Reply 20 of 83, by bakemono
Flagship cards can have good FPS/watt under load, but they all use more power at idle and at low GPU loads. Older games won't load the card at 100% so the FPS/watt will take a big hit. Cards with more memory and wider memory bus consume more power at idle.
Compare these:
GTX 970 4GB = 14.6W at idle
GTX 960 4GB = 11W
GTX 660 2GB = 11W
GTX 650 Ti 1GB = 8W
I don't know about Radeon cards of this generation, but the 4/5/6000 series can be hit or miss. For instance I have a 5570 1GB which throttles to 157MHz at idle and is around 10W maybe? But I have a 5670 1GB which only would throttle to 400MHz and clearly ran hotter at idle (though I never wrote down a measurement).
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
