Reply 20 of 40, by Major Jackyl
- Member
Make sure you have everything except floppy and VGA unplugged for testing phase. (since it boots still) Also try disabling everything disable-able in the BIOS
Will it not even sit at prompt without suddenly crashing? Or the execution of ANYTHING crashes it? If you can at least sit at POST or in the BIOS reliably(not crashed), you can probe around with it "running"; CPU voltage specifically.
*may not match your board
Also, feel around, see if anything is getting unusually hot. The hot thing/things around it could be bad, if voltages are good.
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
