Reply 20 of 25, by bertrammatrix
feipoa wrote on 2025-02-13, 07:41:bertrammatrix wrote on 2025-02-12, 04:38:... unless of course my hardware is glitchy and some boards may be able to run faster settings with some bios, which can certainly be the case
May be. This is something I need to test for again. It may be an edge case situation. My board can do 180 Mhz with 1024K L2, and 128 MB EDO with 2-1-2 SRAM and DRAM at 1 ws read, 0 ws write. It may have been that I needed to set DRAM to 2 ws with the 5/6/1996 BIOS, but I don't recall.
Ugh 2-1-2, I wish. I still have to use the slowest setting with 60mhz FSB. I was honestly hoping this would improve seeing the 1024 module has some nice fast chips, comparatively to the original 256k one (which would also only work on the slowest setting on a 60mhz fsb)
Mmm maybe I will try to slow the dram down a tad and see if that helps.
