Reply 20 of 25, by DaveDDS
Hamby wrote on 2024-11-22, 09:51:
DaveDDS wrote on 2024-11-21, 03:48:
Sorry ...
I'm sorry ...
My god .. are we BOTH Canadian? 😀
As mentioned in my previous post look at the DDLINK sources ... talking to LPT hardware is very easy
(mainly just IN/OUTs to the LPT addresses)
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 21 of 25, by Hamby
jakethompson1 wrote on 2024-11-21, 02:20:
Here is an overview. We're assuming it's a bare-bones, output only parallel port. For LPT1: your data port (output) is 378h. Wha […]
Hamby wrote on 2024-11-21, 00:54:
Thanks but I was thinking more in terms of parallel coms, not serial coms 😀
For LPT1: your data port (output) is 378h. Whatever you put there goes to pins 2-9 of the parallel port.
Your status port (input) is 379h. The bits in it are 0:reserved, 1: reserved, 2:IRQ, 3:ERROR#, 4:SELECT, 5:PAPER_OUT, 6:ACK#, and 7:BUSY#
For more detail, https://wiki.osdev.org/Parallel_port
Assuming your LapLink cable has standard pinout, bits 0 through 5 go to pins 15(ERROR#), 13(SELECT), 12(PAPER_OUT), 10(ACK#), and 11(BUSY#) on the other side. Now we see the reason for the pinout. So, whatever we write to the output port is shifted to the left by 3 bits at the status port at the other end. Despite a few of these status lines being marked as active-low, it is only BUSY# that appears inverted at the other side, when using a null-printer cable (https://bitsavers.org/pdf/ibm/pc/pc/6025008_P … rence_Aug81.pdf p. 2-68).
The other piece to mention here is that when set up properly, the parallel port will generate an IRQ 7 on the proper transition of the ACK line. That allows your nibble-mode parallel port code to transition between idling and intensive bit-banging polling-mode operation. The latter is needed when exchanging nibbles to make it fast. It is a per-nibble, stop-and-wait protocol between the two sides. Another general rule is to not accept the value of the status port until it doesn't change on two consecutive reads (and you might have some number of microsend delay on reading it too).
You could review the Linux plip_send for an idea: https://github.com/torvalds/linux/blob/master … lip/plip.c#L710
Basically the sending protocol there is:
  1. Place the low nibble on bits 0 through 3 of output and set bit 4 to zero. Then flip bit 4 from zero to one. This causes the BUSY# line to transition from one to zero on the opposite end.
  2. Continue reading from the status port until bit 7 (BUSY#) is zero, meaning that the other side has set bit 4 to one on their end, acknowledging the incoming nibble.
  3. Place the high nibble on bits 0 through 3 of output, continuing to leave bit 4 set to one.
  4. Flip bit 4 from one to zero. This causes the BUSY# line to transition from zero to one on the opposite end.
  5. Continue reading from the status port until bit 7 (BUSY#) is one, meaning that the other side has cleared bit 4 on their end, acknowledging the incoming nibble.
If you look at plip_receive, line 484, it is symmetric. Wait until status port until bit 7 clears, then grab bits 3 through 6 as the low nibble. Set output port bit 4. Wait until status port bit 7 sets, then grab bits 3 through 6 as the high nibble. Clear output port bit 4.
Aside from that, the complexity is in the state machine and all in the timeouts, checksums, and other error handling (like collisions) and in triggering the interrupt on the other end when needed.
As you can see at line 859, the implementation idles by writing zero to the output port (so status port bit 6, ACK#, rests at 1), and on line 777, wakes up the other end by writing 0x08 to the output port (causing status port 6, ACK#, to transition from 1 to 0 at the other end, generating an IRQ and waking it up).
is there any reason this couldn't be adapted to talk to the gpio pins of a raspberry pi or arduino?
Reply 22 of 25, by jakethompson1
Hamby wrote on 2024-11-22, 23:18:
I'm not sure. I'm interested myself for a few reasons. One is an open source parallel port Ethernet adapter like used to be common for pre-PCMCIA laptops. Another is a "reverse JetDirect"; i.e. a little Linux box that hooks to the parallel port and runs CUPS, and has converters for several languages (PS, PCL, Epson 24pin, Epson 9pin, IBM Proprinter) and routes jobs you send to it to Ethernet. You could also do a parallel port disk this way.
How many GPIO pins are there? Remember there's all these pins to deal with. And are they designed for 5 volts?
Reply 23 of 25, by jmarsh
They can easily talk to a 5V Arduino. If you want to talk to a MCU with 3.3V pins, you can use signal diodes (pointing towards the LPT port) with the GPIOs configured for built-in pullups.
Back in the day it was common for EEPROM programmers (both professional and homemade) to just be a few logic latches connected to the parallel port. GAL/PAL programmers too, since they're basically just a serial stream with a clock.
Reply 24 of 25, by BitWrangler
I was thinking, "Hey, didn't Tandy make a parallel port floppy drive, the 25-1087, so Tandy ports should be bi directional right?"
Umm yeah, not that simple I guess...
https://www.youtube.com/watch?v=BrPHgUJjkQo
Reply 25 of 25, by DaveDDS
I don't see why not... Over the years I've built LOTS of things that attached
to the parallel port, including such things as:
Some "Specialized Test Equipment", some with embedded microprocessors which
have fast signalling to the PC via GPIO<>LPT
"Eprom Emulator" - basically a static RAM chip in a powered carrier which could
be written/read by the PC (I used resettable counters to drive the address
bus on the PC side). After it was programmed you could remove the carrier
from the programmer (attached to parallel) and put it in the test device as a
ROM.
"Halloween Display" - in addition to scary pictures (Monitor in window) and
sounds (speakers in two of the talking pumpkins), there were controlled
hardware things like lights (LED-eyes & lights in pumpkins, spotlights etc.) and
motors (Bat flying on string, Coffin opening/closing etc.) - all controlled with
hardware I built that was controlled via the parallel port.
