Reply 20 of 34, by myne
Hmmmm
Some candidates.
[HKEY_LOCAL_MACHINE\DeadNT\ControlSet001\Services\Abiosdsk]
"Start"=dword:00000004
"Group"="Primary disk"
[HKEY_LOCAL_MACHINE\DeadNT\ControlSet001\Services\Atdisk]
Start=4 = disabled.
Load registry on one of the 2 drives
Change to start=0
put in OG machine
test
This Dell one is also a candidate
[HKEY_LOCAL_MACHINE\DeadNT\ControlSet001\Services\Delldsa]
"Group"="SCSI miniport"
It's very weird that it only has 4 set to 0
[HKEY_LOCAL_MACHINE\DeadNT\ControlSet001\Services\atapi] (cdrom)
[HKEY_LOCAL_MACHINE\DeadNT\ControlSet001\Services\Disk] (filesystem)
[HKEY_LOCAL_MACHINE\DeadNT\ControlSet001\Services\intlfxsr] (no idea)
[HKEY_LOCAL_MACHINE\DeadNT\ControlSet001\Services\PowerSwitch] (duh)
I built:
Reply 21 of 34, by kmeaw
NT4's atapi.sys is the IDE port driver (also used for hard disks), the cdrom is called cdrom.sys. intlfxsr is a driver that enables CR4.OSFXSR to do fast context switches on CPUs supporting SSE instructions, abiosdsk is for disk controllers connectred to MCA running on an IBM machine with ABIOS firmware.
I'm not sure what atdisk is.
Reply 22 of 34, by V0LDY
myne wrote on 2024-10-24, 14:59:
Hmmmm Some candidates. […]
Hmmmm
Some candidates.
Sorry but my level of knowledge is not that high, so I'm a bit lost and I need to understand.
What are we looking at exactly? Are those registry keys telling the bootloader which device should be accessed at boot?
Also, how could the problem be in the registry file? AFAIK nothing could have possibly changed there since I just plugged the drive into another PC to clone from it.
I've copied all the content from the image of the original HDD's main partition to the the main partition of a virtualized NT4 install I had done previously, and it works. Heck, I even tried to recreate the same 2 partition layout of the original computer and that also seem to work, despite me using W11 disk mangement to patition the VHD. I'm so puzzled.
Granted, there might be some Virtualbox trickery going on that makes it work, but I'm still more inclined to believe the problem is outside of the main partitions otherwise I should have gotten the same "INACCESSIBLE_BOOT_DEVICE" error, no? After all the image of the disk was done after I had already plugged it into another PC, so it should carry the same errors.
Reply 23 of 34, by myne
Well if you're going to just copy files, make sure you keep the registry at least.
It's those files without extensions.
System etc
I built:
Reply 24 of 34, by Mondodimotori
V0LDY wrote on 2024-10-24, 18:31:
Sorry but my level of knowledge is not that high, so I'm a bit lost and I need to understand. What are we looking at exactly? Ar […]
Then it goes back to an issue I have pointed out elsewhere: The BIOS settings (and prolly a dead CMOS battery).
Because if nothing is damaged or changed in the original disk image, and it works in a virtual machine, then I don't know what the issue could be apart from settings on the machine itself, unless the fuckery that may have happened in the boot loader causes issues only on the OG machine.
Also, I've sent you a private message on facebook the other day, could you check it? (prolly went lost in "messages requests"). I didn't ask it publicly because they could be more private informations.
Reply 25 of 34, by V0LDY
Nope, BIOS is rock solid, even bringing the computer back home it didn't lose anything. I took a photo of each page just in case the battery dies on the return trip, but it seems to be mostly standard configuration.
Btw, I managed to bring back the system online complete with the 2 partitions doing what I did to the VM: I reinstalled Windows NT 4, updated it with the service pack, then I've connected it to a modern computer (this time with an USB adapter I just bought and not directly using an IDE cable), deleted all the files (at least the visible ones, see below*), copied back the files from the backup image and it seemed to boot just fine, the software that matters says it can't find a directory but I'm pretty sure that was on the network so it should work once it's connected again.
I haven't had the opportunity to see if it works with the machinery, but so far it seems promising.
