Help me fix this 486 system
Reply 20 of 36, by Dorunkāku
I have a system that is simular, but not exactly the same. When I pull a RAM stick and power it on I get 3 low pitched (sad?) beeps followed by a short pause repeated ad infinum.
Reply 21 of 36, by ElectroSoldier
Dorunkāku wrote on 2025-04-18, 06:31:
Yes thats what happened.
It took a while, 5 minutes or so but yes thats what happened.
If I was to get some replacement RAM how many sticks would I need to test it?
SIMMs need to be populated in pairs or would I need 4 sticks to fill up bank 0 on this board?
Reply 22 of 36, by Dorunkāku
You need bank 0 populated with 4 sticks.
Reply 23 of 36, by ElectroSoldier
battery corrosion on the leg 🙁
Reply 24 of 36, by Matth79
On leg of what? also, that sent me looking at the area around it. make sure that JP8 is present on pins 1-2 CMOS normal, as if it's dropped off, boards with a normal / clear jumper may do nothing if it's missing altogether
Reply 25 of 36, by Shponglefan
ElectroSoldier wrote on 2025-04-17, 13:27:
So Creative sound cards were never very good then?
More like they are overrated, especially based on current retro prices. A lot of what people pay for is the nostalgia factor, not practical value.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 26 of 36, by Shponglefan
ElectroSoldier wrote on 2025-04-18, 09:27:
Battery corrosion is a pretty common issue for hardware of that era. Best thing to do is a full motherboard inspection, look for any signs of corrosion, test for continuity, shorts, etc.
Reply 27 of 36, by ElectroSoldier
Matth79 wrote on 2025-04-18, 13:52:
Leg of the battery. Small amount of corrosion. Doesnt look like its leaked anywhere yet.
This is the battery and the jumpers as they are now.
https://imgur.com/a/zGsCYYd
Reply 28 of 36, by ElectroSoldier
Is it possible to replace that battery like for like?
Ive been looking for it on google but I cant find it, at least not one that looks like that in the blue wrap?
If not what can I replace it with?
Reply 29 of 36, by ElectroSoldier
Going by the picture of the RAM and the motherboard is the RAM actually compatible with the board?
I was looking on ebay and it seems some is parity RAM and some isnt and Im not sure what this board needs to work.
Reply 30 of 36, by ElectroSoldier
Is there any chance an admin can mi e this to the General hardware board as I think it will stray into that topic rather than general chit chat
Reply 31 of 36, by Matth79
ElectroSoldier wrote on 2025-04-19, 14:47:
Most boards can use either, may need jumper setting, and if parity and non-parity are mixed, then it will all be non-parity. Some boards don't like 3 chip (parity) or 2 chip (non parity), only working with 9 chip (parity) or 8 chip (non) - but this was supposed to have been posting as it stood, with the reported amount being correct for a full set of 512k, minus the reserved
Reply 32 of 36, by Dorunkāku
No, according to the picture earlier in this thread the board came with eight 1MB SIMMs. Four with parity and four without. In the POST screen in the Ebay listing you can see that only 4MB is detected.
Have you tried only the four 3 chip sticks in bank 0? And if that does not work, only the four 2 chip sticks in bank 0?
If you want to find a replacement for the battery, search for "3.6v 80mah". Nowadays they wrap them in green plastic instead of blue, but that doesn't matter.
Reply 33 of 36, by ElectroSoldier
Matth79 wrote on 2025-04-20, 23:00:
I see... so different RAM might help you think?
Yeah my main problem is it doesnt do what it was supposed to have been doing.
Dorunkāku wrote on 2025-04-21, 08:21:
I have tried both of the sets in just Bank 0 with the same effect. Nothing happens at all. The monitor doesnt turn on, just nothing, as though there is no video output.
Reply 34 of 36, by ElectroSoldier
I had the post code analyser plugged into it both with and without any RAM.
It just displayed 4 dash marks. 4 lights on LEDs to show power rails and the reset LED remains lit.
Reply 35 of 36, by ElectroSoldier
This is a photo of the code code card I got to test it.
https://imgur.com/a/J0p3oC4
Reply 36 of 36, by ElectroSoldier
Can anybody help me find the battery for this motherboard please.
I would much prefer the exact same battery if possible. Otherwise a battery with the same foot print will do too.
UK based buyer.
