Reply 20 of 137, by Jackhead
- Oldbie
luckybob wrote on 2025-05-09, 15:14:The 5/12 processors have integrated voltage regulators. the 2.8v cpus do not. If a slot-2 motherboard has separate voltage regulators AS YOUR DOES, it means it is designed for the 2.8V processors.
The 2.8V Version with external VRMs can use 5V or 12V VRM moduls? Why different values? Confusing...
And boards from compaq for example dont have external VRM ports.
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - MPU-401AT with YucatanFX / Roland CM64
Win98SE: Asus XG DLS 1x SL4XY - SG Voodoo 5 6000 PCI - 1GB RAM ECC- Audigy 2 ZS - MX300