*Here I've noticed something weird, mounting the image file I've created with Macrium I can't see some of the files needed for NT 4 bootloader to work (specifically ntldr and NTDETECT.COM) are missing. And I can't see those files either in WIndows even if I access the drives that are now working. Even enabling "hidden files" it seems that that some stuff is just hidden no matter what. Same goes for accessing the virtual drives, if I attach them to a Linux VM everything is displayed including ntlr etc, but not in Windows. Now that might be common knowledge, but I was still puzzled by that.
When I'm deliting stuff from the Working NT4 install it means I'm just deleting the "visible" files and replacing them with other "visible" files, not sure how many are't actually being displayed (and deleted/replaced), but it might actually be a good thing since it's booting.
And speaking of Macrium, there I might have made a mistake, I didn't check the advanced option and used the default "Intelligent sectory copy" instead of the "Make exact copy" which should be a 1 to 1 clone suitable for forensic examination etc. Now, I'm not sure if the files are present or not in the Macrium image (for sure I can't see them in Windows), but that might explain why the cloned disk didn't work. I say might because it's still suspiscious that the error was the exact same as the one I got from the original drive, so it's possible it occurred before the cloning and that it carried over to the image.
That said, I'd still relly like to know WTF happened to the original drive, I've now connected it to a linux pc and everything seems to be there (including all the files that might be missing from the image).
I'll now try and see if I can create a proper image to feed to the VM and see if it boots or if it will give me the same INACCESSIBLE_BOOT_DEVICE error.
Another thing I might to reinstall Windows 4.0 from scracth onto another drive and connect it again to the computer that seemingly made the original drive unreadable, just to see if it happens again.
My guess at this point is that somehow the MBR got fckd up, apart from that I really dunno.
Reply 26 of 34, by myne
So... Somehow ntldr was deleted from both images?!
Do you have a wayward virus scanner?
Check logs maybe?
Theory: drive inserted, virus scanner quarantined ntldr and Co, macrium did as expected but the files were gone.
If that's the case, just copying ntldr and co back to the original drive will fix it.
Ntfs is pretty good like that. You don't need special sectors. Just the files there. It's entirely possible to just format as Ntfs and copy across.
It is weird you got that error though. I would have expected "ntldr missing".
I built:
Reply 27 of 34, by V0LDY
myne wrote on 2024-10-26, 13:47:
So... Somehow ntldr was deleted from both images?! Do you have a wayward virus scanner? Check logs maybe? […]
Check logs maybe?
I'm not sure ntldr is in the images or not. Macrium allows me to mount the image as a virtual drive on Windows, and from Windows I can't see it, but that might be Windows problem, not an issue with the image itself.
Right now I don't have any disk burned with the Macrium image so I can't check, I might see if I can restore the image to a VHD, in that case it should be visible if I then open the VHD on Linux.
Btw, I attached the original drive to a Linux system and all the files are there. As I said, in theory I never did anything to that drive!
___
Edit: ok, I've now restored the Macrium image to a VHD and the virtual machine f*ing worked.
Like, not even a fuzz, it just straight up worked.
I modified the 4Gb VHD my NT 4 virtual machine used, resizing it to 115Gb in order to fit both the partitions from the Macrium Image, I wiped it with DISKPART on Windows 11, then I just mounted the VHD and I told Macrium to restore the original disk image to that.
Detached the drive, attached it to the VM, ran it and it worked.
I'm just so confused.
Obviously once inside NT4 everything seems to be in place, includint ntldr etc otherwise it wouldn't have booted in the first splace.
I'll now try to restore it again to physical drive, maybe the "clean" command with DISKPART is the key? I'll let you know!
Reply 28 of 34, by Mondodimotori
V0LDY wrote on 2024-10-26, 13:28:
Nope, BIOS is rock solid, even bringing the computer back home it didn't lose anything. I took a photo of each page just in case […]
That's actually a relief.
But maybe something REALLY happened when you hooked it up directly to the modern machine.
That could be it! I actually didn't even consider that the antivirus on the modern PC could be the culprit. I'm so used to running windows defender by itself that I completely stopped thinking about the old kind of intrusive antivirus softwares.
