some PINs, there are two things, either it doesn't work because it needs further modification, or it doesn't work at all.
I think it's the same with LIN LIN adapters, it might be possible that adapters like Upgradeware or similar might work instead (maybe?), but I think it's both difficult and expensive to find one, two will be very difficult.
However, if there is someone who has managed to make two Tualatins work, perhaps he has made a HW modification, if it is explained exactly what he modified, and with the necessary soldering skill, it could be evaluated whether to modify the board.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 28 of 28, by soggi
Mamba wrote on 2024-09-24, 18:38:
Thank you.
Yes, go for it, I wish you success! 😀
kind regards
soggi
