Lenovo Legion Go Doesn't Like Old Games?
Reply 20 of 20, by BEEN_Nath_58
davidmorom wrote on 2025-03-10, 20:11:
Also, you will need dgVoodoo or DDrawCompat, as this game, by default, uses the 320x240 mode, which is not supported anymore.
A minor correction: 320x240 and similar resolutions are not "enumerated by default" anymore. If you can successfully enable it in the Control Panel, they will be available to use. However they are not MODE X types: and hence render completely over DirectDraw.
The Lenovo Legion monitor won't probably go below 640x480 so the image will be upscaled by display