Something really happened right in that moment between connecting the HDD to the new PC and starting the backup process.
Reply 29 of 34, by V0LDY
I'll give an update tomorrow once I have the confirmation everything is working again (including the machinery), but apart from that I might have some interesting new developments I'll share for the curious ones.
Reply 30 of 34, by V0LDY
Ok, I finally had the chance to test the computer with the machinery and it all worked fine.
What I also found out is that somehow, if I used another computer with an USB/IDE adapter to clone the very first image I've made to a drive it worked on ther old PC without any issue.
Granted, I've cleaned the drive with DISKPART before cloning, but it's so weird because that image was created with the computer that created all the non working drives.
Because yes, in the end I narrowed it down to the computer I used initially to clone the drive.
I had two different USB/IDE adapter I wanted to use initially to clone the old drive, one turned out to have a dead PSU, the other one had a capcacitor that literally exploded when I plugged it in.
I've then used an old PC I had lying around which had both IDE and SATA ports to create the image with Macrium, I just connected the old IDE drive to the IDE cable and cloned it on Windows 10 installed on the SATA SSD.
Well, apparently both the IDE drives (the original one and the newer with the cloned NT system on it) stop working on the 1998 computer if they are plugged into the "intermediate" computer I've used to create the image. The image itself was perfectly fine tho, and that's what I've used to restore the system, but somehow it just "breaks" the drives for the old PC.
Any idea for why that could happend? At this point I don't even need that old PC anymore since I have the new USB adapter, but I was curious to try and understand what could have caused all this trouble.
Would this have happened on any other computer just by plugging the drive directly into an IDE controller or was it my specific computer doing something weird? It feels strange to me that Windows would handle the drive differently (or make any modification to it) depending on how it is connected.
Reply 31 of 34, by piarman
hello!
When connecting a 20GB hard drive to Win7 with WinNT 4.0 build 1381 SP3 and reading disk images .imgc and .img with Hdd Raw Copy 1.20, it stopped working with the error 0x0000007b Inaccessible boot device. We found out that in sp3, the old atapi.sys and ntfs.sys cannot work with sectors larger than 7.8GB, and there are 2 sectors on the hard drive, 15GB and 4GB. Replacing these drivers with those from the SP6a update (which can handle partitions larger than 7.8 GB, such as atapi. ntfs can read version 3.0 of ntfs, and Win7 has changed it from 1.2 to 3.0) .
In the system hive (which is located in the system32/config folder), there was a missing partition in the root of the hive called Disk, which was located in the system hive in the old folder (a copy of the system from previous years). on the hard drive, there is a table of values where, in addition to the geometry, the signature of the known hard drive (4 bytes: 63 16 66 F6) is specified at offset 0x1b8 in the MBR of the hard drive. By exporting to a .reg file and then importing it into the hive, I added this Disk partition.
+ I corrected the mbr to NT5 and the pbr to NTLDR in the Bootice 1.3.4.0 program. Win7 changes NTFS to 3.0 instead of 1.2.
Note: If you let the hard drive communicate with WinNT and then reconnect it to Win7, Win7 will not see the partitions, the CPU will load up to 50%, and the system process will remain loaded even after disconnecting the hard drive (when connected via IDE, Win7 will not even load). In this case, I connected it to Win10, and Win10 saw the errors and fixed them in a minute. I performed all operations using the Agestar FUBCP2 usb-to-ide adapter.
The attachment Atapi and ntfs from WinNT 40 b1381 SP6a.zip is no longer available
attachment%5D
attachment%5D
attachment%5D
Reply 32 of 34, by piarman
The main thing is to change the atapi.sys and ntfs.sys files, replace mbr and pbr through Bootice, and add the Disk partition to the registry.
Reply 33 of 34, by piarman
Export: "Disk" from System Hive
.reg
The attachment Export Disk from System Hive.zip is no longer available
Reply 34 of 34, by myne
So... When you're cloning, you are making the partitions larger?
Yeah, don't do that. 1:1 copy, leave the blank space and if the bios detects it, it should all be in a compatible location.
00000000000f234
Is the same as
00000000000000000000000000000000000f234
So it shouldn't matter as long as it is all in the same location it was.
I built:
