Reply 20 of 27, by PcBytes
Reflashed both BIOS chips again, this time with the newest BIOS provided by TRW. Same symptoms.
Reply 21 of 27, by PcBytes
So slight update, now I somewhat got it to run. It now hangs in the way described in the OP only if I have external cache enabled.
Not sure where to look at this point given I redid the joints on all 4 cache chips, and even replaced the TAG RAM chip yet no change in that regard.
Reply 22 of 27, by Ozzuneoj
PcBytes wrote on 2024-12-23, 22:22:
Any idea what has changed since it also froze with cache disabled before?
Reply 23 of 27, by PcBytes
One thing I definitely remember was accidentally plugging an IDE cable backwards. It fried nothing, I caught it pretty early into POST and reverted the cable in the correct way. Since then it has started working albeit without its onboard cache.
Not sure what can I do at this moment, short of swapping its cache. The hardest part might be sourcing cache chips to rebuild the 1MB back.
Reply 24 of 27, by rasz_pl
There was a post about someone having trouble with L2 enabled and K6-3 FIC PA-2013 will not boot with "External Cache Enabled"
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 25 of 27, by PcBytes
rasz_pl wrote on 2024-12-24, 06:30:
Saw the thread but not of much help. They also did the same as me with replacing the TAG RAM chip and had the same outcome.
Reply 26 of 27, by PcBytes
Figured I'd update again. Won a local listing for 3x PA-2013 boards. Gonna be fun 🤣
Reply 27 of 27, by PC@LIVE
PcBytes wrote on 2025-01-10, 18:09:
Very interesting 🧐, keep us updated on the three motherboards, and possibly if you can make progress with the cache, that is, if it works by enabling it.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
