286 Headland HT12 Mainboard Replica
Reply 20 of 63, by douglar
Might be of interest in this thread--
http://66.113.161.23/~mR_Slug/chipset/c ... =8735#8735
**HT11          Single 286 AT Chip [no datasheet]               <Aug90...
**HT12/+/A Single 286 AT Chip with EMS support c:Aug90...
**HT18 80386SX Single Chip c:Sep91...
**HT21 386SX/286 Single Chip (20 MHz) c:Aug91...
**HT22 386SX/286 Single Chip (25 MHz) c:Sep91
Reply 21 of 63, by feipoa
I did'n t know about the HT21/HT22. How's overclockability with the HT22?
Reply 22 of 63, by douglar
feipoa wrote on 2024-12-18, 22:00:
Still looking for a board with that chip. 🙁
https://www.dosdays.co.uk/topics/Manufacturers/headland.php
HT22
A 286 and 386SX chipset launched in September 1991. For 286-class motherboards, the HT22 supports the Harris 80C286-25 MHz CPU.
It is likely the HT22 was a mildly upgraded HT21 that was able to cope with 25 MHz CPUs over the HT21's 20 MHz.
Reply 23 of 63, by Nexxen
Could it be that it was rebranded for PCChips and thus have another name?
TRW yields nothing.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 24 of 63, by douglar
Nexxen wrote on 2024-12-19, 14:22:
TRW yields nothing.
I think TRW & Dosdays list of Headland chipsets are both based on the data in MR_Slugs list.
When you go that far back before the web, sometimes the oral tradition preserved in BBS's like MR_Slugs list are all you got.
I can search through some old PC mags and Computer shoppers later to see if they have anything.
Reply 25 of 63, by Nexxen
douglar wrote on 2024-12-19, 15:26:
I think TRW & Dosdays list of Headland chipsets are both based on the data in MR_Slugs list. When you go that far back before […]
TRW yields nothing.
This is a huge side quest for a fistful of XP points.
Thank you for your commitment.
Reply 26 of 63, by douglar
Nexxen wrote on 2024-12-19, 16:49:
Looks HT-22 & HT18 use the same BIOS, but it is a different than the HT12
https://www.google.com/books/edition/The_Bios … nd+ht22&pg=PA28
Looks like HT-22 does 25Mhz FSB with 12.5 Mhz ISA
https://theretroweb.com/chip/documentation/ht … 0f014663141.pdf
So if I had to guess:
HT-12 = 20 Mhz and 4MB Ram
HT-18 = 20 Mhz and 16MB Ram
HT-21 = 25 Mhz and 16MB Ram but needed a re-spin for some reason and was rare
HT-22 = 25 Mhz and 16MB Ram
Reply 27 of 63, by Nexxen
Interesting read so far.
Reply 28 of 63, by maxtherabbit
are the 18/21/22 pin compatible to be used with this PCB design or is this all academic?
Reply 29 of 63, by Nexxen
maxtherabbit wrote on 2024-12-20, 15:19:
18 and 22 look like they are 100% compatible, at a first glance at the datasheets.
18 https://theretroweb.com/chip/documentation/ht … 98435658181.pdf
Reply 30 of 63, by feipoa
Nexxen wrote on 2024-12-20, 16:37:
...but HT12 has 160 pins, while HT18 has 208 pins. Thus, a PCB redesign would be required on this motherboard to accommodate HT18+
Reply 31 of 63, by Nexxen
feipoa wrote on 2024-12-20, 21:52:
Yes. He asked 18 to 22.
They have more internal circuitry, probably if you limited to 4MB of ram... IDK, an expert is needed to tell.
I'd like to find a seller for the HT12 though.
Reply 32 of 63, by Nelson68k
I have an HT18/B. It has 160 pins like the HT12. With a datasheet i could check if it is pin compatible.
Reply 33 of 63, by ecuProg7
Hi.
Great Project Nelson. Are the schematics available as open source?
I got my hands on an HT18 386SX Board. Now i´m playing with the idea of using the Chip for a 286 replica board.
Reply 34 of 63, by Nexxen
Nelson68k wrote on 2024-12-20, 23:30:
We discussed this in another thread, hoping for the same.
HT12 is 160 pin, HT18 is 208.
HT18 a,d 21/22 are pin compatible.
Reply 35 of 63, by Nexxen
I wish we had a HT12 boardview...
Reply 37 of 63, by Nexxen
Nelson68k wrote on 2025-01-24, 20:36:
Not now. Later, when the beta testers no longer find any bugs. […]
ecuProg7 wrote on 2025-01-24, 14:49:
Nexxen wrote on 2025-01-24, 17:08:
This?
The attachment Bildschirmfoto 2025-01-24 um 21.44.18.png is no longer available
Nelson, this is great.
Reply 38 of 63, by PC@LIVE
This?
Having the pin connection scheme, you can have the board made, and then you have to solder all the necessary components, maybe 🤔 who has a too damaged board, could make it work again with a new PCB.
For example, I kept an old 386DX from the late 80s, maybe 🤔 it could be repaired with a lot of (a lot of) work, but having a new PCB made, ultimately could be the easiest solution, because you don't have to go in search of traces interrupted by corrosion.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
Reply 39 of 63, by Nelson68k
Test the maximum speed. At the moment it is running stable at 24.58 MHz.
The attachment IMG_9480.jpg is no longer available
The attachment IMG_9479.jpg is no longer available
