BIOS chip for PCChips M912 (486 Socket 3)
Reply 20 of 23, by Tigre978
I just read a "manual" that says that using jumper JP2 I can select which BIOS I want to use, AMI or Award, but for that the chip must have both BIOSes. And what about writing the BIOS file twice? Why is that and how do I do it? I have the T48 programmer.
http://www.elhvb.com/webhq/manuals/486vlb3/m912v17.zip. I got the manual from here that says about the JP2 jumper.
Reply 21 of 23, by analog_programmer
Tigre978 wrote on 2025-03-23, 17:54:
Because with the JP2 you set address space used in the 128 KB ROM chip. For Award BIOS you can use W29EE512 EEPROM instead, which is 64 KB in size, so not bother to write two 64 KB BIOS images in EEPROM's "low" and "high" address space.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 22 of 23, by Tigre978
In this thread Re: PC Chips M912 BIOS update for Am5x86 and Cyrix 5x86 I have seen that with an Intel P28F020-150 chip I can put both AMI and Award bios, which bios do you recommend, the AMI, the Award or the dual bios? I don't know which is better for this motherboard, also I am having a problem and it is that it does not let me load DOS from the Floppy and I do not know what it is due to besides a keyboard error, so I do not know if the higher version of Award fixes it or if the AMI is better
Reply 23 of 23, by analog_programmer
Tigre978 wrote on 2025-03-24, 00:20:
analog_programmer wrote on 2025-03-22, 23:28:
I've replaced the factory OTP-PROM chip with Winbond W27C010 EEPROM which is compatible with AMI BIOSes, 'cause it turned out that newer W29EE011 chip only works with Award BIOSes for this mobo.
I prefer the last Award BIOS modified by Jan Steunebrink, which is available in the very same thread you linked.
